Hello.
Every day I turn on the computer, garuda seems to restart my volume configuration, I know this is not a mayor issue, but is anoying and I'm trying to get rid of it. Anyone know whats happening?
Hope you can help me.
System: Kernel: 5.15.2-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-zen root=UUID=237a9908-4e49-4521-88ed-64c5eeeafc8f
Desktop: KDE Plasma 5.23.3 tk: Qt 5.15.2 info: latte-dock wm: kwin_x11 vt: 1 dm: SDDM
Machine: Type: Desktop Mobo: Gigabyte model: B450 AORUS ELITE v: x.x serial: <filter>
UEFI: American Megatrends LLC. v: F62c date: 05/10/2021
CPU: Info: 8-Core model: AMD Ryzen 7 2700 bits: 64 type: MT MCP arch: Zen+ family: 17 (23)
model-id: 8 stepping: 2 microcode: 800820D cache: L2: 4 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm bogomips: 102204
Speed: 3311 MHz min/max: 1550/3200 MHz boost: enabled Core speeds (MHz): 1: 3311 2: 3222
3: 3272 4: 3300 5: 3303 6: 3316 7: 3309 8: 3317 9: 3280 10: 3285 11: 3294 12: 3300 13: 3316
14: 3317 15: 3312 16: 3287
Graphics: Device-1: AMD Ellesmere [Radeon RX 470/480/570/570X/580/580X/590] vendor: XFX Pine
driver: amdgpu v: kernel bus-ID: 07:00.0 chip-ID: 1002:67df class-ID: 0300
Display: x11 server: X.Org 1.21.1.1 compositor: kwin_x11 driver: loaded: amdgpu,ati
Screen-1: 0 s-res: 3000x1920 s-dpi: 96 s-size: 791x506mm (31.1x19.9") s-diag: 939mm (37")
Monitor-1: HDMI-A-0 res: 1920x1080 hz: 60 dpi: 93 size: 527x296mm (20.7x11.7")
diag: 604mm (23.8")
Monitor-2: DVI-D-0 res: 1080x1920 hz: 60
OpenGL: renderer: AMD Radeon RX 590 Series (POLARIS10 DRM 3.42.0 5.15.2-zen1-1-zen LLVM 13.0.0)
v: 4.6 Mesa 21.2.5 direct render: Yes
Audio: Device-1: AMD Ellesmere HDMI Audio [Radeon RX 470/480 / 570/580/590] vendor: XFX Pine
driver: snd_hda_intel v: kernel bus-ID: 07:00.1 chip-ID: 1002:aaf0 class-ID: 0403
Device-2: AMD Family 17h HD Audio vendor: Gigabyte driver: snd_hda_intel v: kernel
bus-ID: 09:00.3 chip-ID: 1022:1457 class-ID: 0403
Sound Server-1: ALSA v: k5.15.2-zen1-1-zen running: yes
Sound Server-4: PulseAudio v: 15.0 running: yes
Sound Server-5: PipeWire v: 0.3.40 running: yes
Network: Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: Gigabyte driver: r8169
v: kernel port: f000 bus-ID: 04:00.0 chip-ID: 10ec:8168 class-ID: 0200
Drives: Local Storage: total: 1.58 TiB used: 737.44 GiB (45.5%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Kingston model: SNVS500GB size: 465.76 GiB
rev: S8542101 temp: 45.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Western Digital model: WD10EZEX-75WN4A1 size: 931.51 GiB
serial: <filter> rev: 7113 scheme: GPT
ID-3: /dev/sdb maj-min: 8:16 vendor: Kingston model: SA400S37240G size: 223.57 GiB block-size:
physical: 512 B logical: 512 B speed: 6.0 Gb/s type: SSD serial: <filter> rev: 0009 scheme: GPT
Partition: ID-1: / raw-size: 223.31 GiB size: 223.31 GiB (100.00%) used: 94.89 GiB (42.5%) fs: btrfs
dev: /dev/sdb2 maj-min: 8:18
ID-2: /boot/efi raw-size: 260 MiB size: 256 MiB (98.45%) used: 562 KiB (0.2%) fs: vfat
dev: /dev/sdb1 maj-min: 8:17
ID-3: /home raw-size: 223.31 GiB size: 223.31 GiB (100.00%) used: 94.89 GiB (42.5%) fs: btrfs
ID-4: /var/log raw-size: 223.31 GiB size: 223.31 GiB (100.00%) used: 94.89 GiB (42.5%)
fs: btrfs dev: /dev/sdb2 maj-min: 8:18
ID-5: /var/tmp raw-size: 223.31 GiB size: 223.31 GiB (100.00%) used: 94.89 GiB (42.5%)
ID-1: swap-1 type: zram size: 15.63 GiB used: 1.62 GiB (10.4%) priority: 100 dev: /dev/zram0
Sensors: Message: No sensor data found. Is lm-sensors configured?
Info: Processes: 427 Uptime: 1h 59m wakeups: 0 Memory: 15.63 GiB used: 9.33 GiB (59.7%) Init: systemd
v: 249 tool: systemctl Compilers: gcc: 11.1.0 clang: 13.0.0 Packages: pacman: 2096 lib: 473
