Hi
I am working through an issue that I am not sure what the root cause is. I have installed Garuda and everything is working very well except for when I return after the system has been sitting. It seems to be in a tight loop because the system is on, fans running, not responding to anything but a forced shutdown. These are some of my tests so far:
- I manually tested suspend and hibernate and they work well.
- I installed the KDE multimedia and GNOME versions with the same hang.
- This machine runs fine with Debian 10 and Ubuntu. I retested Ubuntu and it is fine.
- I updated the BIOS and retested both Garuda installations with the same result.
I don't know exactly what log file to look into but I suspect it is something to do with my system and the zen kernel. Just a guess.
Are there any thoughts on what to try next to figure this out? If it is meaningful, my motherboard is a supermicro C7Z170-m with a Radeon WX 5100 graphics card.
