Garuda isnt detecting my Built-In audio or microphone (Fixed)
I’m trying to setup audio but the page is just blank i haven’t the slightest clue on how to make my built in audio device to show
root=UUID=2c2c7353-ed2e-40c0-aed4-20bdb91ed0d3 rw rootflags=subvol=@
loglevel=3 ibt=off
Desktop: KDE Plasma v: 5.27.7 tk: Qt v: 5.15.10 wm: kwin_x11 vt: 1
Type: Laptop System: Acer product: Nitro AN515-54 v: V1.33
Mobo: CFL model: Octavia_CFS v: V1.33 serial: <superuser required>
UEFI: Insyde v: 1.33 date: 11/17/2020
ID-1: BAT1 charge: 42.5 Wh (99.8%) condition: 42.6/57.5 Wh (74.1%)
volts: 16.7 min: 15.4 model: LGC AP18E8M type: Li-ion serial: <filter>
status: not charging
Info: model: Intel Core i5-9300H bits: 64 type: MT MCP arch: Coffee Lake
L3: 8 MiB desc: 1x8 MiB
Speed (MHz): avg: 2800 high: 4004 min/max: 800/4100 scaling:
driver: intel_pstate governor: performance cores: 1: 4000 2: 2400 3: 2400
4: 4004 5: 2400 6: 2400 7: 2400 8: 2400 bogomips: 38400
Device-1: Intel CoffeeLake-H GT2 [UHD Graphics 630]
vendor: Acer Incorporated ALI driver: i915 v: kernel arch: Gen-9.5
process: Intel 14nm built: 2016-20 ports: active: eDP-1 empty: none
bus-ID: 0000:00:02.0 chip-ID: 8086:3e9b class-ID: 0300
Device-2: NVIDIA TU117M [GeForce GTX 1650 Mobile / Max-Q]
vendor: Acer Incorporated ALI driver: nouveau v: kernel
alternate: nvidia_drm,nvidia non-free: 535.xx+
status: current (as of 2023-08) arch: Turing code: TUxxx
process: TSMC 12nm FF built: 2018-22 ports: active: none empty: HDMI-A-1
bus-ID: 0000:01:00.0 chip-ID: 10de:1f91 class-ID: 0300
Device-3: Chicony HD User Facing driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-5:3 chip-ID: 04f2:b64f
compositor: kwin_x11 driver: X: loaded: modesetting,nouveau
alternate: fbdev,intel,nv,vesa dri: iris,nouveau gpu: i915 display-ID: :0
Monitor-1: eDP-1 model: AU Optronics 0x21ed built: 2016 res: 1920x1080
ratio: 16:9 modes: 1920x1080
API: OpenGL v: 4.6 Mesa 23.1.7-arch1.1 renderer: Mesa Intel UHD Graphics
630 (CFL GT2) direct-render: Yes
Device-1: Intel Cannon Lake PCH cAVS vendor: Acer Incorporated ALI
bus-ID: 0000:00:1f.3 chip-ID: 8086:a348 class-ID: 0403
Device-2: NVIDIA vendor: Acer Incorporated ALI driver: snd_hda_intel
v: kernel bus-ID: 0000:01:00.1 chip-ID: 10de:10fa class-ID: 0403
API: ALSA v: k6.2.13-zen-1-zen status: kernel-api with: aoss
Server-1: PipeWire v: 0.3.79 status: active with: 1: pipewire-pulse
bus-ID: 0000:00:14.3 chip-ID: 8086:a370 class-ID: 0280
vendor: Acer Incorporated ALI driver: r8169 v: kernel port: 3000
bus-ID: 0000:06:00.0 chip-ID: 10ec:8168 class-ID: 0200
v: 0.8 type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-14:4
lmp-v: 10 status: discoverable: no pairing: no class-ID: 7c010c
driver: intel_nvme_remap v: N/A port: 5060 bus-ID: 0000:00:17.0
chip-ID: 8086:282a rev: N/A class-ID: 0104
Local Storage: total: 2.29 TiB used: 463.4 GiB (19.8%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Western Digital model: PC SN520
SDAPNUW-512G-1014 size: 476.94 GiB block-size: physical: 512 B
logical: 512 B tech: SSD serial: <filter> fw-rev: 20110000 temp: 31.9 C
model: WD20SPZX-22UA7T0 size: 1.82 TiB block-size: physical: 4096 B
logical: 512 B type: USB rev: 3.0 spd: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1
tech: HDD rpm: 5400 serial: <filter> scheme: GPT
ID-1: / raw-size: 1.82 TiB size: 1.82 TiB (100.00%) used: 21.75 GiB (1.2%)
used: 21.75 GiB (1.2%) fs: btrfs dev: /dev/sda2 maj-min: 8:2
ID-1: swap-1 type: zram size: 15.46 GiB used: 700 MiB (4.4%) priority: 100
System Temperatures: cpu: 46.0 C pch: 55.0 C mobo: N/A gpu: nouveau
temp: 33.0 C
Processes: 287 Uptime: 58m wakeups: 3 Memory: total: 16 GiB
available: 15.46 GiB used: 4.21 GiB (27.2%) Init: systemd v: 254
pm: pacman pkgs: 1882 libs: 531 tools: octopi,paru Shell: fish v: 3.6.1
default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.29
System install date:     2023-09-10
Last full system update: 2023-09-10 ↻
but this shows up on aplay -l
**** List of PLAYBACK Hardware Devices ****
card 0: PCH [HDA Intel PCH], device 0: ALC255 Analog [ALC255 Analog]
Subdevices: 1/1
Subdevice #0: subdevice #0
You just installed and/or your system needs rebooting. Please 1st do that then report back.
:slight_smile:
Thank you for your help, it worked.
KDE is like M$, always restart :smiley:
