Garuda gets stuck at Loading initial ramdisk even in recovery mode
When I install Garuda, the live distro works fine with both free and proprietary drivers. I do have NVIDIA GTX-1660ti and Intel UHD graphics. However, after the first mandatory update, I cannot even boot. I get stuck at 'Loading initial ramdisk'. The problem is that I cannot even get into the recovery mode, I see the same problem if I try to get into the recovery mode. I have seen others complaining the same, but they all could get into recovery mode to be able to do something.
garuda-inxi from the live-distro with the proprietary driver enabled.
╭─garuda@garuda in ~ as 🧙 took 1m5s
 ╰─λ sudo garuda-inxi
    misobasedir=garuda root=miso:LABEL=GARUDA_GNOME_RAPTOR quiet
    systemd.show_status=1 ibt=off driver=nonfree nouveau.modeset=0
  Desktop: GNOME v: 43.5 tk: GTK v: 3.24.37 wm: gnome-shell dm: GDM v: 44.0
  Type: Laptop System: Dell product: G5 5500 v: N/A serial: <filter> Chassis:
    type: 10 serial: <filter>
  Mobo: Dell model: 0DV11C v: A02 serial: <filter> UEFI: Dell v: 1.24.0
    date: 03/14/2023
  ID-1: BAT0 charge: 54.7 Wh (100.0%) condition: 54.7/68.0 Wh (80.5%)
    volts: 15.9 min: 15.2 model: LGC-LGC4.474 DELL JJRRD0C type: Li-poly
    serial: <filter> status: full
  Info: model: Intel Core i7-10750H bits: 64 type: MT MCP arch: Comet Lake
    model-id: 0xA5 (165) stepping: 2 microcode: 0xF4
    L3: 12 MiB desc: 1x12 MiB
  Speed (MHz): avg: 2494 high: 2932 min/max: 800/5000 base/boost: 2673/2600
    ext-clock: 100 MHz cores: 1: 800 2: 2600 3: 2600 4: 2600 5: 2600 6: 2600
    7: 2600 8: 2600 9: 2600 10: 2932 11: 2600 12: 2797 bogomips: 62399
  Device-1: Intel CometLake-H GT2 [UHD Graphics] vendor: Dell driver: i915
    active: DP-1 off: eDP-1 empty: DP-2,HDMI-A-1,HDMI-A-2 bus-ID: 0000:00:02.0
    chip-ID: 8086:9bc4 class-ID: 0300
  Device-2: NVIDIA TU116M [GeForce GTX 1660 Ti Mobile] vendor: Dell
    status: current (as of 2023-03) arch: Turing code: TUxxx
    process: TSMC 12nm FF built: 2018-22 bus-ID: 0000:01:00.0
    chip-ID: 10de:2191 class-ID: 0300
  Device-3: Microdia Integrated_Webcam_HD type: USB driver: uvcvideo
    bus-ID: 1-5:5 chip-ID: 0c45:671f class-ID: 0e02
  Display: server: X.Org v: 21.1.8 with: Xwayland v: 23.1.1
    compositor: gnome-shell driver: X: loaded: modesetting,nvidia
    s-diag: 777mm (30.58")
  Monitor-1: DP-1 pos: primary model: LG (GoldStar) IPS QHD serial: <filter>
    built: 2023 res: 2560x1440 hz: 60 dpi: 123 gamma: 1.2
    max: 2560x1440 min: 640x480
  Monitor-2: eDP-1 note: disabled model: LG Display 0x05e4 built: 2018
    res: 2560x1440 dpi: 142 gamma: 1.2 size: 344x194mm (13.54x7.64")
    missing.
  Device-1: Intel Comet Lake PCH cAVS vendor: Dell
    driver: sof-audio-pci-intel-cnl alternate: snd_hda_intel, snd_soc_skl,
    snd_sof_pci_intel_cnl bus-ID: 0000:00:1f.3 chip-ID: 8086:06c8
    class-ID: 0401
  Device-2: NVIDIA TU116 High Definition Audio vendor: Dell
    driver: snd_hda_intel v: kernel bus-ID: 0000:01:00.1 chip-ID: 10de:1aeb
  API: ALSA v: k6.2.13-zen-1-zen status: kernel-api tools: N/A
  Server-1: PipeWire v: 0.3.70 status: n/a (root, process) with:
  Device-1: Intel Comet Lake PCH CNVi WiFi vendor: Rivet Networks
    driver: iwlwifi v: kernel bus-ID: 0000:00:14.3 chip-ID: 8086:06f0
  Device-2: Realtek vendor: Dell driver: r8169 v: kernel port: 3000
    bus-ID: 0000:3a:00.0 chip-ID: 10ec:2502 class-ID: 0200
  IF: enp58s0 state: down mac: <filter>
  Device-3: Lite-On Dell Wireless Device type: USB
    driver: hid-generic,usbhid bus-ID: 1-2:2 chip-ID: 04ca:00bd class-ID: 0301
    bus-ID: 1-14:8 chip-ID: 8087:0026 class-ID: e001
  Hardware-1: Intel Comet Lake PCH-H RAID driver: intel_nvme_remap v: N/A
    port: 5060 bus-ID: 0000:00:17.0 chip-ID: 8086:06d7 rev: class-ID: 0104
  Local Storage: total: 1011.64 GiB used: 0 KiB (0.0%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Western Digital model: PC SN730
    NVMe WDC 1024GB size: 953.87 GiB block-size: physical: 512 B
    logical: 512 B type: SSD serial: <filter> rev: 11170012 temp: 40.9 C
  SMART: yes health: PASSED on: 38d 5h cycles: 282
    read-units: 46,645,764 [23.8 TB] written-units: 43,435,207 [22.2 TB]
  ID-2: /dev/sda maj-min: 8:0 type: USB vendor: HP model: v236w
    size: 57.77 GiB block-size: physical: 512 B logical: 512 B type: N/A
    serial: <filter> rev: PMAP scheme: MBR
  ID-1: swap-1 type: zram size: 15.39 GiB used: 0 KiB (0.0%) priority: 100
  System Temperatures: cpu: 54.0 C mobo: N/A
  Processes: 297 Uptime: 27m wakeups: 3 Memory: 15.39 GiB
  used: 5.07 GiB (33.0%) Init: systemd v: 253 default: graphical
  tool: systemctl Compilers: gcc: 12.2.1 Packages: pm: pacman pkgs: 1211
  libs: 350 tools: pamac,paru Shell: garuda-inxi (sudo) default: Bash
  v: 5.1.16 running-in: gnome-terminal inxi: 3.3.26
  System install date:     2023-04-10
  Last full system update: 2023-04-10 ↻
  Is partially upgraded:   Yes
  Windows dual boot:       Yes
Maybe you could try switching to the LTS kernel.
Boot to your live USB and use the chroot function in the Garuda Welcome, then:
pacman -S linux-lts linux-lts-headers
Then exit from the chroot, reboot and select the LTS kernel under the GRUB Advanced options sub-menu.
The only thing that works about that is the recovery mode in lts kernel, regular and failsafe boot still gets stuck at the same point. However, booting in the recovery mode does not give a shell, it waits for a long time and then shows an emergency shell with some errors regarding dracut.
The following is the logs it - https://file.io/o9cJjzah5q9x
The last few lines were as follows -
pre.target /run/systemd/generator/systemd-cryptsetup@*.service 2>/dev/null; then
[  194.405351] archlinux dracut-initqueue[486]:     [ -e "/dev/disk/by-uuid/d68ddd16-da61-4ae2-b6a9-96ddbf2b51c3" ]
[  194.405351] archlinux dracut-initqueue[486]: fi"
[  194.410503] archlinux dracut-initqueue[486]: Warning: dracut-initqueue: starting timeout scripts
[  194.922994] archlinux dracut-initqueue[486]: Warning: dracut-initqueue: timeout, still waiting for following initqueue hooks:
[  194.925864] archlinux dracut-initqueue[486]: Warning: /lib/dracut/hooks/initqueue/finished/devexists-\x2fdev\x2fdisk\x2fby-uuid\x2fd68ddd16-da61-4ae2-b6a9-96ddbf2b51c3.sh: "if ! grep -q After=remote-fs-pre.target /run/systemd/generator/systemd-cryptsetup@*.service 2>/dev/null; then
[  194.925864] archlinux dracut-initqueue[486]:     [ -e "/dev/disk/by-uuid/d68ddd16-da61-4ae2-b6a9-96ddbf2b51c3" ]
[  194.925864] archlinux dracut-initqueue[486]: fi"
[  194.930568] archlinux dracut-initqueue[486]: Warning: dracut-initqueue: starting timeout scripts
[  194.930568] archlinux dracut-initqueue[486]: Warning: Could not boot.
[  194.957201] archlinux systemd[1]: Starting Dracut Emergency Shell...
The partition it is complaining about is the root file system of Garuda. Somehow it is not able to access the root filesystem for some reason.
Booting from the stock kernel (installed using pacman -S linux linux-header) and configuring grub actually shows the problem. I can now see that it is forever stuck at loading the root device.
When I get into the dracut emergency shell, I can see the USB device /dev/sda, but I cannot see the nvme device. So, somehow the initramfs is not loading the nvme devices.
Using AHCI instead of RAID in the BIOS boots the system just fine. However that stops Windows from working. Trying to add vmd module using dracut-rebuild fails with the error that vmd module cannot be found or installed.
Maybe you could try these kernel command line options (set according to chapter 3.3)?
https://wiki.archlinux.org/title/Dracut#LVM_/_software_RAID_/_LUKS
That’s right, this is the required setting. From the download page:
Make sure that your device’s SATA controller is set to AHCI mode in your device’s setup utility. Otherwise, the Linux kernel may not be able to detect your drive.
This sounds like an issue with your Windows configuration. I’m not sure why Windows would require your BIOS to be configured for RAID if you are not actually using a RAID setup, however troubleshooting Windows issues is somewhat beyond the scope of this forum.
Even though it is mentioned in the download page, the system did work just fine before the update. So I am still trying to make it work with RAID. Otherwise, I would have to go change the settings in BIOS every time I have to boot into Windows, which is workable. I am pretty sure it would be a lot harder to change Windows settings because of the lack of help. Thanks for the help, I will try the above suggestion. It is just taking me some time.
Apparently, just booting Windows once in safe mode was enough to make it install the AHCI drivers. Problem solved.
