I’m currently using Whoogle from the address bar in FireFox successfully.
I would also like the option to use Searx. Most of the install instructions use docker which I don’t want to use.
Searx seems to have been replaced by Searxng-git. If I remove the app Searx (A Firefox Dependency) can I then replace it with SearxNG and use this as a service and SearXNG from the address bar?
Kernel: 6.12.10-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
Type: Desktop Mobo: MSI model: A68HM-E33 V2 (MS-7721) v: 9.0
UEFI: American Megatrends v: 8.5 date: 11/01/2018
Info: model: AMD Athlon X4 860K bits: 64 type: MCP arch: Steamroller
level: v2 built: 2014 process: GF 28nm family: 0x15 (21) model-id: 0x30 (48)
stepping: 1 microcode: 0x6003106
L1: 256 KiB desc: d-4x16 KiB; i-2x96 KiB L2: 4 MiB desc: 2x2 MiB
Speed (MHz): avg: 3531 min/max: 1700/3700 boost: enabled scaling:
driver: acpi-cpufreq governor: performance cores: 1: 3531 2: 3531 3: 3531
4: 3531 bogomips: 29543
Device-1: Advanced Micro Devices [AMD/ATI] Baffin [Radeon RX 460/560D / Pro
450/455/460/555/555X/560/560X] vendor: PC Partner / Sapphire
active: DP-1,HDMI-A-1 empty: DVI-D-1 bus-ID: 01:00.0 chip-ID: 1002:67ef
class-ID: 0300 temp: 33.0 C
Device-2: Logitech BRIO Ultra HD Webcam driver: snd-usb-audio,uvcvideo
type: USB rev: 2.1 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 2-2:2
chip-ID: 046d:085e class-ID: 0102 serial: <filter>
alternate: fbdev,vesa dri: radeonsi gpu: amdgpu d-rect: 3840x1080
display-ID: 0
Monitor-1: DP-1 pos: primary,left model: Dell S2721H serial: <filter>
built: 2020 res: mode: 1920x1080 hz: 60 scale: 100% (1) dpi: 82 gamma: 1.2
Monitor-2: HDMI-A-1 pos: right model: Dell S2721H serial: <filter>
built: 2022 res: mode: 1920x1080 hz: 60 scale: 100% (1) dpi: 82 gamma: 1.2
glx-v: 1.4 direct-render: yes renderer: AMD Radeon RX 460 Graphics
(radeonsi polaris11 LLVM 19.1.7 DRM 3.59 6.12.10-zen1-1-zen)
device-ID: 1002:67ef memory: 1.95 GiB unified: no display-ID: :1.0
API: Vulkan v: 1.4.303 layers: 4 device: 0 type: discrete-gpu name: AMD
Radeon RX 460 Graphics (RADV POLARIS11) driver: N/A device-ID: 1002:67ef
Device-1: Advanced Micro Devices [AMD] FCH Azalia vendor: Micro-Star MSI
driver: snd_hda_intel v: kernel bus-ID: 00:14.2 chip-ID: 1022:780d
Device-2: Advanced Micro Devices [AMD/ATI] Baffin HDMI/DP Audio [Radeon
RX 550 640SP / 560/560X] vendor: PC Partner / Sapphire
bus-ID: 01:00.1 chip-ID: 1002:aae0 class-ID: 0403
Device-3: Logitech BRIO Ultra HD Webcam driver: snd-usb-audio,uvcvideo
API: ALSA v: k6.12.10-zen1-1-zen status: kernel-api tools: N/A
IF-ID-1: wgpia0 state: unknown speed: N/A duplex: N/A mac: N/A
Local Storage: total: 1.35 TiB used: 583.44 GiB (42.3%)
ID-1: /dev/sda maj-min: 8:0 vendor: Crucial model: CT240M500SSD1
size: 223.57 GiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
tech: SSD serial: <filter> fw-rev: MU05 scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: Crucial model: CT240M500SSD1
model: WD10EALX-009BA0 size: 931.51 GiB block-size: physical: 512 B
logical: 512 B speed: 6.0 Gb/s tech: N/A serial: <filter> fw-rev: 1H15
used: 43.66 GiB (19.6%) fs: btrfs dev: /dev/sdb2 maj-min: 8:18
used: 27.4 MiB (9.1%) fs: vfat dev: /dev/sdb1 maj-min: 8:17
ID-1: swap-1 type: zram size: 15.58 GiB used: 0 KiB (0.0%) priority: 100
comp: zstd avail: lzo-rle,lzo,lz4,lz4hc,deflate,842 max-streams: 4
System Temperatures: cpu: 28.8 C mobo: N/A gpu: amdgpu temp: 34.0 C
Fan Speeds (rpm): N/A gpu: amdgpu fan: 1049
Memory: total: 16 GiB available: 15.58 GiB used: 5.85 GiB (37.6%)
Processes: 257 Power: uptime: 1d 43m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 6.21 GiB services: org_kde_powerdevil,
Packages: pm: pacman pkgs: 1755 libs: 460 tools: octopi,pacseek,paru
Compilers: clang: 19.1.7 gcc: 14.2.1 Shell: garuda-inxi default: Bash
v: 5.2.37 running-in: konsole inxi: 3.3.37
Garuda (2.6.26-1.1):
System install date: 2024-08-28
Last full system update: 2025-01-30
