Hi At first I had Windows 11 on my computer, but I changed to Fedora, but that hung for several seconds. I changed to Garuda linux, but the problem is similar. I wanted to install microsoft Flight simulator 2020 game through lutris but the game crashes on the first screen. Can the game work through lutris? I wanted to test the game, so I bought access to steam with the game for a little money. Could this affect the game's performance? I didn't want to risk the full amount for MSFS2020 not working on Linux. I don't know how to embrace these 2 problems. Can you guys help me out?
Kernel: 6.3.2-arch1-1-g14 arch: x86_64 bits: 64 compiler: gcc v: 13.1.1
parameters: ibt=off pm_debug_messages amd_pmc.dyndbg="+p" acpi.dyndbg="file
drivers/acpi/x86/s2idle.c +p" BOOT_IMAGE=/@/boot/vmlinuz-linux-g14
root=UUID=ce44ee29-c6e0-4698-ae11-c1ecd6dd1cd9 rw rootflags=subvol=@
quiet rd.luks.uuid=fb29c4c2-a91f-4bf0-bde4-2fd038611895 quiet splash
rd.luks.uuid=4bfc7a54-295a-46b3-bd1b-0cd44d8c6820
resume=/dev/mapper/luks-4bfc7a54-295a-46b3-bd1b-0cd44d8c6820 loglevel=3
Type: Laptop System: ASUSTeK product: ROG Zephyrus G14 GA401QE_GA401QE
Mobo: ASUSTeK model: GA401QE v: 1.0 serial: <superuser required>
UEFI: American Megatrends LLC. v: GA401QE.410 date: 08/30/2022
ID-1: BAT0 charge: 36.1 Wh (53.7%) condition: 67.2/76.0 Wh (88.4%)
status: charging
Info: model: AMD Ryzen 7 5800HS with Radeon Graphics bits: 64 type: MT MCP
microcode: 0xA50000C
L3: 16 MiB desc: 1x16 MiB
Speed (MHz): avg: 2864 high: 3380 min/max: 1200/4462 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 2624 2: 1703
3: 3200 4: 3200 5: 2045 6: 2539 7: 3200 8: 3380 9: 2500 10: 2819 11: 3200
12: 3200 13: 2625 14: 3200 15: 3200 16: 3200 bogomips: 102249
Device-1: NVIDIA GA107M [GeForce RTX 3050 Ti Mobile] vendor: ASUSTeK
driver: nvidia v: 530.41.03 alternate: nvidia_drm non-free: 530.xx+
status: current (as of 2023-05) arch: Ampere code: GAxxx
process: TSMC n7 (7nm) built: 2020-22 pcie: gen: 3 speed: 8 GT/s lanes: 8
link-max: gen: 4 speed: 16 GT/s lanes: 16 ports: active: none empty: DP-1
bus-ID: 01:00.0 chip-ID: 10de:25a0 class-ID: 0300
link-max: gen: 4 speed: 16 GT/s ports: active: eDP-1 empty: HDMI-A-1
bus-ID: 04:00.0 chip-ID: 1002:1638 class-ID: 0300 temp: 61.0 C
s-diag: 777mm (30.58")
Monitor-1: eDP-1 mapped: eDP model: TL140BDXP01-0 built: 2020
res: 2560x1440 hz: 120 dpi: 210 gamma: 1.2 size: 310x174mm (12.2x6.85")
diag: 355mm (14") ratio: 16:9 modes: max: 2560x1440 min: 640x480
API: OpenGL v: 4.6 Mesa 23.1.1 renderer: AMD Radeon Graphics (renoir LLVM
15.0.7 DRM 3.52 6.3.2-arch1-1-g14) direct-render: Yes
gen: 3 speed: 8 GT/s lanes: 8 link-max: gen: 4 speed: 16 GT/s lanes: 16
bus-ID: 01:00.1 chip-ID: 10de:2291 class-ID: 0403
Device-2: AMD Renoir Radeon High Definition Audio driver: snd_hda_intel
speed: 16 GT/s bus-ID: 04:00.1 chip-ID: 1002:1637 class-ID: 0403
lanes: 16 link-max: gen: 4 speed: 16 GT/s bus-ID: 04:00.5
link-max: gen: 4 speed: 16 GT/s bus-ID: 04:00.6 chip-ID: 1022:15e3
API: ALSA v: k6.3.2-arch1-1-g14 status: kernel-api with: aoss
Device-1: MEDIATEK MT7921 802.11ax PCI Express Wireless Network Adapter
lanes: 1 bus-ID: 02:00.0 chip-ID: 14c3:7961 class-ID: 0280
rev: 2.1 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-4:3 chip-ID: 13d3:3563
Local Storage: total: 476.94 GiB used: 161.06 GiB (33.8%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Intel model: SSDPEKNU512GZ
lanes: 4 tech: SSD serial: <filter> fw-rev: 002C temp: 39.9 C scheme: GPT
ID-1: / raw-size: 460.1 GiB size: 460.1 GiB (100.00%)
used: 161.06 GiB (35.0%) fs: btrfs dev: /dev/dm-0 maj-min: 254:0
mapped: luks-fb29c4c2-a91f-4bf0-bde4-2fd038611895
ID-3: /home raw-size: 460.1 GiB size: 460.1 GiB (100.00%)
ID-4: /var/log raw-size: 460.1 GiB size: 460.1 GiB (100.00%)
ID-5: /var/tmp raw-size: 460.1 GiB size: 460.1 GiB (100.00%)
ID-1: swap-1 type: partition size: 16.53 GiB used: 0 KiB (0.0%)
mapped: luks-4bfc7a54-295a-46b3-bd1b-0cd44d8c6820
ID-2: swap-2 type: zram size: 15.03 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 62.6 C mobo: N/A gpu: amdgpu temp: 61.0 C
Fan Speeds (RPM): cpu: 4300
Processes: 384 Uptime: 22m wakeups: 2 Memory: available: 15.03 GiB
used: 4.42 GiB (29.4%) Init: systemd v: 253 default: graphical
tool: systemctl Compilers: gcc: 13.1.1 Packages: 3734 pm: pacman pkgs: 1867
libs: 524 tools: octopi,paru pm: rpm pkgs: N/A note: see --rpm tools: dnf
pm: flatpak pkgs: 0 Shell: fish v: 3.6.1 default: Bash v: 5.1.16
running-in: konsole inxi: 3.3.27
System install date: 2023-05-28
Last full system update: 2023-05-29
