I am Using My Pc Which Has Garuda Linux Kde Dragnonized Installed In It...
I am facing os freezing problem with my pc After Updating It..
I am facing this same problem in my second pc too which has garuda gnome installed and i have seen many other users are also facing this same issue with garuda....
So This Is My Humble Request To Team Garuda Linux To Check This Issue ASAP..
Thank You Regards
Ayush Sharma (CyberBoyAyush)
inxi -Fxxxza
System: Kernel: 5.10.6-110-tkg-bmq x86_64 bits: 64 compiler: gcc v: 10.2.0
root=UUID=4ba46db0-b2a8-4f6c-b9b3-5905fdbb5e97 rw rootflags=subvol=@ quiet splash rd.udev.log_priority=3
vt.global_cursor_default=0 systemd.unified_cgroup_hierarchy=1 resume=UUID=0d1acd20-d33a-43e1-8be4-3bccd5caaf7a
Desktop: KDE Plasma 5.20.5 tk: Qt 5.15.2 info: latte-dock wm: kwin_x11 dm: SDDM Distro: Garuda Linux
Machine: Type: Desktop System: Gigabyte product: A320M-S2H v: N/A serial:
Mobo: Gigabyte model: A320M-S2H-CF v: x.x serial: UEFI: American Megatrends v: F22 date: 03/15/2018
CPU: Info: Quad Core model: AMD Ryzen 5 2400G with Radeon Vega Graphics bits: 64 type: MT MCP arch: Zen family: 17 (23)
model-id: 11 (17) stepping: N/A microcode: 8101007 L2 cache: 2 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm bogomips: 57549
Speed: 1421 MHz min/max: 1600/3600 MHz boost: disabled Core speeds (MHz): 1: 1421 2: 1422 3: 1421 4: 1423 5: 1480
6: 1438 7: 1420 8: 1422
Graphics: Device-1: AMD Raven Ridge [Radeon Vega Series / Radeon Vega Mobile Series] vendor: Gigabyte driver: amdgpu
v: kernel bus ID: 07:00.0 chip ID: 1002:15dd
Display: x11 server: [X.Org](http://X.Org) 1.20.10 compositor: kwin_x11 driver: amdgpu,ati unloaded: modesetting
alternate: fbdev,vesa display ID: :0 screens: 1
Monitor-1: HDMI-A-0 res: 1920x1080 hz: 60 dpi: 102 size: 477x268mm (18.8x10.6") diag: 547mm (21.5")
OpenGL: renderer: AMD Radeon Vega 11 Graphics (RAVEN DRM 3.40.0 5.10.6-110-tkg-bmq LLVM 11.0.0) v: 4.6 Mesa 20.3.2
direct render: Yes
Audio: Device-1: Advanced Micro Devices [AMD/ATI] Raven/Raven2/Fenghuang HDMI/DP Audio driver: snd_hda_intel v: kernel
bus ID: 07:00.1 chip ID: 1002:15de
Device-2: Advanced Micro Devices [AMD] Family 17h HD Audio vendor: Gigabyte driver: snd_hda_intel v: kernel
bus ID: 07:00.6 chip ID: 1022:15e3
Sound Server: ALSA v: k5.10.6-110-tkg-bmq
Network: Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: Gigabyte driver: r8169 v: kernel
port: f000 bus ID: 06:00.0 chip ID: 10ec:8168
IF: enp6s0 state: down mac:
Device-2: Realtek RTL8188FTV 802.11b/g/n 1T1R 2.4G WLAN Adapter type: USB driver: rtl8188fu bus ID: 1-4.4:3
chip ID: 0bda:f179 serial:
IF: wlp1s0f0u4u4 state: up mac:
Drives: Local Storage: total: 931.51 GiB used: 37.59 GiB (4.0%)
ID-1: /dev/sda maj-min: 8:0 vendor: Western Digital model: WD10EZEX-08WN4A0 size: 931.51 GiB block size:
physical: 4096 B logical: 512 B speed: 6.0 Gb/s serial: rev: 1A02
Partition: ID-1: / raw size: 922.42 GiB size: 922.42 GiB (100.00%) used: 37.59 GiB (4.1%) fs: btrfs dev: /dev/sda2
maj-min: 8:2
ID-2: /boot/efi raw size: 300 MiB size: 299.4 MiB (99.80%) used: 560 KiB (0.2%) fs: vfat dev: /dev/sda1
maj-min: 8:1
ID-3: /home raw size: 922.42 GiB size: 922.42 GiB (100.00%) used: 37.59 GiB (4.1%) fs: btrfs dev: /dev/sda2
maj-min: 8:2
ID-4: /var/log raw size: 922.42 GiB size: 922.42 GiB (100.00%) used: 37.59 GiB (4.1%) fs: btrfs dev: /dev/sda2
maj-min: 8:2
ID-5: /var/tmp raw size: 922.42 GiB size: 922.42 GiB (100.00%) used: 37.59 GiB (4.1%) fs: btrfs dev: /dev/sda2
maj-min: 8:2
ID-1: swap-1 type: partition size: 8.8 GiB used: 0 KiB (0.0%) priority: -2 dev: /dev/sda3 maj-min: 8:3
ID-2: swap-2 type: zram size: 869.2 MiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram0
ID-3: swap-3 type: zram size: 869.2 MiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram1
ID-4: swap-4 type: zram size: 869.2 MiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram2
ID-5: swap-5 type: zram size: 869.2 MiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram3
ID-6: swap-6 type: zram size: 869.2 MiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram4
ID-7: swap-7 type: zram size: 869.2 MiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram5
ID-8: swap-8 type: zram size: 869.2 MiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram6
ID-9: swap-9 type: zram size: 869.2 MiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram7
Sensors: System Temperatures: cpu: 31.6 C mobo: N/A gpu: amdgpu temp: 31.0 C
Info: Processes: 291 Uptime: 3m wakeups: 0 Memory: 6.79 GiB used: 2.3 GiB (33.9%) Init: systemd v: 247 Compilers:
gcc: 10.2.0 clang: 11.0.1 Packages: pacman: 1379 lib: 402 flatpak: 0 Shell: fish v: 3.1.2 running in: konsole
inxi: 3.2.01
