Gamemode vs falcond
Hi, I am new, I installed garda a few days ago.
Is it possible to install and set falcond and scx_sched instead of gamemode, like in PikaOS? Does anyone use this ?
You seem to have “overlooked” the template when you opened this thread.
To get help in this forum, it is necessary to post the terminal output of garuda-inxi.
Sorry, I read “the template,” but I didn’t think my “garuda-inxi” would be necessary for my question. Here it is:
krzysztof@garuda in ~
󰛓 ❯ garuda-inxi
Kernel: 6.15.7-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 15.1.1
root=UUID=aecb9d74-cb67-450e-bfa3-eefc6b40f212 rw rootflags=subvol=@
Desktop: KDE Plasma v: 6.4.3 tk: Qt v: N/A info: frameworks v: 6.16.0
Type: Laptop System: LENOVO product: 83GS v: LOQ 15IAX9
serial: <superuser required> Chassis: type: 10 v: LOQ 15IAX9
Mobo: LENOVO model: LNVNB161216 v: No DPK serial: <superuser required>
part-nu: LENOVO_MT_83GS_BU_idea_FM_LOQ 15IAX9 uuid: <superuser required>
UEFI: LENOVO v: NECN44WW date: 04/01/2025
ID-1: BAT1 charge: 23.4 Wh (38.4%) condition: 61.0/60.0 Wh (101.7%)
power: 20.9 W volts: 14.5 min: 15.4 model: BYD L23B4PK4 type: Li-poly
serial: <filter> status: discharging cycles: 66
Info: model: 12th Gen Intel Core i5-12450HX bits: 64 type: MST AMCP
microcode: 0x3A
Topology: cpus: 1x dies: 1 clusters: 5 cores: 8 threads: 12 mt: 4 tpc: 2
st: 4 smt: enabled cache: L1: 704 KiB desc: d-4x32 KiB, 4x48 KiB; i-4x32
KiB, 4x64 KiB L2: 7 MiB desc: 4x1.2 MiB, 1x2 MiB L3: 12 MiB desc: 1x12 MiB
Speed (MHz): avg: 800 min/max: 800/4400:3100 scaling: driver: intel_pstate
8: 800 9: 800 10: 800 11: 800 12: 800 bogomips: 64512
Device-1: Intel Alder Lake-S [UHD Graphics] vendor: Lenovo driver: i915
v: kernel alternate: xe arch: Xe process: Intel 10nm built: 2020-21 ports:
active: eDP-2 empty: DP-2, DP-3, HDMI-A-2, HDMI-A-3, HDMI-A-4, HDMI-A-5
bus-ID: 00:02.0 chip-ID: 8086:468b class-ID: 0300
Device-2: NVIDIA GA107BM / GN20-P0-R-K2 [GeForce RTX 3050 6GB Laptop GPU]
vendor: Lenovo driver: nvidia v: 575.64.03 alternate: nouveau,nvidia_drm
gen: 4 speed: 16 GT/s lanes: 8 link-max: lanes: 16 ports: active: none
empty: DP-1,HDMI-A-1,eDP-1 bus-ID: 01:00.0 chip-ID: 10de:25ec
Device-3: Bison Integrated Camera driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-6:2 chip-ID: 5986:216a
class-ID: 0e02
Display: x11 server: X.Org v: 21.1.18 with: Xwayland v: 24.1.8
Monitor-1: eDP-2 model-id: CSW 0x150f serial: <filter> built: 2023
res: N/A dpi: 142 gamma: 1.2 size: 344x193mm (13.54x7.6")
surfaceless: drv: nvidia x11: drv: iris inactive: wayland,device-2
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: intel mesa v: 25.1.6-arch1.1
glx-v: 1.4 direct-render: yes renderer: Mesa Intel UHD Graphics (ADL-S
GT0.5) device-ID: 8086:468b memory: 14.97 GiB unified: yes
API: Vulkan v: 1.4.321 layers: 13 device: 0 type: integrated-gpu
name: Intel UHD Graphics (ADL-S GT0.5) driver: mesa intel v: 25.1.6-arch1.1
device-ID: 8086:468b surfaces: N/A device: 1 type: discrete-gpu
name: NVIDIA GeForce RTX 3050 6GB Laptop GPU driver: nvidia v: 575.64.03
device-ID: 10de:25ec surfaces: N/A device: 2 type: cpu name: llvmpipe
(LLVM 20.1.8 256 bits) driver: mesa llvmpipe v: 25.1.6-arch1.1 (LLVM
Device-1: Intel Alder Lake-S HD Audio vendor: Lenovo driver: snd_hda_intel
chip-ID: 8086:7ad0 class-ID: 0401
Device-2: NVIDIA GA107 High Definition Audio vendor: Lenovo
link-max: lanes: 16 bus-ID: 01:00.1 chip-ID: 10de:2291 class-ID: 0403
API: ALSA v: k6.15.7-zen1-1-zen status: kernel-api tools: N/A
port: 4000 bus-ID: 07:00.0 chip-ID: 10ec:8168 class-ID: 0200
Device-2: Realtek RTL8852BE PCIe 802.11ax Wireless Network vendor: Lenovo
driver: rtw89_8852be v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
port: 3000 bus-ID: 08:00.0 chip-ID: 10ec:b852 class-ID: 0280
Device-3: ASUSTek TUF GAMING M4 WIRELESS driver: hid-generic,usbhid
type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-9:4
chip-ID: 0b05:19f4 class-ID: 0300
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-14:5 chip-ID: 0bda:4853
Report: bt-adapter note: tool can't run ID: hci0 rfk-id: 2 state: down
bt-service: disabled rfk-block: hardware: no software: yes address: N/A
Local Storage: total: 931.51 GiB used: 109.84 GiB (11.8%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Kingston model: SNV3S1000G
lanes: 4 tech: SSD serial: <filter> fw-rev: ERFK1N.3 temp: 35.9 C
ID-1: / raw-size: 598.02 GiB size: 598.02 GiB (100.00%)
used: 109.84 GiB (18.4%) fs: btrfs dev: /dev/nvme0n1p5 maj-min: 259:5
ID-2: /boot/efi raw-size: 2 GiB size: 2 GiB (99.80%) used: 620 KiB (0.0%)
fs: vfat dev: /dev/nvme0n1p4 maj-min: 259:4
ID-3: /home raw-size: 598.02 GiB size: 598.02 GiB (100.00%)
ID-4: /var/log raw-size: 598.02 GiB size: 598.02 GiB (100.00%)
ID-5: /var/tmp raw-size: 598.02 GiB size: 598.02 GiB (100.00%)
ID-1: swap-1 type: zram size: 15.32 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 36.8 C mobo: N/A
Memory: total: 16 GiB note: est. available: 15.32 GiB used: 3.04 GiB (19.8%)
Processes: 326 Power: uptime: 6m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 6.05 GiB services: org_kde_powerdevil,
Packages: pm: pacman pkgs: 1423 libs: 458 tools: octopi,paru Compilers:
inxi: 3.3.38
Garuda (2.7.3-2):
System install date:     2025-07-17
Last full system update: 2025-07-23 ↻
I hope everything is okay now?
To be on the safe side ;-), always reboot after update in terminal.
falcond is in the AUR, use pacseek or paru
scx_sched? IDK that “tool”, I have no time for games :smiley:
Get the CachyOS kernel, and scx-scheds. Run boot options, to set CachyOS as the default kernel. Then, you can follow any guide for swapping in LAVD.
No idea about falcond. I question how much you get out of such tweaking utilities, anyway, though, unless you have a 12-16 core AMD X3D CPU.
Thanks a lot for the information :+1:
I understand that scx schedulers cannot be used with the default zen kernel? I used CachyOS for a while some time ago, but so far I haven’t had any performance issues with games on Garuda, so I’m sticking with you guys :grin:
As for falcond, it’s a mechanism similar to gamemode, but it runs automatically (as a systemd daemon) and allows you to create profiles for different programs or games.
Oh, I don’t mean changing the OS. I mean installing them from the Chaotic-AUR, on Garuda (use paru, yay, or Octopi (GUI)). Once both linux-cachyos and scx-scheds are installed, you should be able to quickly follow the CachyOS docs, to get it set up. Then use the boot options tool to easily make the CachyOS kernel the default.
I don’ mean changing the OS too :grinning_face_with_smiling_eyes: I mean I have already used the cachy kernel together with the whole it’s „original environment” (CachyOS) a few months ago. Although I do not hide that I had the dilemma of choosing Garuda or going back to CachyOS.
My attention was drawn to the look of the new Mokka release and I decided to swap Fedora 42 KDE for Garuda. :smiling_face_with_three_hearts::+1:
Never use Octopi for installing packages. It has often broken things. Use it only for searching.
Don’t know who mentioned it but I’m using pacseek now, I find it much better than Octopi
