saikat:
add that parameter?
Boot to Grub.
At your main boot entry, press E
key, to go to a terminal like page.
Find the line that starts with linux
Go to the end of the line and write suggested parameters.
Press F10 to boot.
I have the same CPU and GPU and all are fine (with archlinux).
Your next option is to chroot
using Garuda ISO and run updates, or other actions to get info and/or repair.
Lots of instructions are at wiki and FAQ and Tutorials
I'm not a linux guy I always use windows, but for a project I'm using this and I'm in love with this distro
the Grub parameter is not working
Mina
11 March 2021 15:43
24
I recently had a similar experience with Dr46onized: An update pretty much destroyed everything: No more panels, window headers unresponsive, alacritty terminal not opening etc.
I restored the last snapshot and everything worked again. The snapshots are truly an amazing feature - and very much needed for rolling distributions.
petsam:
chroot
Please help me, To go through the chroot
thing
saikat:
the chroot
thing
Starting this is easy. But then, troubleshooting needs more effort and responsibility, study etc.
Boot to Garuda ISO.
Start Konsole, or other terminal.
Run this command
sudo garuda-chroot
Run other terminal commands.
When finished, exit , runningā¦
exit
Whatever error messages, post here.
Inside chroot, do at least (remember that you are logged in as root
with full privileges to fix or break your system):
pacman -Syu
mhwd -li
and post output of those two.
This problem was occurring due to the RLT8188FTV wifi usb adaptor driver. Can you please help me to fine a suitable driver?
At your services! I forward you to another employee which is a specialist on the subject.
@tbg hey!! Customer!
Come on! Time's money, you know!! Tsk - can't get the staff nowadays!
tbg
11 March 2021 20:18
31
If Iām any employee why am I still waiting for my first paycheck, not even a decent gaming laptop in the offing either.
Both packages are creating screen freezing issue
tbg
12 March 2021 06:08
35
I'd suggest testing different kenels.
I already mentioned the last time I dealt with your wifi support issue, I'd buy a replacement adapter as this model is very problematic. Being a USB adapter (not an internal) it's easily replaceable with lots of other more reliable reasonably priced alternatives.
This model just isn't worth the headaches it brings for the price of a cheap replacement..
All was good with the previous update but this update makes some issues with my device. I think there is an issue with the display driver.
Please check:
System: Kernel: 5.11.5-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 10.2.1
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-zen root=UUID=8186c618-9851-44b0-b4ad-8871694c16be
systemd.unified_cgroup_hierarchy=1 resume=UUID=612957a0-4479-4427-8050-affb9c62cba2 loglevel=3
Desktop: KDE Plasma 5.21.2 tk: Qt 5.15.2 info: latte-dock wm: kwin_x11 dm: SDDM
Distro: Garuda Linux
Machine: Type: Desktop Mobo: Micro-Star model: A320M-A PRO MAX (MS-7C52) v: 1.0 serial: <filter>
UEFI: American Megatrends v: 2.60 date: 06/10/2020
CPU: Info: Quad Core model: AMD Ryzen 5 3400G with Radeon Vega Graphics bits: 64 type: MT MCP
arch: Zen/Zen+ note: check family: 17 (23) model-id: 18 (24) stepping: 1 microcode: 8108109
L2 cache: 2 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm bogomips: 59204
Speed: 3700 MHz min/max: N/A Core speeds (MHz): 1: 3700 2: 3700 3: 3700 4: 3700 5: 3700 6: 1230
7: 3700 8: 3700
Graphics: Device-1: AMD Picasso vendor: Micro-Star MSI driver: amdgpu v: kernel bus ID: 29:00.0
chip ID: 1002:15d8 class ID: 0300
Display: x11 server: X.Org 1.20.10 compositor: kwin_x11 driver: loaded: amdgpu,ati
unloaded: modesetting alternate: fbdev,vesa display ID: :0 screens: 1
Monitor-1: HDMI-A-0 res: 1366x768 hz: 60 dpi: 81 size: 430x255mm (16.9x10.0")
diag: 500mm (19.7")
OpenGL: renderer: AMD Radeon Vega 11 Graphics (RAVEN DRM 3.40.0 5.11.5-zen1-1-zen LLVM 11.1.0)
v: 4.6 Mesa 20.3.4 direct render: Yes
Audio: Device-1: AMD Raven/Raven2/Fenghuang HDMI/DP Audio driver: snd_hda_intel v: kernel
bus ID: 29:00.1 chip ID: 1002:15de class ID: 0403
Device-2: AMD Family 17h HD Audio vendor: Micro-Star MSI driver: snd_hda_intel v: kernel
bus ID: 29:00.6 chip ID: 1022:15e3 class ID: 0403
Sound Server: ALSA v: k5.11.5-zen1-1-zen
Network: Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: Micro-Star MSI
driver: r8169 v: kernel port: f000 bus ID: 25:00.0 chip ID: 10ec:8168 class ID: 0200
IF: enp37s0 state: down mac: <filter>
Device-2: Realtek RTL8188FTV 802.11b/g/n 1T1R 2.4G WLAN Adapter type: USB driver: usb-network
bus ID: 3-4:3 chip ID: 0bda:f179 class ID: 0000 serial: <filter>
IF-ID-1: enp18s0f0u3 state: unknown speed: N/A duplex: N/A mac: <filter>
Drives: Local Storage: total: 447.13 GiB used: 11.74 GiB (2.6%)
ID-1: /dev/sda maj-min: 8:0 vendor: Kingston model: SA400S37480G size: 447.13 GiB block size:
physical: 512 B logical: 512 B speed: 6.0 Gb/s rotation: SSD serial: <filter> rev: 0102
scheme: MBR
Partition: ID-1: / raw size: 438.24 GiB size: 438.24 GiB (100.00%) used: 11.74 GiB (2.7%) fs: btrfs
dev: /dev/sda3 maj-min: 8:3
ID-2: /boot/efi raw size: 100 MiB size: 98.4 MiB (98.42%) used: 546 KiB (0.5%) fs: vfat
dev: /dev/sda1 maj-min: 8:1
ID-3: /home raw size: 438.24 GiB size: 438.24 GiB (100.00%) used: 11.74 GiB (2.7%) fs: btrfs
ID-4: /var/log raw size: 438.24 GiB size: 438.24 GiB (100.00%) used: 11.74 GiB (2.7%) fs: btrfs
ID-5: /var/tmp raw size: 438.24 GiB size: 438.24 GiB (100.00%) used: 11.74 GiB (2.7%) fs: btrfs
ID-1: swap-1 type: partition size: 8.79 GiB used: 0 KiB (0.0%) priority: -2 dev: /dev/sda2
maj-min: 8:2
ID-2: swap-2 type: zram size: 1.71 GiB used: 256 KiB (0.0%) priority: 32767 dev: /dev/zram0
ID-3: swap-3 type: zram size: 1.71 GiB used: 256 KiB (0.0%) priority: 32767 dev: /dev/zram1
ID-4: swap-4 type: zram size: 1.71 GiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram2
ID-5: swap-5 type: zram size: 1.71 GiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram3
ID-6: swap-6 type: zram size: 1.71 GiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram4
ID-7: swap-7 type: zram size: 1.71 GiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram5
ID-8: swap-8 type: zram size: 1.71 GiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram6
ID-9: swap-9 type: zram size: 1.71 GiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram7
Sensors: System Temperatures: cpu: 47.2 C mobo: N/A gpu: amdgpu temp: 47.0 C
Info: Processes: 345 Uptime: 1h 27m wakeups: 0 Memory: 13.67 GiB used: 7.11 GiB (52.0%) Init: systemd
v: 247 Compilers: gcc: 10.2.0 clang: 11.1.0 Packages: pacman: 1211 lib: 301 Shell: fish
v: 3.1.2 running in: konsole inxi: 3.3.01
tbg
12 March 2021 18:38
37
I leave display issues to others, I try to help users with networking issues mostly.
Good luck, and this time if you figure out a solution be sure to post the steps for others benefit (unlike the last thread I assisted you with where you ignored my request).
SGS
12 March 2021 18:44
38
Read
Writing a well formatted post in the forum (Discource powered) is important, if you want readers to easily read and understand.
It's especially important for terminal output.
Here is a brief tutorial.
Terminal output
For terminal output, text output with special characters, always use code wrapping (Pre-formated text).
Select all of the text and do one of these:
Hit the </> button in Discource Post Toolbar.
Press CtrlShift+C on your keyboard.
Manually with markdown
After you Copy yoā¦
please and edit your post. Itās a pain reading/scroll on phone/tablets.
