Pls help I can´t get sound
Provide info about your system
inxi -Fxxxza
Also when did this happen
It happend after I take out the headphone and it didn´t give the sound and I rebooted an d it still don´t gives the sound and I use B&O speaker with my laptop and I use Windows dual boot
Sory for bad english I am just 12
This is the out put of
inxi -Fxxza
Kernel: 5.9.13-98-tkg-bmq x86_64 bits: 64 compiler: gcc v: 10.2.0
parameters: intel_pstate=passive BOOT_IMAGE=/boot/vmlinuz-linux-tkg-bmq
root=UUID=3d050fbe-7357-4196-97b8-a28092ed9380 rw quiet splash
Desktop: KDE Plasma 5.20.4 tk: Qt 5.15.2 info: latte-dock wm: kwin_x11
dm: SDDM Distro: Garuda Linux
Type: Laptop System: HP product: HP Pavilion Power Laptop 15-cb0xx
v: Type1ProductConfigId serial: <filter> Chassis: type: 10
Mobo: HP model: 836B v: 46.20 serial: <filter> UEFI: Insyde v: F.09
date: 06/02/2017
ID-1: BAT0 charge: 44.4 Wh condition: 44.4/44.4 Wh (100%)
volts: 17.4/15.4 model: HP Primary type: Li-ion serial: N/A status: Full
Info: Quad Core model: Intel Core i7-7700HQ bits: 64 type: MT MCP
arch: Kaby Lake family: 6 model-id: 9E (158) stepping: 9 microcode: DE
L2 cache: 6144 KiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3
bogomips: 44840
Speed: 3586 MHz min/max: 800/3800 MHz Core speeds (MHz): 1: 3581 2: 3542
3: 3581 4: 3793 5: 3458 6: 3495 7: 3461 8: 3540
Device-1: Intel HD Graphics 630 vendor: Hewlett-Packard driver: i915
v: kernel bus ID: 00:02.0 chip ID: 8086:591b
Device-2: NVIDIA GP107M [GeForce GTX 1050 Mobile]
vendor: Hewlett-Packard driver: nvidia v: 455.45.01
alternate: nouveau,nvidia_drm bus ID: 01:00.0 chip ID: 10de:1c8d
Device-3: Chicony HP Wide Vision HD Camera type: USB driver: uvcvideo
bus ID: 1-4:3 chip ID: 04f2:b5d6
Display: x11 server: X.org 1.20.10 compositor: kwin_x11
driver: modesetting,nvidia alternate: fbdev,intel,nouveau,nv,vesa
resolution: <missing: xdpyinfo>
OpenGL: renderer: Mesa Intel HD Graphics 630 (KBL GT2)
v: 4.6 Mesa 20.3.0 direct render: Yes
Device-1: Intel CM238 HD Audio vendor: Hewlett-Packard
driver: snd_hda_intel v: kernel bus ID: 00:1f.3 chip ID: 8086:a171
Sound Server: ALSA v: k5.9.13-98-tkg-bmq
Device-1: Intel Wireless 7265 driver: iwlwifi v: kernel port: 4000
bus ID: 04:00.0 chip ID: 8086:095a
vendor: Hewlett-Packard driver: r8169 v: kernel port: 3000
bus ID: 05:00.0 chip ID: 10ec:8168
Local Storage: total: 931.51 GiB used: 35.98 GiB (3.9%)
ID-1: /dev/sda vendor: Western Digital model: WDS100T2B0A-00SM50
size: 931.51 GiB block size: physical: 512 B logical: 512 B
speed: 6.0 Gb/s serial: <filter> rev: 00WD scheme: GPT
ID-1: / raw size: 378.25 GiB size: 371.31 GiB (98.17%)
used: 35.75 GiB (9.6%) fs: ext4 dev: /dev/sda4
ID-1: swap-1 type: zram size: 980.3 MiB used: 0 KiB (0.0%)
priority: 32767 dev: /dev/zram0
ID-2: swap-2 type: zram size: 980.3 MiB used: 0 KiB (0.0%)
priority: 32767 dev: /dev/zram1
ID-3: swap-3 type: zram size: 980.3 MiB used: 0 KiB (0.0%)
priority: 32767 dev: /dev/zram2
ID-4: swap-4 type: zram size: 980.3 MiB used: 0 KiB (0.0%)
priority: 32767 dev: /dev/zram3
ID-5: swap-5 type: zram size: 980.3 MiB used: 0 KiB (0.0%)
priority: 32767 dev: /dev/zram4
ID-6: swap-6 type: zram size: 980.3 MiB used: 0 KiB (0.0%)
priority: 32767 dev: /dev/zram5
ID-7: swap-7 type: zram size: 980.3 MiB used: 0 KiB (0.0%)
priority: 32767 dev: /dev/zram6
ID-8: swap-8 type: zram size: 980.3 MiB used: 0 KiB (0.0%)
priority: 32767 dev: /dev/zram7
System Temperatures: cpu: 66.0 C mobo: N/A
Processes: 260 Uptime: 3m wakeups: 1 Memory: 7.66 GiB
used: 2.47 GiB (32.2%) Init: systemd v: 247 Compilers: gcc: 10.2.0
clang: 11.0.0 Packages: pacman: 1404 lib: 413 flatpak: 0 Shell: fish
v: 3.1.2 running in: konsole inxi: 3.1.09
I edit for you, three ~ in first and last line
Thanks for edit
