Well I guess if you can't figure out a proper solution you could temporarily ignore the package, but that's not really recommended.
Okay, for now I will ignore garauda-common-settings & garuda-kde-settings
Having same issue.
Perhaps someone should contact "Pedro Henrique Lara Campos root@pedrohlc.com". The signature is invalid.
How to update my Garuda? I have fresh install and i want to install something or update all packages.
What i should do?
Here the same. Tried the solutions but nothing works yet. Anyone a workaround ?
There is a way how to ignore this damaged packages, just skip?
The entry for "garuda-common-settings" was outdated in the database, please try again (after -Sy).
It's working i successfully run sudo pacman -Syu!
I just installed Garuda and I am getting the same issue, but with a different package:
retroarch-autoconfig-udev-git-r1862.c1131d5-1-any 79,3 KiB 211 KiB/s 00:00 [----------------------------------------------] 99%
(454/454) checking keys in keyring [----------------------------------------------] 100%
(454/454) checking package integrity [----------------------------------------------] 100%
error: retroarch-autoconfig-udev-git: signature from “Pedro Henrique Lara Campos root@pedrohlc.com” is invalid
:: File /var/cache/pacman/pkg/retroarch-autoconfig-udev-git-r1862.c1131d5-1-any.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
Did you sudo pacman -Syu again?
I did try that multiple times, still the same issue
I am trying to update my system after a fresh install.
I also had same issue with a different package retroarch-autoconfig-udev-git-r1862.c1131d5-1-any.pkg.tar.zst
The things I tried are :
1. Refresh Packman keyring
sudo pacman-key --refresh-keys
2. Install chaotic-keyring (install or upgrade)
sudo pacman -Sy chaotic-keyring
3. Query the Package
command
pacman -Q chaotic-keyring;output
chaotic-keyring 20201229-1
4. Delete the key associated with it, and again populate
sudo pacman-key --delete EF925EA60F33D0CB85C44AD13056513887B78AEB; sudo pacman-key --populate chaotic;
5. Tried same command multiple times.
sudo pacman -Syu;
Result
error: retroarch-autoconfig-udev-git: signature from "Pedro Henrique Lara Campos <root@pedrohlc.com>" is invalid :: File /var/cache/pacman/pkg/retroarch-autoconfig-udev-git-r1862.c1131d5-1-any.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)). Do you want to delete it? [Y/n] n error: failed to commit transaction (invalid or corrupted package) Errors occurred, no packages were upgraded
I am unable to solve it, please help.
answer y
then try again
with
sudo pacman -Syyuu
Thank you so much ! This worked !!
And thank you for your so fast reply !
Hi, I am also having the same issue with a new install, with file garuda-setup-assistant-r24.1ab4be6-1-any.pkg.tar.zst. I have tried all the suggestions in this post, but keep coming back to the same error.
Please open new thread this one is solved, read
and post
inxi -Fxxxza
and
