Garuda Linux Stuck while booting
Hi All,
I am Using Garuda Linux for almost an year.
It was working fine but all of a sudden it stops booting.
It loads the Kernel but after kernel loaded the OS is not getting booted it stucks in the page wher it displays the logo.
I tried restoring snapshots collected before but same goes with snapshots as well.
Please help me on this.
Please do as the instructions read and post the terminal output of inxi -Faz
Oh! And glad you are onboard. :smiley:
Please press esc button or any arrow key to see the exact issue, and capture its image, and scan it in image to text, to paste it as text here.
I hope it is not a big task.
Hello Team
I am facing issue as per the below post.
My bad I was waiting for a email for response on the post and discussion got closed because of delayed response.
I have followed the steps as per @Naman
The device failed to boot due to disk issue.
setfont: KDFONTOP: Function not implemented mount: /new_root: wrong fs type, bad option, bad superblock on /dev/sda1, missing codepage or helper program, or other error. You are now being dropped into an emergency shell. sh: can't access tty: job control turned off
[rootfs l# df -h Filesystem
Size Used Available Use Mounted on dev
3.8G3.8G 0% /dev run
3.8G 140.OK 3.8G 0% /run
The disk is not being mounted.
attaching dmesg for reference
13963983 usb usb4: Manufacturer: Linux 5.12.2-zen2-1-zen xhci-hcd 13.963585) usb usb: Serial Number: 0000:00:14.0 13.964764] hub 4-0:1.0: USB hub found 13.9647851 hub 4-0:1.0: 4 ports detected 13.992251] sr 2:0:0:0: [sro] scsi3-mmc drive: 24x/24% writer dud-ram cd/rw xa/form2 cdda tray 13.9922581 cdrom: Uniform CD-ROM driver Revision: 3.20 14.013452) sr 2:0:0:0: Attached scsi CD-ROM sro 14.322008) random: fast init done 14.649024] raid6: skip pg benchmark and using algorithm sse2x4 14.649031] raid6: using ssse3x2 recovery algorithm 14.651319] xor: automatically using best checksumming function 14.735089] Btrfs loaded, crc32c=crc32c-intel, zoned=yes 14.736065] BTRFS: device fsid f4a72113-3238-4327-add8-36e7a3adc083 devid 1 transid 13806 /dev/sda1 scanned by systemd-udeud (187) 14.758952) input: AT Translated Set 2 keyboard as devices/platform/i8042/serioo/input/input? 15.169266] PM: Image not found (code -22) [ 15.180914] BTRFS info (device sdal): disk space caching is enabled [ 15.180922] BTRFS info (device sdal): has skinny extents [ 15.197595) fbcon: Taking over console [ 15.198359) Console: switching to colour frame buffer device 170x48 [ 15.471925) random: crng init done [ 15.686820) BTRFS error (device sdal): parent transid verify failed on 903823360 wanted 13806 found 13484 15.694269] BTRFS error (device sdal): parent transid verify failed on 903823360 wanted 13806 found 13484 15.694309) BTRFS error (device sdal): failed to read block groups: -5 15.696435] BTRFS error (device sda1): open_ctree failed [ 22.649630] [drm] enabling PCIE gen 2 link speeds, disable with radeon.pcie_gen2=0 [ 22.666968] [drm] PCIE GART of 1024M enabled (table at Ox0000000000162000). 22.667106) radeon 0000:01:00.0: WB enabled 22.667115) radeon 0000:01:00.0: fence driver on ring 0 use gpu addr 0x0000000040000000 22.667122) radeon 0000:01:00.0: fence driver on ring 3 use gpu addr Ox0000000040000cc 22.668713] radeon 0000:01:00.0: fence driver on ring 5 use gpu addr Ox0000000000072118 22.6854601 [drm] ring test on O succeeded in 1 usecs 22.685472] [drm) ring test on 3 succeeded in 3 usecs 23.872881] [drm:uud_v1_0_start [radeon]] *ERROR* UVD not responding, trying to reset the VCPU!!! 24.893136] [drm:uud_v1_0_start [radeon]] *ERROR* UVD not responding, trying to reset the VCPU!!! 25.913379] [drm:uud_v1_0_start [radeon]] *ERROR* UVD not responding, trying to reset the VCPU!!! 26.9336171 [drn:uud_v1_0_start [radeon]] *ERROR* UVD not responding, trying to reset the VCPU!1! [ 27.953854) (drm:uud_v1_0_start [radeon]] *ERROR* UVD not responding, trying to reset the VCPU!!! 28.974093] [drm:uud_v1_0_start [radeon]] *ERROR* UVD not responding, trying to reset the VCPU? 1! 29.9943301 [arn:uud v1_0_start [radeon]] "ERROR# UVD not responding, trying to reset the VCPU!!! 31.0145631 (drn uud_v1_0_start [radeon]] -ERRORUVD not responding, trying to reset the VCPU!!! 32.0348131 (drm:uud_v1_0_start [radeon]] *ERROR" UVD not responding, trying to reset the VCPU!!! 33.055054] [drn uud_v1_0_start [radeon ]] -ERROR* UVD not responding, trying to reset the VCPU!!! 33.075106] [drm:uud_v1_O_start Cradeon]] *ERRORUVD not responding, giving up!!! 33.075155) radeon 0000:01:00.0: failed initializing UVD (-1) 34.124800] [drm:r600_ib_test Cradeon]] -ERROR* radeon: fence wait timed out. [ 34.124875] [drn:radeon_ib_ring_tests (radeon]] ERROR* radeon: failed testing IB on GFX ring (-110). 34.124928] [drm:radeon_resume_kms Cradeon]] -ERROR* ib ring test failed (-110).
Are you able to chroot from a live USB?
If so, I'd try to first reinstall the grub, then update.
And what's more, I'd use it to save your data (but I hope you have back-ups).
If not, you could try to check the smart status of your drive.
Are you sure hard disk is working fine?
also post inxi Faz as text, from live medium
At the minimum the drive's file system is likely corrupted. It could also be possible a drive failure is in progress.
