Garuda-common-settings and ipw2100-fw are in conflict
$ update
:: garuda-common-settings and ipw2100-fw are in conflict. Remove ipw2100-fw? [y/N]
Yes or no?
$ garuda-inxi
  Kernel: 5.19.8-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
    root=UUID=57e701a9-b2cf-42d5-bf91-e80b2c177b3a rw rootflags=subvol=@
  Desktop: sway v: 1.7 info: waybar vt: 1 dm: greetd Distro: Garuda Linux
  Type: Laptop System: Hewlett-Packard product: HP Compaq 6720s v: F.0A
  Mobo: Hewlett-Packard model: 30D8 v: KBC Version 83.0E
    serial: <superuser required> BIOS: Hewlett-Packard v: 68MDU Ver. F.0A
    date: 04/14/2008
  ID-1: C23B charge: 40.6 Wh (96.7%) condition: 42.0/42.0 Wh (100.0%)
    volts: 12.4 min: 10.8 model: Hewlett-Packard Primary type: Li-ion
  Info: model: Intel Core2 Duo T5670 bits: 64 type: MCP arch: Core2 Merom
    built: 2006-09 process: Intel 65nm family: 6 model-id: 0xF (15)
    stepping: 0xD (13) microcode: 0xA4
  Topology: cpus: 1x cores: 2 smt: <unsupported> cache: L1: 128 KiB
    desc: d-2x32 KiB; i-2x32 KiB L2: 2 MiB desc: 1x2 MiB
  Speed (MHz): avg: 799 high: 800 min/max: 800/1801 boost: enabled scaling:
    driver: acpi-cpufreq governor: schedutil cores: 1: 800 2: 798
    bogomips: 7181
  Flags: ht lm nx pae sse sse2 sse3 ssse3
  Type: mds status: Vulnerable: Clear CPU buffers attempted, no microcode;
    SMT disabled
  Type: spectre_v2 mitigation: Retpolines, STIBP: disabled, RSB filling,
    PBRSB-eIBRS: Not affected
  Device-1: Intel Mobile GME965/GLE960 Integrated Graphics
    vendor: Hewlett-Packard driver: i915 v: kernel arch: Gen-4
    process: Intel 65n built: 2006-07 ports: active: LVDS-1
    empty: SVIDEO-1,VGA-1 bus-ID: 00:02.0 chip-ID: 8086:2a12 class-ID: 0300
  Display: wayland server: Xwayland v: 22.1.3 compositor: sway v: 1.7
    driver: gpu: i915 display-ID: 1
  Monitor-1: LVDS-1 model: Seiko Epson 0x4e45 built: 2008 res: 1280x800
    hz: 60 dpi: 98 gamma: 1.2 scale: 1 size: 331x207mm (13.03x8.15")
    diag: 390mm (15.4") ratio: 16:10 modes: 1280x800
  Message: Wayland GBM/EGL data currently not available.
  Device-1: Intel 82801H HD Audio vendor: Hewlett-Packard
    driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:284b
  Sound Server-1: ALSA v: k5.19.8-zen1-1-zen running: yes
  Sound Server-4: PipeWire v: 0.3.57 running: yes
  Device-1: Intel 82562GT 10/100 Network vendor: Hewlett-Packard
    driver: e1000e v: kernel port: 4020 bus-ID: 00:19.0 chip-ID: 8086:10c4
  Device-2: Realtek RTL8188EUS 802.11n Wireless Network Adapter type: USB
    driver: r8188eu bus-ID: 2-1:2 chip-ID: 0bda:8179 class-ID: 0000
  IF: wlp0s29f7u1 state: up mac: <filter>
  Device-1: HP Bluetooth 2.0 Interface [Broadcom BCM2045] type: USB
    driver: btusb v: 0.8 bus-ID: 3-1:2 chip-ID: 03f0:171d class-ID: fe01
  Device-2: Cambridge Silicon Radio Bluetooth Dongle (HCI mode) type: USB
    driver: btusb v: 0.8 bus-ID: 4-2:2 chip-ID: 0a12:0001 class-ID: e001
  Report: ID: hci1 rfk-id: 2 state: up address: N/A
  Local Storage: total: 223.57 GiB used: 208.63 GiB (93.3%)
  ID-1: /dev/sda maj-min: 8:0 vendor: Kingston model: SA400S37240G
    size: 223.57 GiB block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
    type: SSD serial: <filter> rev: B1D1 scheme: MBR
  ID-1: / raw-size: 223.57 GiB size: 223.57 GiB (100.00%) used: 208.63 GiB
    (93.3%) fs: btrfs dev: /dev/sda1 maj-min: 8:1
  ID-2: /home raw-size: 223.57 GiB size: 223.57 GiB (100.00%) used: 208.63
    GiB (93.3%) fs: btrfs dev: /dev/sda1 maj-min: 8:1
  ID-3: /var/log raw-size: 223.57 GiB size: 223.57 GiB (100.00%) used: 208.63
  ID-4: /var/tmp raw-size: 223.57 GiB size: 223.57 GiB (100.00%) used: 208.63
  Alert: No swap data was found.
  System Temperatures: cpu: 51.0 C mobo: N/A
  Processes: 184 Uptime: 24m wakeups: 1 Memory: 3.82 GiB used: 1.39 GiB
  (36.4%) Init: systemd v: 251 default: graphical tool: systemctl
  Compilers: gcc: 12.2.0 clang: 14.0.6 Packages: pacman: 1697 lib: 394
  flatpak: 0 Shell: nu running-in: xfce4-terminal inxi: 3.3.20
Garuda (2.6.7-1):
  System install date:     2021-12-28
  Last full system update: 2022-09-15
Answer: Yes
That is an old intel wireless driver for hardware you don't have that was dropped from the repo.
