Freeze ups installing wine related prereqs (bottles, protontricks, winetricks)
Hello Garuda users.
I started noticing my system freezing while installing wine prefix components with Bottles first. I tinkered and ended up just installing Bottles as a flatpak which resolved the issue.
Then I also encountered the freezing issue while using protontricks (happens intermittently every few seconds).
Does anyone have any clue what might cause this?
I attempted to turn off zswap only, but other than that it seems like flatpaks are the only workaround. I would like to get to the root issue. Hard to find relevant scenarios when searching for freeze ups.
Kernel: 6.4.13-201.fsync.fc38.x86_64 arch: x86_64 bits: 64 compiler: gcc
v: 2.39-9.fc38 clocksource: tsc available: hpet,acpi_pm
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-fsync-nobara-bin
root=UUID=58d899b9-dff2-41f8-9e33-b9bfaf304276 rw rootflags=subvol=@
quiet rd.luks.uuid=185ba6fd-f750-49c2-afc0-8e7fc3e6240f quiet
Desktop: KDE Plasma v: 5.27.8 tk: Qt v: 5.15.10 wm: kwin_x11 vt: 2
Mobo: ASUSTeK model: ROG STRIX X670E-F GAMING WIFI v: Rev 1.xx
serial: <superuser required> UEFI: American Megatrends v: 1602
date: 08/15/2023
Info: model: AMD Ryzen 9 7950X3D bits: 64 type: MT MCP arch: Zen 4 gen: 5
Topology: cpus: 1x cores: 16 tpc: 2 threads: 32 smt: enabled cache:
L1: 1024 KiB desc: d-16x32 KiB; i-16x32 KiB L2: 16 MiB desc: 16x1024 KiB
L3: 128 MiB desc: 1x32 MiB, 1x96 MiB
Speed (MHz): avg: 3018 high: 4200 min/max: 3000/5713 boost: enabled
scaling: driver: acpi-cpufreq governor: ondemand cores: 1: 2996 2: 3000
3: 2998 4: 3000 5: 3000 6: 2993 7: 2999 8: 3000 9: 3000 10: 3000 11: 2879
12: 2878 13: 3000 14: 2880 15: 3000 16: 3000 17: 3000 18: 3000 19: 3000
20: 3000 21: 3000 22: 2999 23: 3000 24: 3000 25: 2880 26: 2880 27: 3000
28: 3000 29: 4200 30: 3000 31: 3000 32: 3000 bogomips: 268791
Device-1: AMD Navi 21 [Radeon RX 6800/6800 XT / 6900 XT]
vendor: XFX Speedster MERC 319 driver: amdgpu v: kernel arch: RDNA-2
speed: 16 GT/s lanes: 16 ports: active: DP-1,DP-2 empty: DP-3,HDMI-A-1
bus-ID: 03:00.0 chip-ID: 1002:73bf class-ID: 0300
Device-2: AMD Raphael vendor: ASUSTeK driver: amdgpu v: kernel
gen: 4 speed: 16 GT/s lanes: 16 ports: active: none empty: DP-4,HDMI-A-2
bus-ID: 15:00.0 chip-ID: 1002:164e class-ID: 0300 temp: 35.0 C
Screen-1: 0 s-res: 5120x1440 s-dpi: 96 s-size: 1354x381mm (53.31x15.00")
s-diag: 1407mm (55.38")
Monitor-1: DP-1 mapped: DisplayPort-0 pos: primary,right
model: LG (GoldStar) ULTRAGEAR serial: <filter> built: 2022 res: 2560x1440
hz: 165 dpi: 93 gamma: 1.2 size: 697x392mm (27.44x15.43")
diag: 800mm (31.5") ratio: 16:9 modes: max: 2560x1440 min: 640x480
Monitor-2: DP-2 mapped: DisplayPort-1 pos: left model: AOC AG271QG4
serial: <filter> built: 2016 res: 2560x1440 dpi: 109 gamma: 1.2
max: 2560x1440 min: 720x400
API: OpenGL v: 4.6 Mesa 23.1.7-arch1.1 renderer: AMD Radeon RX 6800 XT
(navi21 LLVM 16.0.6 DRM 3.52 6.4.13-201.fsync.fc38.x86_64)
direct-render: Yes
gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 03:00.1 chip-ID: 1002:ab28
Device-2: AMD Rembrandt Radeon High Definition Audio vendor: ASUSTeK
bus-ID: 15:00.1 chip-ID: 1002:1640 class-ID: 0403
Device-3: C-Media Audio Adapter (Unitek Y-247A)
driver: cmedia_hs100b,snd-usb-audio,usbhid type: USB rev: 1.1 speed: 12 Mb/s
lanes: 1 mode: 1.1 bus-ID: 1-2:2 chip-ID: 0d8c:0014 class-ID: 0300
Device-4: ASUSTek USB Audio driver: hid-generic,snd-usb-audio,usbhid
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-6:2
API: ALSA v: k6.4.13-201.fsync.fc38.x86_64 status: kernel-api with: aoss
Server-2: PipeWire v: 0.3.80 status: active with: 1: pipewire-pulse
lanes: 1 bus-ID: 0b:00.0 chip-ID: 14c3:0616 class-ID: 0280
IF: wlp11s0 state: down mac: <filter>
pcie: gen: 2 speed: 5 GT/s lanes: 1 port: N/A bus-ID: 0c:00.0
IF: eno1 state: up speed: 2500 Mbps duplex: full mac: <filter>
rev: 2.1 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-9:5 chip-ID: 0489:e0e2
Report: btmgmt ID: hci0 rfk-id: 5 state: up address: <filter> bt-v: 5.2
Local Storage: total: 25.47 TiB used: 7.67 TiB (30.1%)
ID-1: /dev/nvme0n1 maj-min: 259:5 vendor: Crucial model: CT2000P5PSSD8
lanes: 4 tech: SSD serial: <filter> fw-rev: P7CR403 temp: 34.9 C
ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: Sabrent model: Rocket 4.0 1TB
lanes: 4 tech: SSD serial: <filter> fw-rev: RKT401.3 temp: 26.9 C
ID-3: /dev/nvme2n1 maj-min: 259:2 vendor: Crucial model: CT2000P5PSSD8
lanes: 4 tech: SSD serial: <filter> fw-rev: P7CR403 temp: 27.9 C
ID-4: /dev/sda maj-min: 8:0 vendor: Toshiba model: HDWE150 size: 4.55 TiB
block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s tech: HDD
rpm: 7200 serial: <filter> fw-rev: FP2A scheme: GPT
ID-5: /dev/sdb maj-min: 8:16 vendor: Western Digital
model: WD40EZRX-00SPEB0 size: 3.64 TiB block-size: physical: 4096 B
fw-rev: 0A80 scheme: GPT
ID-6: /dev/sdc maj-min: 8:32 vendor: Western Digital
model: WD140EDGZ-11B1PA0 size: 12.73 TiB block-size: physical: 4096 B
logical: 512 B type: USB rev: 3.1 spd: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1
tech: HDD rpm: 7200 serial: <filter> fw-rev: 3012 scheme: GPT
ID-1: / raw-size: 1.82 TiB size: 1.82 TiB (100.00%) used: 959.76 GiB (51.5%)
fs: btrfs dev: /dev/dm-0 maj-min: 253:0
mapped: luks-185ba6fd-f750-49c2-afc0-8e7fc3e6240f
used: 720 KiB (0.2%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:6
used: 959.76 GiB (51.5%) fs: btrfs dev: /dev/dm-0 maj-min: 253:0
zswap: no
ID-1: swap-1 type: zram size: 61.93 GiB used: 0 KiB (0.0%) priority: 100
comp: zstd avail: lzo,lzo-rle,lz4,lz4hc,842 max-streams: 32 dev: /dev/zram0
System Temperatures: cpu: 41.4 C mobo: N/A
GPU: device: amdgpu temp: 35.0 C device: amdgpu temp: 32.0 C mem: 30.0 C
fan: 1199 watts: 28.00
Processes: 641 Uptime: 1d 15h 28m wakeups: 148 Memory: total: 64 GiB
available: 61.93 GiB used: 10.14 GiB (16.4%) Init: systemd v: 254
default: graphical tool: systemctl Compilers: gcc: 13.2.1 alt: 12
clang: 16.0.6 Packages: 2250 pm: pacman pkgs: 2224 libs: 536
tools: octopi,pamac,paru,yay pm: flatpak pkgs: 26 Shell: fish v: 3.6.1
default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.29
System install date:     2023-03-17
Last full system update: 2023-09-20 ↻
Relevant software:       timeshift NetworkManager dracut
Failed units:            mnt-Network-Fresh.mount archlinux-keyring-wkd-sync.service
While troubleshooting this further, I find that its the mouse that seems to be freezing during these processes, not the entire system. I am able to type continuously or switch between applications while the mouse stops.
To note, this mouse behavior happens briefly when starting Steam which also interacts with wine/proton.
