Hi, as proposed in the title, I want my HDD to stop spinning after 10minutes of not using it. So I configured my HDD via gnome-disks (used to that from my times with Linux Mint, didnt see a reason to search for another program to do what i do with gnome disks so yea) to auto-sleep or stop spinning however youll call it after 10min of inactivity. I literally sat in front of my pc, without having any program open and just waited for my hdd to turn off. It didnt.
I didnt find any useful information in my system or the internet, probably because I dont really know what Im looking for.
Any help is greatly appreciated, thanks in advance!
─λ inxi -Faz
System: Kernel: 5.15.7-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-zen root=UUID=6bf2fd60-5bcf-49a1-8f0a-55b3687cb794
systemd.unified_cgroup_hierarchy=1 resume=UUID=11eb62e4-36a7-43bd-a30b-df8ffca3446f loglevel=3
Desktop: KDE Plasma 5.23.4 tk: Qt 5.15.2 info: latte-dock wm: kwin_x11 vt: 1 dm: SDDM
Machine: Type: Desktop Mobo: ASUSTeK model: PRIME B350-PLUS v: Rev X.0x serial: <superuser required>
UEFI: American Megatrends v: 0902 date: 09/08/2017
Battery: ID-1: hidpp_battery_0 charge: 99% condition: N/A volts: 4.2 min: N/A
model: Logitech G502 LIGHTSPEED Wireless Gaming Mouse type: N/A serial: <filter>
status: Discharging
CPU: Info: 6-Core model: AMD Ryzen 5 1600 bits: 64 type: MT MCP arch: Zen family: 17 (23)
model-id: 1 stepping: 1 microcode: 8001129 cache: L1: 576 KiB L2: 3 MiB L3: 16 MiB
flags: avx avx2 ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm bogomips: 91032
Speed: 3693 MHz min/max: 1550/3800 MHz boost: disabled Core speeds (MHz): 1: 3693 2: 3700
3: 3581 4: 3448 5: 3525 6: 3513 7: 3406 8: 3672 9: 3511 10: 3419 11: 3607 12: 3328
Type: spectre_v2 mitigation: Full AMD retpoline, STIBP: disabled, RSB filling
Graphics: Device-1: AMD Navi 22 [Radeon RX 6700/6700 XT / 6800M] vendor: Gigabyte driver: amdgpu
v: kernel bus-ID: 24:00.0 chip-ID: 1002:73df class-ID: 0300
Display: x11 server: X.Org 1.21.1.1 compositor: kwin_x11 driver: loaded: amdgpu,ati
unloaded: modesetting,radeon alternate: fbdev,vesa display-ID: :0 screens: 1
Screen-1: 0 s-res: 4480x1080 s-dpi: 96 s-size: 1182x285mm (46.5x11.2") s-diag: 1216mm (47.9")
Monitor-1: DisplayPort-1 res: 2560x1080 hz: 60 dpi: 81 size: 798x334mm (31.4x13.1")
diag: 865mm (34.1")
Monitor-2: HDMI-A-1 res: 1920x1080 hz: 60 dpi: 102 size: 477x268mm (18.8x10.6")
diag: 547mm (21.5")
OpenGL:
renderer: AMD Radeon RX 6700 XT (NAVY_FLOUNDER DRM 3.42.0 5.15.7-zen1-1-zen LLVM 13.0.0)
v: 4.6 Mesa 21.2.5 direct render: Yes
Audio: Device-1: AMD Navi 21 HDMI Audio [Radeon RX 6800/6800 XT / 6900 XT] driver: snd_hda_intel
v: kernel bus-ID: 24:00.1 chip-ID: 1002:ab28 class-ID: 0403
Device-2: AMD Family 17h HD Audio vendor: ASUSTeK driver: snd_hda_intel v: kernel
bus-ID: 26:00.3 chip-ID: 1022:1457 class-ID: 0403
Device-3: Realtek USB2.0 Microphone type: USB driver: hid-generic,snd-usb-audio,usbhid
bus-ID: 1-2:3 chip-ID: 0bda:4937 class-ID: 0300 serial: <filter>
Device-4: SteelSeries ApS SteelSeries Arctis 7 type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 3-4.1:3 chip-ID: 1038:12ad class-ID: 0300
Sound Server-1: ALSA v: k5.15.7-zen1-1-zen running: yes
Network: Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: ASUSTeK PRIME B450M-A
driver: r8169 v: kernel port: f000 bus-ID: 1e:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp30s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Bluetooth: Device-1: Realtek Bluetooth Radio type: USB driver: btusb v: 0.8 bus-ID: 1-3:4
chip-ID: 0bda:8771 class-ID: e001 serial: <filter>
Report: bt-adapter ID: hci0 rfk-id: 0 state: down bt-service: enabled,running rfk-block:
hardware: no software: no address: <filter>
Drives: Local Storage: total: 7.04 TiB used: 6.18 TiB (87.8%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Western Digital model: WDS500G3XHC-00SJG0
size: 465.76 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s lanes: 4 type: SSD
serial: <filter> rev: 102000WD temp: 50.9 C scheme: MBR
ID-2: /dev/sda maj-min: 8:0 vendor: SanDisk model: SSD PLUS 240GB size: 223.58 GiB block-size:
physical: 512 B logical: 512 B speed: 6.0 Gb/s type: SSD serial: <filter> rev: 00RL scheme: MBR
ID-3: /dev/sdb maj-min: 8:16 vendor: Toshiba model: DT01ACA300 size: 2.73 TiB block-size:
physical: 4096 B logical: 512 B speed: 6.0 Gb/s type: HDD rpm: 7200 serial: <filter> rev: ABB0
ID-4: /dev/sdc maj-min: 8:32 type: USB vendor: Seagate model: Expansion Desk size: 3.64 TiB
block-size: physical: 4096 B logical: 512 B type: N/A serial: <filter> rev: 0915 scheme: GPT
Partition: ID-1: / raw-size: 100 GiB size: 100 GiB (100.00%) used: 97.6 GiB (97.6%) fs: btrfs
ID-2: /boot/efi raw-size: 512 MiB size: 511 MiB (99.80%) used: 576 KiB (0.1%) fs: vfat
ID-3: /home raw-size: 349.26 GiB size: 349.26 GiB (100.00%) used: 197.41 GiB (56.5%) fs: btrfs
ID-4: /var/log raw-size: 100 GiB size: 100 GiB (100.00%) used: 97.6 GiB (97.6%) fs: btrfs
ID-5: /var/tmp raw-size: 100 GiB size: 100 GiB (100.00%) used: 97.6 GiB (97.6%) fs: btrfs
ID-1: swap-1 type: partition size: 16 GiB used: 0 KiB (0.0%) priority: -2 dev: /dev/nvme0n1p2
maj-min: 259:2
ID-2: swap-2 type: zram size: 31.34 GiB used: 2.2 MiB (0.0%) priority: 100 dev: /dev/zram0
Sensors: Message: No sensor data found. Is lm-sensors configured?
Info: Processes: 446 Uptime: 6h 10m wakeups: 14 Memory: 31.35 GiB used: 9.52 GiB (30.4%)
Init: systemd v: 249 tool: systemctl Compilers: gcc: 11.1.0 clang: 13.0.0 Packages:
pacman: 1831 lib: 491 Shell: fish v: 3.3.1 default: Bash v: 5.1.12 running-in: konsole
inxi: 3.3.09
