hey, i installed garuda blackarch recently but on blackarch section in applications launcher there's nothing but autopsy only.
how can i show blackarch tools?
Most of the tools are CLI-based, which you should know if you're using the BlackArch tools.
i know but what about gui tools?
Which GUI tools?
This is the ISO profile for the BlackArch edition.
If you scroll to the Blackarch section you'll find the tools included.
Then, again, BlackArch is targeted to experienced users. You should be able to understand what you need and how to launch it.
see this https://imgur.com/a/mTMwlJh is that normal?
Nobody will open links, not to imgur either.
can not upload images here?
i know how to launch but why it's not add to menu by default like kali ?
Please read,
