Hello.
inxi -Faz
System: Kernel: 5.14.7-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-zen root=UUID=25bdb391-e52a-4575-8f27-23aa4b24a0c0 rw
rootflags=subvol=@ quiet splash pcie_aspm=off rd.udev.log_priority=3 vt.global_cursor_default=0
Desktop: GNOME 40.4 tk: GTK 3.24.30 wm: gnome-shell dm: GDM 40.1 Distro: Garuda Linux base: Arch Linux
Machine: Type: Desktop Mobo: Gigabyte model: GA-A55M-S2V serial: <filter> BIOS: Award v: F6 date: 11/18/2011
CPU: Info: Quad Core model: AMD Athlon II X4 631 bits: 64 type: MCP arch: Fusion family: 12 (18) model-id: 1 stepping: 0
microcode: 3000027 cache: L2: 4 MiB
flags: lm nx pae sse sse2 sse3 sse4a svm bogomips: 20797
Speed: 1650 MHz min/max: 800/2600 MHz Core speeds (MHz): 1: 1650 2: 1338 3: 2528 4: 2600
Type: spec_store_bypass status: Not affected
Type: spectre_v2 mitigation: Full AMD retpoline, STIBP: disabled, RSB filling
Graphics: Device-1: NVIDIA GP108 [GeForce GT 1030] vendor: Micro-Star MSI driver: nvidia v: 470.74
alternate: nouveau,nvidia_drm bus-ID: 01:00.0 chip-ID: 10de:1d01 class-ID: 0300
Display: x11 server: X.Org 1.20.13 compositor: gnome-shell driver: loaded: nvidia display-ID: :1 screens: 1
Screen-1: 0 s-res: 1680x1050 s-dpi: 96 s-size: 445x278mm (17.5x10.9") s-diag: 525mm (20.7")
Monitor-1: HDMI-0 res: 1680x1050 hz: 60 dpi: 90 size: 474x296mm (18.7x11.7") diag: 559mm (22")
OpenGL: renderer: NVIDIA GeForce GT 1030/PCIe/SSE2 v: 4.6.0 NVIDIA 470.74 direct render: Yes
Audio: Device-1: Advanced Micro Devices [AMD] FCH Azalia vendor: Gigabyte driver: snd_hda_intel v: kernel bus-ID: 00:14.2
chip-ID: 1022:780d class-ID: 0403
Device-2: NVIDIA GP108 High Definition Audio vendor: Micro-Star MSI driver: snd_hda_intel v: kernel bus-ID: 01:00.1
chip-ID: 10de:0fb8 class-ID: 0403
Device-3: Creative Labs EMU10k2/CA0100/CA0102/CA10200 [Sound Blaster Audigy Series] driver: snd_emu10k1 v: kernel
bus-ID: 03:06.0 chip-ID: 1102:0004 class-ID: 0401
Sound Server-1: ALSA v: k5.14.7-zen1-1-zen running: yes
Sound Server-4: PipeWire v: 0.3.37 running: yes
Network: Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: Gigabyte driver: r8168 v: 8.049.02-NAPI
modules: r8169 port: ee00 bus-ID: 02:00.0 chip-ID: 10ec:8168 class-ID: 0200
Bluetooth: Device-1: Conwise CW6622 type: USB driver: btusb v: 0.8 bus-ID: 1-3.3:4 chip-ID: 0e5e:6622 class-ID: e001
Drives: Local Storage: total: 1.48 TiB used: 271.32 GiB (17.9%)
ID-1: /dev/sda maj-min: 8:0 vendor: Western Digital model: WD10EZEX-22MFCA0 size: 931.51 GiB block-size:
physical: 4096 B logical: 512 B speed: 6.0 Gb/s type: HDD rpm: 7200 serial: <filter> rev: 1A01 scheme: MBR
ID-2: /dev/sdb maj-min: 8:16 model: SATA SSD size: 111.79 GiB block-size: physical: 512 B logical: 512 B
speed: 6.0 Gb/s type: SSD serial: <filter> rev: 61.2 scheme: MBR
ID-3: /dev/sdc maj-min: 8:32 vendor: Western Digital model: WD5000AAKX-001CA0 size: 465.76 GiB block-size:
physical: 512 B logical: 512 B speed: 6.0 Gb/s type: N/A serial: <filter> rev: 1H15 scheme: MBR
ID-4: /dev/sdd maj-min: 8:48 type: USB vendor: Generic model: Flash Disk size: 7.5 GiB block-size: physical: 512 B
logical: 512 B type: SSD serial: <filter> rev: 8.07 scheme: MBR
Partition: ID-1: / raw-size: 94.46 GiB size: 94.46 GiB (100.00%) used: 36.05 GiB (38.2%) fs: btrfs dev: /dev/sdb1
maj-min: 8:17
ID-2: /home raw-size: 233.02 GiB size: 228.36 GiB (98.00%) used: 124.85 GiB (54.7%) fs: ext4 dev: /dev/sda1
maj-min: 8:1
ID-3: /var/log raw-size: 94.46 GiB size: 94.46 GiB (100.00%) used: 36.05 GiB (38.2%) fs: btrfs dev: /dev/sdb1
maj-min: 8:17
ID-4: /var/tmp raw-size: 94.46 GiB size: 94.46 GiB (100.00%) used: 36.05 GiB (38.2%) fs: btrfs dev: /dev/sdb1
maj-min: 8:17
ID-1: swap-1 type: zram size: 7.76 GiB used: 0 KiB (0.0%) priority: 100 dev: /dev/zram0
Sensors: System Temperatures: cpu: 87.0 C mobo: 41.0 C gpu: nvidia temp: 46 C
Fan Speeds (RPM): cpu: 1159 fan-1: 1041 fan-3: 0 gpu: nvidia fan: 36%
Power: 12v: N/A 5v: 2.96 3.3v: N/A vbat: 3.30
Info: Processes: 263 Uptime: 12m wakeups: 0 Memory: 7.76 GiB used: 2.31 GiB (29.8%) Init: systemd v: 249 tool: systemctl
Compilers: gcc: 11.1.0 clang: 12.0.1 Packages: 1914 apt: 0 pacman: 1904 lib: 512 flatpak: 10 Shell: fish v: 3.3.1
running-in: gnome-terminal inxi: 3.3.06
-- Journal begins at Sat 2021-08-21 09:44:50 MSK, ends at Fri 2021-09-24 04:56:00 MSK. --
сен 24 04:07:28 alex-gaa55ms2v kernel: ACPI Error: AE_NOT_FOUND, While resolving a named reference package element - LNKD (20210604/dspkginit-438)
сен 24 04:07:28 alex-gaa55ms2v systemd-modules-load[253]: Failed to find module 'ashmem_linux'
сен 24 04:07:28 alex-gaa55ms2v systemd-modules-load[253]: Failed to find module 'binder_linux'
сен 24 04:07:28 alex-gaa55ms2v systemd-udevd[270]: /etc/udev/rules.d/39-libmtp-smart.rules:31 Invalid key 'TTR'
сен 24 04:07:28 alex-gaa55ms2v systemd-udevd[274]: vboxdrv: /usr/lib/udev/rules.d/60-vboxdrv.rules:1 Only network interfaces can be renamed, ignoring NAME="vboxdrv".
сен 24 04:07:28 alex-gaa55ms2v systemd-udevd[301]: vboxdrvu: /usr/lib/udev/rules.d/60-vboxdrv.rules:2 Only network interfaces can be renamed, ignoring NAME="vboxdrvu".
сен 24 04:07:28 alex-gaa55ms2v systemd-udevd[299]: vboxnetctl: /usr/lib/udev/rules.d/60-vboxdrv.rules:3 Only network interfaces can be renamed, ignoring NAME="vboxnetctl".
сен 24 04:07:28 alex-gaa55ms2v kernel: r8168 Copyright (C) 2021 Realtek NIC software team
сен 24 04:07:28 alex-gaa55ms2v systemd-udevd[286]: vboxdrvu: /usr/lib/udev/rules.d/60-vboxdrv.rules:2 Only network interfaces can be renamed, ignoring NAME="vboxdrvu".
сен 24 04:07:28 alex-gaa55ms2v systemd-udevd[296]: vboxdrv: /usr/lib/udev/rules.d/60-vboxdrv.rules:1 Only network interfaces can be renamed, ignoring NAME="vboxdrv".
сен 24 04:07:28 alex-gaa55ms2v systemd-udevd[301]: vboxnetctl: /usr/lib/udev/rules.d/60-vboxdrv.rules:3 Only network interfaces can be renamed, ignoring NAME="vboxnetctl".
сен 24 04:07:29 alex-gaa55ms2v systemd-udevd[295]: host6: /usr/lib/udev/rules.d/50-sata.rules:2 Failed to write ATTR{/sys/devices/pci0000:00/0000:00:13.2/usb2/2-3/2-3:1.0/host6/scsi_host/host6/link_power_management_policy}, ignoring: No such file or directory
сен 24 04:07:29 alex-gaa55ms2v systemd-tmpfiles[484]: Failed to write file "/sys/module/pcie_aspm/parameters/policy": Operation not permitted
сен 24 04:07:44 alex-gaa55ms2v gdm-launch-environment][3818]: GLib-GObject: g_object_unref: assertion 'G_IS_OBJECT (object)' failed
сен 24 04:08:03 alex-gaa55ms2v systemd[7055]: Failed to start Profile-sync-daemon.
сен 24 04:10:49 alex-gaa55ms2v systemd-udevd[270]: /etc/udev/rules.d/39-libmtp-smart.rules:31 Invalid key 'TTR'
сен 24 04:15:12 alex-gaa55ms2v systemd-udevd[270]: /etc/udev/rules.d/39-libmtp-smart.rules:31 Invalid key 'TTR'
сен 24 04:15:12 alex-gaa55ms2v kernel:
сен 24 04:15:13 alex-gaa55ms2v kernel: NVRM: loading NVIDIA UNIX x86_64 Kernel Module 470.74 Mon Sep 13 23:09:15 UTC 2021
сен 24 04:15:23 alex-gaa55ms2v bluetoothd[493]: src/profile.c:record_cb() Unable to get Hands-Free Voice gateway SDP record: Host is down
сен 24 04:15:33 alex-gaa55ms2v bluetoothd[493]: src/device.c:search_cb() 48:59:A4:DC:E2:CF: error updating services: Host is down (112)
сен 24 04:15:33 alex-gaa55ms2v bluetoothd[493]: src/profile.c:record_cb() Unable to get Hands-Free Voice gateway SDP record: Host is down
сен 24 04:23:18 alex-gaa55ms2v bluetoothd[493]: src/profile.c:record_cb() Unable to get Hands-Free Voice gateway SDP record: Host is down
сен 24 04:23:23 alex-gaa55ms2v gdm-password][98593]: gkr-pam: unable to locate daemon control file
сен 24 04:23:37 alex-gaa55ms2v bluetoothd[493]: src/profile.c:record_cb() Unable to get Hands-Free Voice gateway SDP record: Host is down
сен 24 04:23:38 alex-gaa55ms2v gdm-launch-environment][65573]: GLib-GObject: g_object_unref: assertion 'G_IS_OBJECT (object)' failed
сен 24 04:23:59 alex-gaa55ms2v bluetoothd[493]: src/profile.c:record_cb() Unable to get Hands-Free Voice gateway SDP record: Host is down
сен 24 04:24:06 alex-gaa55ms2v systemd-coredump[102819]: Process 493 (bluetoothd) of user 0 dumped core.
Found module linux-vdso.so.1 with build-id: f365fbf9889dd52a9719776c3ccb193782417204
Found module libudev.so.1 with build-id: 880e57f50a36ddbfe80dbe5f62d43860f960c797
Found module sixaxis.so with build-id: 0f183325e4d5c5ef8c45f3c20c888eaf62b6b6a8
Found module libgpg-error.so.0 with build-id: ba85170c2d9343ea05eea8fa2048c212ff4ef552
Found module libgcrypt.so.20 with build-id: db45f5d5e0f7af1e77324fea1885f974619ad268
Found module libcap.so.2 with build-id: e56ad9da369b1a7ba6c62d8d31c5a779f07fbbb1
Found module liblz4.so.1 with build-id: e63600ab23b2f6997f42fac2fa56e1f02ce159a1
Found module libzstd.so.1 with build-id: 4b10444c1560ebc574af4d5f488b7408b22d450e
Found module liblzma.so.5 with build-id: 8b615460aa230708c5183f16bede67aa0437d95e
Found module librt.so.1 with build-id: 75484da2d6f1515189eefa076e0a40328834cd16
Found module libm.so.6 with build-id: 2b8fd1f869ecab4e0b55e92f2f151897f6818acf
Found module ld-linux-x86-64.so.2 with build-id: 040cc3dd10461562f177df39e3be2f3704258c3c
Found module libsystemd.so.0 with build-id: f776aaa16b4e2ba7056d01d928e4b2726ffe2b8b
Found module libpthread.so.0 with build-id: 07c8f95b4f3251d08550217ad8a1f31066229996
Found module libpcre.so.1 with build-id: 845483dd0acba86de9f0313102bebbaf3ce52767
Found module libc.so.6 with build-id: 4b406737057708c0e4c642345a703c47a61c73dc
Found module libasound.so.2 with build-id: 9288c92ff737b1999761df2018fcd0e7cbf46d5a
Found module libdl.so.2 with build-id: 5abc547e7b0949f89f3c0e21ab0c8331a7440a8a
Found module libdbus-1.so.3 with build-id: 74f2ab9c60512f3a93c932c3f627564d42e0b11e
Found module libglib-2.0.so.0 with build-id: 1fe1592d097fa28822c23e96d9f357583b48424d
Found module bluetoothd with build-id: 5d0b44b893a28348e96f259996e30ad460f6b691
Stack trace of thread 493:
#0 0x00007fe2239e4fbb g_slist_foreach (libglib-2.0.so.0 + 0x6ffbb)
#1 0x00007fe2239e8f4c g_slist_free_full (libglib-2.0.so.0 + 0x73f4c)
#2 0x000056484e0b15fe n/a (bluetoothd + 0x265fe)
#3 0x000056484e0b1ca4 n/a (bluetoothd + 0x26ca4)
#4 0x000056484e0e6daa n/a (bluetoothd + 0x5bdaa)
#5 0x00007fe2239c93e5 g_main_context_dispatch (libglib-2.0.so.0 + 0x543e5)
#6 0x00007fe223a1d749 n/a (libglib-2.0.so.0 + 0xa8749)
#7 0x00007fe2239c8a63 g_main_loop_run (libglib-2.0.so.0 + 0x53a63)
#8 0x000056484e15a0f6 n/a (bluetoothd + 0xcf0f6)
#9 0x000056484e15a578 n/a (bluetoothd + 0xcf578)
#10 0x000056484e0acb3e n/a (bluetoothd + 0x21b3e)
#11 0x00007fe22368cb25 __libc_start_main (libc.so.6 + 0x27b25)
#12 0x000056484e0ada5e n/a (bluetoothd + 0x22a5e)
сен 24 04:24:06 alex-gaa55ms2v pipewire-media-session[100133]: Failed to start HFP/HSP backend native
сен 24 04:24:11 alex-gaa55ms2v systemd-coredump[102883]: Process 102874 (yandex_browser) of user 1000 dumped core.
Found module libabt-bindings.so without build-id.
Found module libbrotlicommon.so.1 with build-id: f68934f94312f770550ebc6c5acfd6359b098b07
Found module libbrotlidec.so.1 with build-id: f871e6f204ab8d48099915126ba01be989a8000f
Found module libbz2.so.1.0 with build-id: 919597c477c9b2cb9cdbb7745ed6494ac0e6da60
Found module libgraphite2.so.3 with build-id: 47761dc11e553f519cde97ed9ee985be12ccdae2
Found module libdatrie.so.1 with build-id: 6fe3b6ece2c8e7d11869fa051375128d8f808f58
Found module libblkid.so.1 with build-id: f03a24e92c9852272bd0049b5bcb7ed6cf0e664f
Found module libgmp.so.10 with build-id: e58d34ab389d1b649c24195c2d145e3ff2e58290
Found module libhogweed.so.6 with build-id: 2d70cff7b1841b4d9ca4e8e7726cd4b944c07fdc
Found module libnettle.so.8 with build-id: 9a878e513c02007598fcf1e2e286c2203f13536e
Found module libtasn1.so.6 with build-id: 4df18bd1f13772f0956191e137eb00d9bd6238c5
Found module libunistring.so.2 with build-id: 015ac6d6bcb60b7d8bea31a80d1941b06e8636ab
Found module libidn2.so.0 with build-id: 1ce2b50ad9f9821c2c629b521cf5a3c99593d332
Found module libp11-kit.so.0 with build-id: 5314ec746546ada6f442b6fdfae15eab9f6d3cdc
Found module libkeyutils.so.1 with build-id: ac405ddd17be10ce538da3211415ee50c8f8df79
Found module libkrb5support.so.0 with build-id: adf65240a4d2aba772d7a0772b4d015469934113
Found module libcom_err.so.2 with build-id: eb61ef71c8b97846db759fb89a115405cff6dd30
Found module libk5crypto.so.3 with build-id: eb8220b8f36675aac769450be4cb6bb7f97ec38a
Found module libkrb5.so.3 with build-id: 72d26767c5cb1097db75a5f5bff88860233c902b
Found module libXi.so.6 with build-id: 16603be937a02a7e61b0b0395d064be7efd86f49
Found module libpixman-1.so.0 with build-id: 341f793dcada3a48a306a793d265a517e3f2e7d6
Found module libxcb-shm.so.0 with build-id: fb797f299a446f559a95afcc168227482cc800d1
Found module libxcb-render.so.0 with build-id: a37bdb37744b508be9dd29fd9ccb9bb0170d43e5
Found module libfreetype.so.6 with build-id: 65e7f4a1e5557b0ceeaa433e5356f857fe9c669b
Found module libfontconfig.so.1 with build-id: 1103a641395c7d3b42e49b793d3a9ea927c77bf6
Found module libpng16.so.16 with build-id: 2dc0bce07f199bf983c07a05fb95a6f4af83a9b3
Found module libharfbuzz.so.0 with build-id: f954dfb80265c0dd2484e766282305a739b8239d
Found module libthai.so.0 with build-id: 3fdce1a7db2b94d9168eea540dbf5ff5caa3b8ad
Found module libfribidi.so.0 with build-id: e29e3b231f961d49e628d43ddd1237a8364f788c
Found module libwayland-server.so.0 with build-id: 232648aebf61c9b61940ac383dbe27984deea6b2
Found module libXrender.so.1 with build-id: 97e0b9ab6ba96ebc86527cc2b3c3078aad8616b3
Found module libXdmcp.so.6 with build-id: 8ca0792d23c8b8b4c0864297512349292bea5955
Found module libXau.so.6 with build-id: 1c67764663e07bec24d8951e5fd93f4d165979ff
Found module libresolv.so.2 with build-id: c915c72668282861a813f7ea3c0780f37b681dc0
Found module libmount.so.1 with build-id: ff9a1d99d35cf640d0bfdaba294854372672c29b
Found module libgmodule-2.0.so.0 with build-id: 34cabbd12d9baf397a0255f174e4c96165bc329b
Found module libz.so.1 with build-id: 81bf6e728a6d6f5b105b0f8b25f6c614ce10452a
Found module libgnutls.so.30 with build-id: 8c87466eacaec0041a370df713d0fd200358c94c
Found module libavahi-client.so.3 with build-id: 1858551543958190c653b565cf0eb64609ad908a
Found module libavahi-common.so.3 with build-id: 80fda945459a3476ccd1050783dfd5f5c17c479a
Found module libgssapi_krb5.so.2 with build-id: e6e098ad51ce7bdd3dbe902d7b0f69a90f8a9e08
Found module libplc4.so with build-id: e3d338de1e8d5ea2f98a87af9157b17f92278d83
Found module libplds4.so with build-id: a2dcd5d4a1d3dccbf591e36bcc8d84162751c0a8
Found module libffi.so.7 with build-id: de60e99f39569d11d09160bbdcd486cedc87d2b6
Found module libgcc_s.so.1 with build-id: 7f8508bb914546ada778809b64b99d234337d835
Found module libxshmfence.so.1 with build-id: 8876d9ccf620858795724ca24b9e567585a77cec
Found module libatspi.so.0 with build-id: 046ee7a264956ff92020b0773ab583b23b93933c
Found module libcairo.so.2 with build-id: 06820af9cf79c2deb207d9533a61caf04e67a8ad
Found module libpango-1.0.so.0 with build-id: 5deae7c16592ea404754114e8ae56ddf9cf4ca7e
Found module libgbm.so.1 with build-id: cd8fa998966b9987180fd6034f3e8b1f02ed50f4
Found module libxkbcommon.so.0 with build-id: 1f1bc7527e57c886c3df5803068122e1971d4724
Found module libXrandr.so.2 with build-id: d4e869b5c72541e1de8f96b456248987ea52d51b
Found module libXfixes.so.3 with build-id: 0a05c7e8714522bfbdd7c0027c3e2a94965664b0
Found module libXext.so.6 with build-id: d70f24beb4fad748d6becffdcc13e51be0a2ebfa
Found module libXdamage.so.1 with build-id: a1d867e093c16944b2c0083be98050ef35c9e5c2
Found module libXcomposite.so.1 with build-id: f1bb5ffb6203ab2907ac044a204ce3902a79f1c1
Found module libX11.so.6 with build-id: e9192497aa39fab51358826d1a1b5fb77edc5081
Found module libxcb.so.1 with build-id: 0d1ef11740a5daad2ee331e812a51aa6574af222
Found module libexpat.so.1 with build-id: 8850138eae6d9d4d43c5c4b2ac48393bc4279037
Found module libgio-2.0.so.0 with build-id: 3338d7168eab6039416e1b6dbb7ea3ef213cd129
Found module libdrm.so.2 with build-id: 3aeff5403ca8d7589eabc05752eb613937f454a1
Found module libcups.so.2 with build-id: 2cd7a7fb6941acfb2cc2a6540dcbc9f3056c1a18
Found module libatk-bridge-2.0.so.0 with build-id: 1161ebbcc5aa791075dfa026671875e5417287bd
Found module libatk-1.0.so.0 with build-id: aacaa40363d304858b654728a893bc212a4ca119
Found module libnspr4.so with build-id: d737bfb932206eb128a493cc70cedd63714e814f
Found module libsmime3.so with build-id: 6ded7cfb9acbade6410a4eb35ce56890dba17c55
Found module libnssutil3.so with build-id: a75bf14b783440fd724c77699e1e77391d22c7e5
Found module libnss3.so with build-id: 0597b62ca501f399f9c45c74b8081753f8f36811
Found module libgobject-2.0.so.0 with build-id: 0eaa1a0f88089b3dcf33eedf51105a54beeeea9a
Found module libffmpeg.so with build-id: 8da032612f03149711a9ad980359e3f77f48605a
Found module yandex_browser with build-id: cea45b8388fc039c88380835162f79052c6af9a7
Stack trace of thread 102874:
#0 0x00007f1cde1fa9ef n/a (libabt-bindings.so + 0x1f79ef)
#1 0x00007f1cde1fa636 n/a (libabt-bindings.so + 0x1f7636)
#2 0x00007f1cde1d8b35 n/a (libabt-bindings.so + 0x1d5b35)
#3 0x000056369ad4f56b n/a (yandex_browser + 0x5b7156b)
#4 0x000056369ad50581 n/a (yandex_browser + 0x5b72581)
#5 0x000056369766a27c n/a (yandex_browser + 0x248c27c)
#6 0x000056369a6f0ce4 n/a (yandex_browser + 0x5512ce4)
#7 0x000056369a6f0359 n/a (yandex_browser + 0x5512359)
#8 0x0000563697669d83 ChromeMain (yandex_browser + 0x248bd83)
#9 0x00007f1cdf7dcb25 __libc_start_main (libc.so.6 + 0x27b25)
#10 0x00005636973545ea _start (yandex_browser + 0x21765ea)
сен 24 04:24:11 alex-gaa55ms2v pipewire-media-session[100133]: Failed to start HFP/HSP backend native
сен 24 04:28:54 alex-gaa55ms2v pipewire-media-session[100133]: a2dp-sink 0x558e639f5328: ioctl fail: Неправильный дескриптор файла
сен 24 04:28:54 alex-gaa55ms2v pipewire-media-session[100133]: Failed to release transport /org/bluez/hci0/dev_57_2C_C2_7F_AE_58/sep1/fd0: Method "Release" with signature "" on interface "org.bluez.MediaTransport1" doesn't exist
