Garuda boot Options issues
I want to remove 5s waiting time when booting. But Garuda boot is not opening. Can I do it with terminal?
I also want to change the background image while booting? Is it possible?
Yes you can do it in a terminal window or the easy way is do it with garuda boot options
Yah . Thats knows as splash screen ( Plymoth ) . Go to settings , select Startup (*u will find full name of the settings) , there will be login splash screen & many .. choose from theme or download custom from button below.
For boot screen , go to Garuda Assistant (Red Colour) ==> Garud Boot Options ==> and then select theme like spinner , line bar, solar flare etc
Finaly click apply
@TilliDie but how can I do it?
Thank you @nalisan007
As @nalisan007 has put or goto etc/defaults/grub and alter there and make sure you update grub after
Why don't you search on google? Or better Whoogle :slightly_smiling_face:
