Garuda Assistant Errors on Hyprland
Hi,
I’m getting a couple of issues with Garuda Assistant on Garuda Hyprland. If I click on any of the options (such as “Refresh mirrorlist”), the command is run twice, and both times I fail to authenticate:
reflector-simple: info: reading file /etc/reflector-simple-tool.conf
reflector-simple: info: reading file /etc/reflector-simple.conf
==== AUTHENTICATING FOR org.freedesktop.policykit.exec ====
Authentication is needed to run `/usr/bin/bash -c cp /etc/pacman.d/mirr ... p.XP9S5L1Jqi /etc/pacman.d/mirrorlist' as the super user
Authenticating as: Daniel Hobbs (daniel)
Password:
polkit-agent-helper-1: error response to PolicyKit daemon: GDBus.Error:org.freedesktop.PolicyKit1.Error.Failed: No session for cookie
==== AUTHENTICATION FAILED ====
Error executing command as another user: Not authorized
This incident has been reported.
Press enter to exit
Where would I need to look to start investigating these issues?
    root=UUID=300417e8-e881-4642-a3d4-15d6c2fcfc95 rw rootflags=subvol=@
    quiet loglevel=3 nvidia_drm.modeset=1 ibt=off
  Type: Desktop System: Micro-Star product: MS-7B51 v: 1.0
  Mobo: Micro-Star model: MPG Z390 GAMING PLUS (MS-7B51) v: 1.0
    serial: <superuser required> UEFI: American Megatrends v: 1.80
    date: 12/26/2019
  Device-1: hidpp_battery_0 model: Logitech M585/M590 Multi-Device Mouse
  Info: model: Intel Core i5-9600KF bits: 64 type: MCP arch: Coffee Lake
    model-id: 0x9E (158) stepping: 0xD (13) microcode: 0xFA
    desc: 1x9 MiB
  Speed (MHz): avg: 3930 high: 4595 min/max: 800/4600:4700 scaling:
    driver: intel_pstate governor: performance cores: 1: 4595 2: 4547 3: 4500
    4: 4567 5: 800 6: 4574 bogomips: 44398
  Device-1: NVIDIA TU116 [GeForce GTX 1660 Ti] vendor: Micro-Star MSI
    driver: nvidia v: 535.113.01 alternate: nouveau,nvidia_drm non-free: 535.xx+
    status: current (as of 2023-09) arch: Turing code: TUxxx
    process: TSMC 12nm FF built: 2018-22 pcie: gen: 1 speed: 2.5 GT/s
    lanes: 16 link-max: gen: 3 speed: 8 GT/s ports: active: none off: HDMI-A-1
    empty: DP-1,DP-2,DP-3 bus-ID: 01:00.0 chip-ID: 10de:2182 class-ID: 0300
  Device-2: Logitech Webcam C270 driver: snd-usb-audio,uvcvideo type: USB
    rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-2:3 chip-ID: 046d:0825
    compositor: Hyprland driver: X: loaded: nvidia unloaded: modesetting,nouveau
    alternate: fbdev,nv,vesa gpu: nvidia,nvidia-nvswitch display-ID: 1
  Monitor-1: HDMI-A-1 model: MSI MAG342CQRV serial: <filter> built: 2021
    res: 3440x1440 hz: 100 dpi: 111 gamma: 1.2 scale: 1
    size: 797x333mm (31.38x13.11") diag: 856mm (33.7") modes: max: 3440x1440
    min: 640x480
  API: Vulkan v: 1.3.269 layers: 9 device: 0 type: discrete-gpu name: NVIDIA
    GeForce GTX 1660 Ti driver: nvidia v: 535.113.01 device-ID: 10de:2182
    16.0.6 256 bits) driver: mesa llvmpipe v: 23.2.1-arch1.2 (LLVM 16.0.6)
  Device-2: NVIDIA TU116 High Definition Audio vendor: Micro-Star MSI
  Device-3: C-Media Blue Snowball driver: hid-generic,snd-usb-audio,usbhid
    type: USB rev: 1.1 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-1:2
    chip-ID: 0d8c:0005 class-ID: 0300 serial: <filter>
  Device-4: Logitech Webcam C270 driver: snd-usb-audio,uvcvideo type: USB
  Server-2: PipeWire v: 0.3.83 status: active with: 1: pipewire-pulse
  Device-1: Intel Ethernet I219-V vendor: Micro-Star MSI driver: e1000e
    v: kernel port: N/A bus-ID: 00:1f.6 chip-ID: 8086:15bc class-ID: 0200
  IF: eno1 state: up speed: 10 Mbps duplex: full mac: <filter>
  Local Storage: total: 3.64 TiB used: 3.17 TiB (87.1%)
  ID-1: /dev/nvme0n1 maj-min: 259:2 vendor: Crucial model: CT1000P2SSD8
    lanes: 4 tech: SSD serial: <filter> fw-rev: P2CR033 temp: 35.9 C
  ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: Crucial model: CT1000P1SSD8
    lanes: 4 tech: SSD serial: <filter> fw-rev: P3CR013 temp: 36.9 C
    model: WD10EZRX-00L4HB0 size: 931.51 GiB block-size: physical: 4096 B
    fw-rev: 1A01 scheme: MBR
  ID-4: /dev/sdb maj-min: 8:16 vendor: Toshiba model: HDWD110
    tech: HDD rpm: 7200 serial: <filter> fw-rev: A8J0 scheme: MBR
  ID-1: / raw-size: 46.57 GiB size: 46.57 GiB (100.00%)
    used: 23.02 GiB (49.4%) fs: btrfs dev: /dev/nvme0n1p5 maj-min: 259:7
  ID-2: /boot/efi raw-size: 619 MiB size: 617.8 MiB (99.80%)
    used: 50.7 MiB (8.2%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:3
  ID-3: /home raw-size: 46.57 GiB size: 46.57 GiB (100.00%)
  ID-4: /var/log raw-size: 46.57 GiB size: 46.57 GiB (100.00%)
  ID-5: /var/tmp raw-size: 46.57 GiB size: 46.57 GiB (100.00%)
  ID-1: swap-1 type: zram size: 31.28 GiB used: 512 KiB (0.0%) priority: 100
    comp: zstd avail: lzo,lzo-rle,lz4,lz4hc,842 max-streams: 6 dev: /dev/zram0
  System Temperatures: cpu: 39.5 C pch: 48.0 C mobo: 31.0 C
  Fan Speeds (rpm): fan-1: 0 fan-2: 661 fan-3: 825 fan-4: 772 fan-5: 791
    fan-6: 834 fan-7: 0
  Processes: 279 Uptime: 57m wakeups: 2 Memory: total: 32 GiB
  available: 31.28 GiB used: 4.52 GiB (14.5%) Init: systemd v: 254
  Packages: pm: pacman pkgs: 1778 libs: 473 tools: paru,trizen,yay Shell: fish
  v: 3.6.1 running-in: foot inxi: 3.3.30
Garuda (2.6.17-1):
  System install date:     2023-10-12
  Last full system update: 2023-11-02
Have you modified ~/.config/hypr/hyprland.conf? Double-check you still have this line:
exec-once =/usr/lib/polkit-gnome/polkit-gnome-authentication-agent-1
Thanks @BluishHumility - that fixed the authentication issue!
