Frequent system freezing issue
I am facing out of nowhere system freezing issues, this is going on for quite a while now, I have searched some posts regarding this issue and found that switching to LTS kernal might help, but still making a post about this issue.
Another issue I am facing is that when I am booting up my laptop the bottom panel is so tiny that it is barely visible, I have to enter edit mode to fix it each time I boot up, any solution for these issues? your help is greatly appreciated, thank you.
Kernel: 6.9.3-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 14.1.1
root=UUID=cd91162f-2636-4eed-ae3d-288a3fbc2000 rw rootflags=subvol=@
resume=UUID=f195304e-a978-4f67-85e4-377a74796bd3 loglevel=3 ibt=off
Desktop: KDE Plasma v: 6.0.5 tk: Qt v: N/A info: frameworks v: 6.2.0
Type: Laptop System: Acer product: Aspire A515-51G v: V2.02
Mobo: KBL model: Charmander_KL v: V2.02 serial: <superuser required>
part-nu: 0000000000000000 uuid: <superuser required> UEFI-[Legacy]: Insyde
v: 2.02 date: 01/03/2019
ID-1: BAT1 charge: 38.7 Wh (97.5%) condition: 39.7/48.9 Wh (81.2%)
volts: 17.0 min: 15.2 model: LG 004B384234314341 type: Li-ion
Info: model: Intel Core i5-8250U bits: 64 type: MT MCP arch: Coffee Lake
model-id: 0x8E (142) stepping: 0xA (10) microcode: 0xF4
L3: 6 MiB desc: 1x6 MiB
Speed (MHz): avg: 775 high: 3400 min/max: 400/3400 scaling:
driver: intel_pstate governor: powersave cores: 1: 400 2: 400 3: 400 4: 400
5: 400 6: 400 7: 400 8: 3400 bogomips: 28800
Device-1: Intel UHD Graphics 620 vendor: Acer Incorporated ALI driver: i915
active: eDP-1 empty: HDMI-A-1 bus-ID: 00:02.0 chip-ID: 8086:5917
Device-2: NVIDIA GP108M [GeForce MX150] vendor: Acer Incorporated ALI
driver: nvidia v: 550.78 alternate: nouveau,nvidia_drm non-free: 545.xx+
status: current (as of 2024-04; EOL~2026-12-xx) arch: Maxwell code: GMxxx
process: TSMC 28nm built: 2014-2019 pcie: gen: 1 speed: 2.5 GT/s lanes: 4
link-max: gen: 3 speed: 8 GT/s bus-ID: 01:00.0 chip-ID: 10de:1d10
class-ID: 0302
Device-3: Chicony Integrated HD WebCam driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-7:4 chip-ID: 04f2:b5f7
class-ID: 0e02
Monitor-1: eDP-1 res: 1366x768 size: N/A modes: N/A
inactive: device-1
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: intel mesa v: 24.1.1-arch1.1
glx-v: 1.4 direct-render: yes renderer: Mesa Intel UHD Graphics 620 (KBL
GT2) device-ID: 8086:5917 memory: 3.73 GiB unified: yes display-ID: :1.0
API: Vulkan v: 1.3.279 layers: 8 device: 0 type: integrated-gpu name: Intel
UHD Graphics 620 (KBL GT2) driver: mesa intel v: 24.1.1-arch1.1
device-ID: 8086:5917 surfaces: xcb,xlib,wayland device: 1
type: discrete-gpu name: NVIDIA GeForce MX150 driver: nvidia v: 550.78
device-ID: 10de:1d10 surfaces: xcb,xlib,wayland device: 2 type: cpu
v: 24.1.1-arch1.1 (LLVM 17.0.6) device-ID: 10005:0000
Device-1: Intel Sunrise Point-LP HD Audio vendor: Acer Incorporated ALI
API: ALSA v: k6.9.3-zen1-1-zen status: kernel-api tools: N/A
speed: 2.5 GT/s lanes: 1 port: 3000 bus-ID: 02:00.1 chip-ID: 10ec:8168
IF: enp2s0f1 state: down mac: <filter>
Device-2: Intel Dual Band Wireless-AC 3168NGW [Stone Peak] driver: iwlwifi
rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-5:3 chip-ID: 8087:0aa7
Local Storage: total: 1.14 TiB used: 229.62 GiB (19.7%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Kingston model: SA2000M8250G
size: 232.89 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
lanes: 4 tech: SSD serial: <filter> fw-rev: S5Z42105 temp: 36.9 C
scheme: MBR
model: WD10SPZX-21Z10T0 size: 931.51 GiB block-size: physical: 4096 B
fw-rev: 1A02 scheme: MBR
ID-1: / raw-size: 224.08 GiB size: 224.08 GiB (100.00%)
used: 117.58 GiB (52.5%) fs: btrfs dev: /dev/nvme0n1p1 maj-min: 259:1
ID-2: /home raw-size: 224.08 GiB size: 224.08 GiB (100.00%)
ID-3: /var/log raw-size: 224.08 GiB size: 224.08 GiB (100.00%)
ID-4: /var/tmp raw-size: 224.08 GiB size: 224.08 GiB (100.00%)
ID-1: swap-1 type: partition size: 8.8 GiB used: 0 KiB (0.0%) priority: -2
ID-2: swap-2 type: zram size: 7.63 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 65.0 C mobo: N/A
Memory: total: 8 GiB available: 7.63 GiB used: 1.71 GiB (22.4%)
Processes: 263 Power: uptime: 1m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 2.99 GiB services: org_kde_powerdevil,
Packages: pm: pacman pkgs: 1556 libs: 447 tools: octopi,paru,yay
Compilers: clang: 17.0.6 gcc: 14.1.1 Shell: garuda-inxi default: Bash
v: 5.2.26 running-in: konsole inxi: 3.3.34
System install date:     2023-10-22
Last full system update: 2024-06-08
Try changing to x11 at the bottom of the login screen
can not find any option to do so at the login screen? it only shows virtual keyboard and battery %
Odd, you must have a custom SDDM without that. There is an alternative way to set this in KDE Settings. Go to SDDM settings and hit the “behavior” button on top. The first line of settings there will let you change the type per user.
Done. Thanks! let’s see what happens.
