Hello Garudans,
My KDE system works good at most point but when I shutdown/reboot the my laptop then after login into my session what starts and only mouse cursor works but desktop/plasma all others freezing. Weirdly when I try to use TTY section most of commands/process has given the "not found" message. Only option rebooting laptop via TTY then session that works properly after fresh reboot.
That freezing kills me inside
garuda-inxi:
Kernel: 5.15.87-1-lts arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
root=UUID=b9a63755-06cc-46d3-a3a0-84752c0237dd rw [email protected]
loglevel=3 ibt=off
Desktop: KDE Plasma v: 5.26.5 tk: Qt v: 5.15.8 wm: kwin_x11 vt: 1 dm: SDDM
Type: Laptop System: Acer product: Nitro AN515-44 v: V1.04
Mobo: RO model: Stonic_RNS v: V1.04 serial: <superuser required>
UEFI: Insyde v: 1.04 date: 02/04/2021
ID-1: BAT1 charge: 40.1 Wh (80.5%) condition: 49.8/58.8 Wh (84.8%)
volts: 16.4 min: 15.4 model: SMP AP18E7M type: Li-ion serial: <filter>
status: N/A
Info: model: AMD Ryzen 7 4800H with Radeon Graphics bits: 64 type: MT MCP
microcode: 0x8600103
L1: 512 KiB desc: d-8x32 KiB; i-8x32 KiB L2: 4 MiB desc: 8x512 KiB L3: 8 MiB
desc: 2x4 MiB
Speed (MHz): avg: 1527 high: 2946 min/max: 1400/2900 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 2946 2: 1397
3: 1397 4: 1397 5: 1397 6: 1397 7: 1397 8: 1397 9: 1397 10: 1395 11: 1481
12: 1397 13: 1397 14: 1397 15: 1852 16: 1397 bogomips: 92628
Device-1: NVIDIA TU117M [GeForce GTX 1650 Ti Mobile]
vendor: Acer Incorporated ALI driver: nvidia v: 525.78.01
alternate: nouveau,nvidia_drm non-free: 525.xx+
status: current (as of 2022-12) arch: Turing code: TUxxx
process: TSMC 12nm FF built: 2018-22 pcie: gen: 1 speed: 2.5 GT/s lanes: 8
link-max: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 01:00.0
chip-ID: 10de:1f95 class-ID: 0300
Device-2: AMD Renoir vendor: Acer Incorporated ALI driver: amdgpu
v: kernel arch: GCN-5.1 code: Vega-2 process: TSMC n7 (7nm) built: 2018-21
pcie: gen: 4 speed: 16 GT/s lanes: 16 ports: active: eDP-1 empty: none
bus-ID: 05:00.0 chip-ID: 1002:1636 class-ID: 0300 temp: 35.0 C
Device-3: Quanta HD User Facing type: USB driver: uvcvideo bus-ID: 3-3:2
chip-ID: 0408:a061 class-ID: 0e02
Monitor-1: eDP-1 mapped: eDP model: Najing CEC Panda 0x004d built: 2019
res: 1920x1080 dpi: 142 gamma: 1.2 size: 344x194mm (13.54x7.64")
API: OpenGL v: 4.6 Mesa 22.3.3 renderer: AMD Radeon Graphics (renoir LLVM
14.0.6 DRM 3.42 5.15.87-1-lts) direct render: Yes
Device-1: NVIDIA vendor: Acer Incorporated ALI driver: snd_hda_intel
v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 8 link-max: gen: 3
speed: 8 GT/s lanes: 16 bus-ID: 01:00.1 chip-ID: 10de:10fa class-ID: 0403
Device-2: AMD ACP/ACP3X/ACP6x Audio Coprocessor
vendor: Acer Incorporated ALI driver: N/A alternate: snd_pci_acp3x,
snd_rn_pci_acp3x, snd_pci_acp5x pcie: gen: 4 speed: 16 GT/s lanes: 16
bus-ID: 05:00.5 chip-ID: 1022:15e2 class-ID: 0480
Device-3: AMD Family 17h/19h HD Audio vendor: Acer Incorporated ALI
Sound API: ALSA v: k5.15.87-1-lts running: yes
Device-1: Realtek vendor: Acer Incorporated ALI driver: r8169 v: kernel
pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: 2000 bus-ID: 03:00.0
chip-ID: 10ec:2600 class-ID: 0200
speed: 5 GT/s lanes: 1 bus-ID: 04:00.0 chip-ID: 8086:2723 class-ID: 0280
Device-1: Intel AX200 Bluetooth type: USB driver: btusb v: 0.8 bus-ID: 1-4:3
chip-ID: 8087:0029 class-ID: e001
address: <filter>
Local Storage: total: 476.94 GiB used: 49.84 GiB (10.5%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Western Digital model: PC SN530
SDBPNPZ-512G-1014 size: 476.94 GiB block-size: physical: 512 B
rev: 21103900 temp: 28.9 C scheme: GPT
ID-1: / raw-size: 165.26 GiB size: 165.26 GiB (100.00%)
used: 49.79 GiB (30.1%) fs: btrfs dev: /dev/nvme0n1p4 maj-min: 259:4
ID-2: /boot/efi raw-size: 1024 MiB size: 1020 MiB (99.61%)
used: 50.3 MiB (4.9%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 165.26 GiB size: 165.26 GiB (100.00%)
ID-4: /var/log raw-size: 165.26 GiB size: 165.26 GiB (100.00%)
ID-5: /var/tmp raw-size: 165.26 GiB size: 165.26 GiB (100.00%)
ID-1: swap-1 type: zram size: 15 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 53.0 C mobo: N/A gpu: amdgpu temp: 36.0 C
Processes: 359 Uptime: 10m wakeups: 1 Memory: 15 GiB used: 3.96 GiB (26.4%)
Init: systemd v: 252 default: graphical tool: systemctl Compilers:
gcc: 12.2.0 Packages: 1681 pm: pacman pkgs: 1665 libs: 372
tools: octopi,paru pm: flatpak pkgs: 16 Shell: fish v: 3.5.1 default: Bash
v: 5.1.16 running-in: konsole inxi: 3.3.24
Garuda (2.6.14-1):
System install date: 2022-11-19
Last full system update: 2023-01-16
Thanks for your helps.
