I opened up Garuda Boot Options
from the Welcome manager
and changed the Boot to
to the lts kernel to test some things out. and then clicked on apply, then a window shows up with a progress bar with the title Updating configuration, please wait
, and has been stuck on that for about an hour now. The progress keeps on completing, again and again, it may be just a loading animation. I can't close the window and am not sure if it's safe to reboot while this is going on. Help is highly appreciated, thank you.
Read
please
and post
inxi -Fxxxza
as text!
and
You can restart and from GRUB, you can choose desired kernel.
(Provided that you installed kernel "correctly")
mhwd-kernel -li
Currently running: 5.11.2-zen1-1-zen (linux-zen)
The following kernels are installed in your system:
local/linux-zen 5.11.2.zen1-1
Sorry for the shabby question, I'm just a little panicked.
╰─λ inxi -Fxxxza
System: Kernel: 5.11.2-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 10.2.1
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-zen root=UUID=f938f9e8-ba16-4db3-8e2a-b867ee6bd539 rw
rootflags=subvol=@ quiet
cryptdevice=UUID=4be08c29-a32d-4820-bb71-dcb882cb4cb0:luks-4be08c29-a32d-4820-bb71-dcb882cb4cb0
root=/dev/mapper/luks-4be08c29-a32d-4820-bb71-dcb882cb4cb0 splash rd.udev.log_priority=3 vt.global_cursor_default=0
systemd.unified_cgroup_hierarchy=1 resume=/dev/mapper/luks-28d7df0f-c80b-4502-8846-b6cbf2e12e99 loglevel=3
Desktop: KDE Plasma 5.21.2 tk: Qt 5.15.2 info: latte-dock wm: kwin_x11 dm: SDDM Distro: Garuda Linux
Machine: Type: Laptop System: HP product: HP Pavilion Gaming Laptop 15-dk0xxx v: Type1ProductConfigId serial: <filter>
Chassis: type: 10 serial: <filter>
Mobo: HP model: 85FC v: 42.42 serial: <filter> UEFI: Insyde v: F.33 date: 07/16/2020
Battery: ID-1: BAT1 charge: 45.9 Wh condition: 45.7/52.5 Wh (87%) volts: 12.9/11.6 model: Hewlett-Packard PABAS0241231
type: Li-ion serial: <filter> status: Unknown
CPU: Info: Quad Core model: Intel Core i5-9300H bits: 64 type: MT MCP arch: Kaby Lake note: check family: 6
model-id: 9E (158) stepping: A (10) microcode: DE L2 cache: 8 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 38400
Speed: 3828 MHz min/max: 800/4100 MHz Core speeds (MHz): 1: 3828 2: 3975 3: 3509 4: 3911 5: 4000 6: 3532 7: 3933
8: 3844
Graphics: Device-1: Intel UHD Graphics 630 vendor: Hewlett-Packard driver: i915 v: kernel bus ID: 00:02.0 chip ID: 8086:3e9b
class ID: 0300
Device-2: NVIDIA TU117M [GeForce GTX 1650 Mobile / Max-Q] vendor: Hewlett-Packard driver: nvidia v: 460.56
alternate: nouveau,nvidia_drm bus ID: 01:00.0 chip ID: 10de:1f91 class ID: 0300
Device-3: Quanta HP Wide Vision HD Camera type: USB driver: uvcvideo bus ID: 1-5:3 chip ID: 0408:5300
class ID: 0e02 serial: <filter>
Display: x11 server: X.Org 1.20.10 compositor: kwin_x11 driver: loaded: intel,nvidia unloaded: modesetting,nouveau
alternate: fbdev,nv,vesa display ID: :0 screens: 1
Screen-1: 0 s-res: 3840x1080 s-dpi: 96 s-size: 1013x285mm (39.9x11.2") s-diag: 1052mm (41.4")
Monitor-1: eDP1 res: 1920x1080 hz: 60 dpi: 143 size: 340x190mm (13.4x7.5") diag: 389mm (15.3")
Monitor-2: HDMI-1-0 res: 1920x1080 hz: 60 dpi: 70 size: 700x390mm (27.6x15.4") diag: 801mm (31.5")
OpenGL: renderer: Mesa Intel UHD Graphics 630 (CFL GT2) v: 4.6 Mesa 20.3.4 direct render: Yes
Audio: Device-1: Intel Cannon Lake PCH cAVS vendor: Hewlett-Packard driver: snd_hda_intel v: kernel
alternate: snd_soc_skl,snd_sof_pci bus ID: 00:1f.3 chip ID: 8086:a348 class ID: 0403
Sound Server: ALSA v: k5.11.2-zen1-1-zen
Network: Device-1: Intel Wireless-AC 9560 [Jefferson Peak] driver: iwlwifi v: kernel port: 5000 bus ID: 00:14.3
chip ID: 8086:a370 class ID: 0280
Device-2: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: Hewlett-Packard driver: r8169 v: kernel
port: 3000 bus ID: 02:00.0 chip ID: 10ec:8168 class ID: 0200
Device-3: Lite-On Dell Wireless Device type: USB driver: hid-generic,usbhid bus ID: 1-3:2 chip ID: 04ca:00ac
class ID: 0301
Bluetooth: Device-1: Intel Bluetooth 9460/9560 Jefferson Peak (JfP) type: USB driver: btusb v: 0.8 bus ID: 1-14:4
chip ID: 8087:0aaa class ID: e001
Message: Required tool hciconfig not installed. Check --recommends
RAID: Hardware-1: Intel 82801 Mobile SATA Controller [RAID mode] driver: ahci v: 3.0 port: 5060 bus ID: 00:17.0
chip ID: 8086.282a rev: 10
Drives: Local Storage: total: 961.79 GiB used: 39.3 GiB (4.1%)
ID-1: /dev/sda maj-min: 8:0 vendor: Western Digital model: WD10SPZX-60Z10T0 size: 931.51 GiB block size:
physical: 4096 B logical: 512 B speed: 6.0 Gb/s rotation: 5400 rpm serial: <filter> rev: 1A04 scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 type: USB vendor: Generic model: Flash Disk size: 30.27 GiB block size:
physical: 512 B logical: 512 B rotation: SSD serial: <filter> rev: 8.07 scheme: MBR
Partition: ID-1: / raw size: 922.45 GiB size: 922.45 GiB (100.00%) used: 39.29 GiB (4.3%) fs: btrfs dev: /dev/dm-0
maj-min: 254:0 mapped: luks-4be08c29-a32d-4820-bb71-dcb882cb4cb0
ID-2: /boot/efi raw size: 260 MiB size: 256 MiB (98.45%) used: 682 KiB (0.3%) fs: vfat dev: /dev/sda1 maj-min: 8:1
ID-3: /home raw size: 922.45 GiB size: 922.45 GiB (100.00%) used: 39.29 GiB (4.3%) fs: btrfs dev: /dev/dm-0
ID-4: /var/log raw size: 922.45 GiB size: 922.45 GiB (100.00%) used: 39.29 GiB (4.3%) fs: btrfs dev: /dev/dm-0
ID-5: /var/tmp raw size: 922.45 GiB size: 922.45 GiB (100.00%) used: 39.29 GiB (4.3%) fs: btrfs dev: /dev/dm-0
ID-1: swap-1 type: partition size: 8.8 GiB used: 0 KiB (0.0%) priority: -2 dev: /dev/dm-1 maj-min: 254:1
mapped: luks-28d7df0f-c80b-4502-8846-b6cbf2e12e99
ID-2: swap-2 type: zram size: 974.2 MiB used: 123.4 MiB (12.7%) priority: 32767 dev: /dev/zram0
ID-3: swap-3 type: zram size: 974.2 MiB used: 124.7 MiB (12.8%) priority: 32767 dev: /dev/zram1
ID-4: swap-4 type: zram size: 974.2 MiB used: 123.8 MiB (12.7%) priority: 32767 dev: /dev/zram2
ID-5: swap-5 type: zram size: 974.2 MiB used: 119.4 MiB (12.3%) priority: 32767 dev: /dev/zram3
ID-6: swap-6 type: zram size: 974.2 MiB used: 132.2 MiB (13.6%) priority: 32767 dev: /dev/zram4
ID-7: swap-7 type: zram size: 974.2 MiB used: 124.4 MiB (12.8%) priority: 32767 dev: /dev/zram5
ID-8: swap-8 type: zram size: 974.2 MiB used: 123.5 MiB (12.7%) priority: 32767 dev: /dev/zram6
ID-9: swap-9 type: zram size: 974.2 MiB used: 128.6 MiB (13.2%) priority: 32767 dev: /dev/zram7
Sensors: System Temperatures: cpu: 52.0 C mobo: 29.8 C
Info: Processes: 308 Uptime: 12h 43m wakeups: 1 Memory: 7.61 GiB used: 5.54 GiB (72.8%) Init: systemd v: 247 Compilers:
gcc: 10.2.0 clang: 11.1.0 Packages: pacman: 1726 lib: 375 Shell: fish v: 3.1.2 running in: konsole inxi: 3.3.01
╰─λ mhwd-kernel -li
local/linux-lts 5.10.19-1
So, I just reboot with this thing running?
Just making sure.
Yep, reboot and in grub, go to advanced options and select lts.
Unfortunately that's a bug with Grub when using btrfs that doesn't look like it's going to get resolved by the grub devs any time soon.
The only way to work around the current limitation is to install a separate boot partition in ext2 or ext3 format at Garuda installation.
Thanks man, I can now sleep peacefully
Good night
