misobasedir=garuda root=miso:LABEL=GARUDA_DR460NIZED_RAPTOR quiet
systemd.show_status=1 ibt=off driver=free nouveau.modeset=1
Type: Desktop Mobo: Micro-Star model: B450 TOMAHAWK MAX II (MS-7C02) v: 3.0
serial: <superuser required> UEFI: American Megatrends LLC. v: H.A1
date: 03/21/2023
Info: model: AMD Ryzen 5 5600X bits: 64 type: MT MCP arch: Zen 3+ gen: 4
L3: 32 MiB desc: 1x32 MiB
Speed (MHz): avg: 2459 high: 3809 min/max: 2200/4650 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 3700 2: 2200
3: 2200 4: 2200 5: 2202 6: 2200 7: 3809 8: 2199 9: 2200 10: 2200 11: 2200
12: 2200 bogomips: 88795
Device-1: NVIDIA GA104 [GeForce RTX 3060] vendor: PNY driver: nouveau
v: kernel non-free: 530.xx+ status: current (as of 2023-03) arch: Ampere
code: GAxxx process: TSMC n7 (7nm) built: 2020-22 pcie: gen: 3
active: DP-1,DP-3 empty: DP-2,HDMI-A-1 bus-ID: 26:00.0 chip-ID: 10de:2487
compositor: kwin_x11 driver: X: loaded: modesetting,nouveau
alternate: fbdev,nv,vesa dri: nouveau gpu: nouveau display-ID: :0
Screen-1: 0 s-res: 5760x1600 s-dpi: 96 s-size: 1522x423mm (59.92x16.65")
s-diag: 1580mm (62.19")
Monitor-1: DP-1 pos: primary,left model: LG (GoldStar) HDR WQHD
serial: <filter> built: 2020 res: 3840x1600 hz: 60 dpi: 111 gamma: 1.2
size: 880x370mm (34.65x14.57") diag: 952mm (37.5") modes: max: 3840x1600
min: 640x480
Monitor-2: DP-3 pos: right model: Philips PHL 246V5 serial: <filter>
built: 2014 res: 1920x1080 hz: 60 dpi: 92 gamma: 1.2
API: OpenGL v: 4.3 Mesa 23.0.3 renderer: NV174 direct-render: Yes
Device-1: NVIDIA GA104 High Definition Audio vendor: PNY
driver: snd_hda_intel v: kernel bus-ID: 5-1.1:4 chip-ID: 0499:170f pcie:
class-ID: 0103 gen: 3 speed: 8 GT/s lanes: 16 link-max: gen: 4
speed: 16 GT/s bus-ID: 26:00.1 chip-ID: 10de:228b class-ID: 0403
bus-ID: 28:00.4 chip-ID: 1022:1487 class-ID: 0403
Device-3: Yamaha Steinberg UR22mkII type: USB driver: snd-usb-audio
Device-4: Intel USB PnP Sound Device type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 5-2:3 chip-ID: 8086:0808
API: ALSA v: k6.2.13-zen-1-zen status: kernel-api tools: N/A
Device-1: TP-Link UB500 Adapter type: USB driver: btusb v: 0.8 bus-ID: 1-7:2
chip-ID: 2357:0604 class-ID: e001 serial: <filter>
Local Storage: total: 3.65 TiB used: 0 KiB (0.0%)
ID-1: /dev/sda maj-min: 8:0 vendor: Seagate model: ST2000DM008-2FR102
type: HDD rpm: 7200 serial: <filter> rev: 0001 scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: Toshiba model: HDWD120 size: 1.82 TiB
block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s type: HDD
rpm: 7200 serial: <filter> rev: ACF0 scheme: GPT
ID-3: /dev/sdc maj-min: 8:32 type: USB model: SCSI size: 14.96 GiB
block-size: physical: 512 B logical: 512 B type: N/A serial: <filter>
rev: 1.00 scheme: MBR
System Temperatures: cpu: 49.1 C mobo: N/A
Processes: 274 Uptime: 11m wakeups: 0 Memory: 31.27 GiB
used: 3.09 GiB (9.9%) Init: systemd v: 253 default: graphical
tool: systemctl Compilers: gcc: 12.2.1 Packages: pm: pacman pkgs: 1200
libs: 327 tools: octopi,paru Shell: fish v: 3.6.1 default: Bash v: 5.1.16
System install date: 2023-07-01
Last full system update: 2023-07-01 ↻
So I wanted to make nftsfix
to one of my HHDs and it showed no errors, but after garuda-update
error I decided to restart my PC and it doesn't recognize my SSD, which Garuda was installed on. The booting send me directly to BIOS and not on Garuda grub menu. I have a Live Bootable USB with Garuda so I'm writing from there.
There is my:
lsblk
NAME MAJ:MIN RM SIZE RO TYPE MOUNTPOINTS
loop0 7:0 0 15.6M 1 loop /run/miso/sfs/livefs
loop1 7:1 0 440M 1 loop /run/miso/sfs/mhwdfs
loop2 7:2 0 1.2G 1 loop /run/miso/sfs/desktopfs
loop3 7:3 0 699.8M 1 loop /run/miso/sfs/rootfs
sda 8:0 0 1.8T 0 disk
└─sda1 8:1 0 1.8T 0 part
sdb 8:16 0 1.8T 0 disk
└─sdb1 8:17 0 1.8T 0 part
sdc 8:32 1 15G 0 disk
├─sdc1 8:33 1 2.5G 0 part /run/miso/bootmnt
└─sdc2 8:34 1 4M 0 part
zram0 253:0 0 31.3G 0 disk [SWAP]
sudo parted -l
Model: ATA ST2000DM008-2FR1 (scsi)
Disk /dev/sda: 2000GB
Sector size (logical/physical): 512B/4096B
Partition Table: gpt
Disk Flags:
Number Start End Size File system Name Flags
1 1049kB 2000GB 2000GB ntfs msftdata
Model: ATA TOSHIBA HDWD120 (scsi)
Disk /dev/sdb: 2000GB
Disk Flags:
1 32.8kB 2000GB 2000GB ntfs msftdata
Model: SCSI DISK (scsi)
Disk /dev/sdc: 16.1GB
Sector size (logical/physical): 512B/512B
Partition Table: msdos
Disk Flags:
Number Start End Size Type File system Flags
2 2680MB 2684MB 4194kB primary esp
Model: Unknown (unknown)
Disk /dev/zram0: 33.6GB
Sector size (logical/physical): 4096B/4096B
Partition Table: loop
Disk Flags:
Number Start End Size File system Flags
1 0.00B 33.6GB 33.6GB linux-swap(v1)
It doesnt display my SSD at all.
lsblk -f
NAME FSTYPE FSVER LABEL UUID FSAVAIL FSUSE% MOUNTPOINTS
loop0 squashfs 4.0 0 100% /run/miso/sfs/livefs
loop1 squashfs 4.0 0 100% /run/miso/sfs/mhwdfs
loop2 squashfs 4.0 0 100% /run/miso/sfs/desktopfs
loop3 squashfs 4.0 0 100% /run/miso/sfs/rootfs
sda
└─sda1 ntfs 01D8BCEE6D645580
sdb
└─sdb1 ntfs 90C8190FC818F4E6
sdc iso9660 Joliet Extension GARUDA_DR460NIZED_RAPTOR 2023-05-01-21-27-23-00
├─sdc1 iso9660 Joliet Extension GARUDA_DR460NIZED_RAPTOR 2023-05-01-21-27-23-00 0 100% /run/miso/bootmnt
└─sdc2 vfat FAT12 MISO_EFI CC34-06DF
zram0 [SWAP]
Someone can help me?
