Garuda gaming kde | gpu power spikes
Hi does anyone having such strange power spikes for gpu?
i'm using rx 6700xt, and this behaviour only comes on garuda
what kind of informations i need to provide you guys for helping me out with that
i cannot paste screenshot apparently new users cannot do that
but im getting power spikes even on idle when i just move my mouse cursor power draw from gpu jumps from 6w to 18w, is that normal? i have opened firedragon with few tabs, and again 15-18w,
gpu memoery usage 456hz and jumps from 96hz
voltage on idle jumps from 6mv to 868mv
these spikes occurs every 1-2 seconds
really strange i haven't noticed that when i was using linux mint for that matter
is there anything can be done to lower power usage?
Kernel: 6.2.7-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
root=UUID=6f7982fa-f801-4a9f-a47e-a2cd8f08ee86 rw rootflags=subvol=@
resume=UUID=4fb2a623-f3ae-4757-9e65-4eb2471f1194 loglevel=3
Desktop: KDE Plasma v: 5.27.3 tk: Qt v: 5.15.8 wm: kwin_x11 vt: 1 dm: SDDM
Type: Desktop Mobo: Gigabyte model: B450 AORUS ELITE
serial: <superuser required> UEFI: American Megatrends LLC. v: F65a
date: 02/09/2023
Info: model: AMD Ryzen 7 5700G with Radeon Graphics bits: 64 type: MT MCP
microcode: 0xA50000D
L3: 16 MiB desc: 1x16 MiB
Speed (MHz): avg: 3200 high: 3800 min/max: 1400/4672 boost: disabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 2995 2: 2989
3: 3269 4: 2999 5: 3155 6: 3800 7: 3027 8: 3800 9: 3007 10: 3037 11: 3006
12: 2998 13: 3263 14: 3057 15: 3009 16: 3800 bogomips: 121379
vendor: Sapphire driver: amdgpu v: kernel arch: RDNA-2 code: Navi-2x
lanes: 16 ports: active: DP-2 empty: DP-1,DP-3,HDMI-A-1 bus-ID: 03:00.0
chip-ID: 1002:73df class-ID: 0300
s-diag: 777mm (30.58")
Monitor-1: DP-2 mapped: DisplayPort-1 model: Samsung LC27G5xT
serial: <filter> built: 2021 res: 2560x1440 hz: 60 dpi: 109 gamma: 1.2
max: 2560x1440 min: 720x400
API: OpenGL v: 4.6 Mesa 22.3.6 renderer: AMD Radeon RX 6700 XT (navi22
LLVM 15.0.7 DRM 3.49 6.2.7-zen1-1-zen) direct-render: Yes
gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 03:00.1 chip-ID: 1002:ab28
Device-2: AMD Renoir Radeon High Definition Audio driver: snd_hda_intel
speed: 16 GT/s bus-ID: 0a:00.1 chip-ID: 1002:1637 class-ID: 0403
Device-3: AMD Family 17h/19h HD Audio vendor: Gigabyte
link-max: gen: 4 speed: 16 GT/s bus-ID: 0a:00.6 chip-ID: 1022:15e3
Sound API: ALSA v: k6.2.7-zen1-1-zen running: yes
lanes: 1 port: e000 bus-ID: 06:00.0 chip-ID: 10ec:8168 class-ID: 0200
driver: btusb v: 0.8 bus-ID: 1-9:4 chip-ID: 0a12:0001 class-ID: e001
address: <filter>
Local Storage: total: 931.51 GiB used: 57.45 GiB (6.2%)
lanes: 4 type: SSD serial: <filter> rev: 5B2QGXA7 temp: 32.9 C scheme: GPT
ID-1: / raw-size: 100 GiB size: 100 GiB (100.00%) used: 10.56 GiB (10.6%)
ID-2: /boot/efi raw-size: 4 GiB size: 3.99 GiB (99.80%)
used: 608 KiB (0.0%) fs: vfat dev: /dev/nvme0n1p2 maj-min: 259:2
ID-3: /home raw-size: 811.51 GiB size: 811.51 GiB (100.00%)
used: 46.9 GiB (5.8%) fs: btrfs dev: /dev/nvme0n1p4 maj-min: 259:4
ID-4: /var/log raw-size: 100 GiB size: 100 GiB (100.00%)
used: 10.56 GiB (10.6%) fs: btrfs dev: /dev/nvme0n1p3 maj-min: 259:3
ID-5: /var/tmp raw-size: 100 GiB size: 100 GiB (100.00%)
ID-1: swap-1 type: zram size: 31.22 GiB used: 0 KiB (0.0%) priority: 100
ID-2: swap-2 type: partition size: 16 GiB used: 0 KiB (0.0%) priority: -2
System Temperatures: cpu: 28.6 C mobo: N/A gpu: amdgpu temp: 35.0 C
mem: 34.0 C
Fan Speeds (RPM): N/A gpu: amdgpu fan: 892
Processes: 350 Uptime: 8m wakeups: 0 Memory: 31.22 GiB used: 3 GiB (9.6%)
Init: systemd v: 253 default: graphical tool: systemctl Compilers:
gcc: 12.2.1 Packages: pm: pacman pkgs: 1787 libs: 517 tools: octopi,paru
Shell: fish v: 3.6.0 default: Bash v: 5.1.16 running-in: konsole
inxi: 3.3.25
Garuda (2.6.15-1):
System install date:     2023-06-03
Last full system update: 2023-06-03
Is partially upgraded:   Yes
I have a rx 6700xt and do not have any issues, games run great and temps stay in the mid to high 50s. My power draw knocks between 27 - 30 idling or using a browser , if corectrl is accurate.
your idling high usage maybe because screen refresh rate, try 60hz
