Kernel: 6.17.6-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 15.2.1 clocksource: tsc
root=UUID=df5afb76-7e89-4e11-8c00-5f1809053a31 rw rootflags=subvol=@ quiet loglevel=3
Desktop: KDE Plasma v: 6.5.1 tk: Qt v: N/A info: frameworks v: 6.19.0 wm: kwin_wayland vt: 1
Type: Desktop System: Gigabyte product: Z790I AORUS ULTRA v: -CF serial: <superuser required>
Mobo: Gigabyte model: Z790I AORUS ULTRA v: x.x serial: <superuser required>
uuid: <superuser required> UEFI: American Megatrends LLC. v: F10 date: 06/19/2025
Info: model: Intel Core i7-14700K bits: 64 type: MST AMCP arch: Raptor Lake gen: core 14
level: v3 note: check built: 2022+ process: Intel 7 (10nm) family: 6 model-id: 0xB7 (183)
stepping: 1 microcode: 0x12F
Topology: cpus: 1x dies: 1 clusters: 11 cores: 20 threads: 28 mt: 8 tpc: 2 st: 12 smt: enabled
cache: L1: 1.8 MiB desc: d-12x32 KiB, 8x48 KiB; i-8x32 KiB, 12x64 KiB L2: 28 MiB
desc: 8x2 MiB, 3x4 MiB L3: 33 MiB desc: 1x33 MiB
Speed (MHz): avg: 5400 min/max: 800/5500:5600:4300 scaling: driver: intel_pstate
governor: powersave cores: 1: 5400 2: 5400 3: 5400 4: 5400 5: 5400 6: 5400 7: 5400 8: 5400
9: 5400 10: 5400 11: 5400 12: 5400 13: 5400 14: 5400 15: 5400 16: 5400 17: 5400 18: 5400
19: 5400 20: 5400 21: 5400 22: 5400 23: 5400 24: 5400 25: 5400 26: 5400 27: 5400 28: 5400
bogomips: 191385
Device-1: Intel Raptor Lake-S GT1 [UHD Graphics 770] vendor: Gigabyte driver: i915 v: kernel
alternate: xe arch: Xe process: Intel 10nm built: 2020-21 ports: active: none
empty: DP-1,HDMI-A-1,HDMI-A-2 bus-ID: 00:02.0 chip-ID: 8086:a780 class-ID: 0380
Device-2: NVIDIA GB205 [GeForce RTX 5070] driver: N/A alternate: nouveau non-free: 550-580.xx+
status: current (as of 2025-08) arch: Lovelace code: AD1xx process: TSMC n4 (5nm) built: 2022+
pcie: gen: 4 speed: 16 GT/s lanes: 16 link-max: gen: 5 speed: 32 GT/s bus-ID: 01:00.0
chip-ID: 10de:2f04 class-ID: 0300
Display: wayland server: X.org v: 1.21.1.20 with: Xwayland v: 24.1.9 compositor: kwin_wayland
driver: X: loaded: modesetting,nouveau alternate: fbdev,intel,nv,vesa dri: iris gpu: i915
display-ID: 0
Monitor-1: Unknown-1 res: mode: 1920x1080 hz: 60 scale: 100% (1) dpi: 96
size: 508x285mm (20x11.22") diag: 582mm (22.93") modes: 1920x1080
API: EGL v: 1.5 hw: drv: intel iris platforms: device: 0 drv: iris device: 1 drv: swrast gbm:
drv: iris surfaceless: drv: iris wayland: drv: swrast x11: drv: swrast
API: OpenGL v: 4.6 compat-v: 4.5 vendor: mesa v: 25.2.6-arch1.1 glx-v: 1.4 direct-render: yes
renderer: llvmpipe (LLVM 21.1.4 256 bits) device-ID: ffffffff:ffffffff memory: 30.38 GiB
unified: yes display-ID: :1.0
API: Vulkan v: 1.4.328 layers: 15 device: 0 type: integrated-gpu name: Intel Graphics (RPL-S)
driver: mesa intel v: 25.2.6-arch1.1 device-ID: 8086:a780 surfaces: N/A device: 1 type: cpu
name: llvmpipe (LLVM 21.1.4 256 bits) driver: mesa llvmpipe v: 25.2.6-arch1.1 (LLVM 21.1.4)
gpu: corectrl, nvidia-settings, nvidia-smi wl: wayland-info x11: xdpyinfo, xprop, xrandr
Device-1: Intel Raptor Lake High Definition Audio vendor: Gigabyte driver: snd_hda_intel
v: kernel alternate: snd_soc_avs,snd_sof_pci_intel_tgl bus-ID: 00:1f.3 chip-ID: 8086:7a50
Device-2: NVIDIA driver: snd_hda_intel v: kernel pcie: gen: 4 speed: 16 GT/s lanes: 16
link-max: gen: 5 speed: 32 GT/s bus-ID: 01:00.1 chip-ID: 10de:2f80 class-ID: 0403
Device-3: Giga-Byte USB Audio driver: hid-generic,snd-usb-audio,usbhid type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-2:2 chip-ID: 0414:a014 class-ID: 0300
Device-4: Creative Sound Blaster Premium HD [SBX] driver: hid-generic,snd-usb-audio,usbhid
type: USB rev: 1.1 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-7:4 chip-ID: 041e:3232
API: ALSA v: k6.17.6-zen1-1-zen status: kernel-api with: aoss type: oss-emulator tools: N/A
Server-1: PipeWire v: 1.4.9 status: active with: 1: pipewire-pulse status: active
Device-1: Intel Raptor Lake-S PCH CNVi WiFi vendor: Rivet Networks driver: iwlwifi v: kernel
Device-2: Intel Ethernet I225-V vendor: Gigabyte driver: igc v: kernel pcie: gen: 2
speed: 5 GT/s lanes: 1 port: N/A bus-ID: 03:00.0 chip-ID: 8086:15f3 class-ID: 0200
Device-1: Intel AX211 Bluetooth driver: btusb v: 0.8 type: USB rev: 2.0 speed: 12 Mb/s lanes: 1
mode: 1.1 bus-ID: 1-14:9 chip-ID: 8087:0033 class-ID: e001
Report: btmgmt ID: hci0 rfk-id: 0 state: up address: <filter> bt-v: 5.4 lmp-v: 13 status:
Local Storage: total: 1.82 TiB used: 334.97 GiB (18.0%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 990 PRO 2TB size: 1.82 TiB
fw-rev: 4B2QJXD7 temp: 35.9 C scheme: GPT
ID-1: / raw-size: 1.82 TiB size: 1.82 TiB (100.00%) used: 334.97 GiB (18.0%) fs: btrfs
ID-2: /boot/efi raw-size: 300 MiB size: 299.4 MiB (99.80%) used: 664 KiB (0.2%) fs: vfat
ID-3: /home raw-size: 1.82 TiB size: 1.82 TiB (100.00%) used: 334.97 GiB (18.0%) fs: btrfs
ID-4: /var/log raw-size: 1.82 TiB size: 1.82 TiB (100.00%) used: 334.97 GiB (18.0%) fs: btrfs
ID-5: /var/tmp raw-size: 1.82 TiB size: 1.82 TiB (100.00%) used: 334.97 GiB (18.0%) fs: btrfs
ID-1: swap-1 type: zram size: 31.11 GiB used: 0 KiB (0.0%) priority: 100 comp: zstd
System Temperatures: cpu: 41.0 C mobo: 36.0 C
Memory: total: 32 GiB note: est. available: 31.11 GiB used: 4.02 GiB (12.9%)
Processes: 519 Power: uptime: 4m states: freeze,mem,disk suspend: deep avail: s2idle wakeups: 0
hibernate: platform avail: shutdown, reboot, suspend, test_resume image: 12.41 GiB
services: org_kde_powerdevil, power-profiles-daemon, upowerd Init: systemd v: 258
Packages: pm: pacman pkgs: 1833 libs: 502 tools: octopi,paru Compilers: clang: 21.1.4
gcc: 15.2.1 Client: Unknown Client: electron inxi: 3.3.39
Garuda (2.11.1-1):
System install date: 2025-09-25
Garuda release: 250916
Last full system update: 2025-11-03
Relevant software: snapper NetworkManager dracut nvidia-utils nvidia-open garuda-hardware-profile-standard garuda-hardware-profile-standard-x11
24/25 checks run in 0.63 seconds ⌛
Powered by garuda-health 🦅
--- HIGH ---
- Nvidia kernel module is not loaded
- Nvidia kernel module is not installed for the following kernels: linux-mainline
--- INFO ---
- Nvidia drivers are installed, but no hardware profile is active (fix available)
This is what it is trying to install currently:
Detecting hardware...
Detected GPU: Product: Intel Corporation Raptor Lake-S GT1 UHD Graphics 770, PCI ID: 00:02.0, Vendor ID: 8086
Detected GPU: Product: NVIDIA Corporation GB205 GeForce RTX 5070, PCI ID: 01:00.0, Vendor ID: 10de
NVIDIA GPU detected, added: garuda-hardware-profile-nvidia.
Installing packages: garuda-hardware-profile-nvidia
resolving dependencies...
:: nvidia-open-dkms-580.95.05-1 and nvidia-open-580.95.05-8 are in conflict. Remove nvidia-open?
