Hey guys , the other day I installed Garuda Gnome on my desktop , it was a very smooth experience until the updates came in , once the updates finished I had to restart my pc , after that I started to notice a bit of lag in my PC , initially I thought that gnome was a heavy environment so I switched to KDE Dragonized , still the problem persists...Is it my hardware compatibility issue or is it comman for all the users?
Hope my specs aren't too bad
No picture from terminal!!
@ndarahaas
Post also the update history, you find the list also in pamac.
Its a very big file
Only from the update date, before the lag came up
inxi -Fxxxza
I installed it yesterday , cant figure out the date
https://bin.garudalinux.org/?2f1b0e886ce02a65#HMN8bSp6jpFV7jFbPo2ssstDisgjEVpbZPf4BMqrdfG2
System: Kernel: 5.10.6-110-tkg-bmq x86_64 bits: 64 compiler: gcc v: 10.2.0
root=UUID=0ba6ff46-f38b-4756-bf00-512a061e8205 rw rootflags=subvol=@ quiet splash
Desktop: KDE Plasma 5.20.5 tk: Qt 5.15.2 info: latte-dock wm: kwin_x11 dm: SDDM
Distro: Garuda Linux
Machine: Type: Desktop System: HP product: 24-g025in v: N/A serial: <filter> Chassis: type: 13
Mobo: HP model: 81BA v: 0001 serial: <filter> UEFI: AMI v: F.03 date: 05/12/2016
CPU: Info: Dual Core model: Intel Core i5-6200U bits: 64 type: MT MCP arch: Skylake family: 6
model-id: 4E (78) stepping: 3 microcode: E2 L2 cache: 3 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 19217
Speed: 400 MHz min/max: 400/2800 MHz Core speeds (MHz): 1: 400 2: 400 3: 400 4: 400
Type: spectre_v2 mitigation: Full generic retpoline, IBPB: conditional, IBRS_FW, STIBP:
conditional, RSB filling
Graphics: Device-1: Intel Skylake GT2 [HD Graphics 520] vendor: Hewlett-Packard driver: i915
v: kernel bus ID: 00:02.0 chip ID: 8086:1916
Device-2: NVIDIA GM108M [GeForce 920MX] vendor: Hewlett-Packard driver: nvidia
v: 460.32.03 alternate: nouveau,nvidia_drm bus ID: 01:00.0 chip ID: 10de:134f
Device-3: Chicony HP Webcam type: USB driver: uvcvideo bus ID: 1-3:3 chip ID: 04f2:b58a
Display: x11 server: X.Org 1.20.10 compositor: kwin_x11 driver: modesetting,nvidia
alternate: fbdev,intel,nouveau,nv,vesa display ID: :0 screens: 1
s-diag: 582mm (22.9")
Monitor-1: eDP-1 res: 1920x1080 hz: 60 dpi: 93 size: 527x297mm (20.7x11.7")
diag: 605mm (23.8")
OpenGL: renderer: Mesa Intel HD Graphics 520 (SKL GT2) v: 4.6 Mesa 20.3.2
direct render: Yes
Audio: Device-1: Intel Sunrise Point-LP HD Audio vendor: Hewlett-Packard driver: snd_hda_intel
v: kernel alternate: snd_soc_skl bus ID: 00:1f.3 chip ID: 8086:9d70
Sound Server: ALSA v: k5.10.6-110-tkg-bmq
Network: Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: Hewlett-Packard
driver: r8169 v: kernel port: d000 bus ID: 02:00.0 chip ID: 10ec:8168
Device-2: Realtek RTL8723BE PCIe Wireless Network Adapter vendor: Hewlett-Packard
driver: rtl8723be v: kernel port: c000 bus ID: 03:00.0 chip ID: 10ec:b723
Drives: Local Storage: total: 946.1 GiB used: 27.74 GiB (2.9%)
ID-1: /dev/sda maj-min: 8:0 vendor: Western Digital model: WD10EZEX-60WN4A0
size: 931.51 GiB block size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
serial: <filter> rev: 1A01
ID-2: /dev/sdc maj-min: 8:32 type: USB vendor: SanDisk model: Cruzer Blade size: 14.59 GiB
block size: physical: 512 B logical: 512 B serial: <filter> rev: 1.00
Partition: ID-1: / raw size: 456.81 GiB size: 456.81 GiB (100.00%) used: 27.73 GiB (6.1%) fs: btrfs
dev: /dev/sda2 maj-min: 8:2
ID-2: /boot/efi raw size: 512 MiB size: 511 MiB (99.80%) used: 8.5 MiB (1.7%) fs: vfat
dev: /dev/sda1 maj-min: 8:1
ID-3: /home raw size: 456.81 GiB size: 456.81 GiB (100.00%) used: 27.73 GiB (6.1%)
ID-4: /var/log raw size: 456.81 GiB size: 456.81 GiB (100.00%) used: 27.73 GiB (6.1%)
ID-5: /var/tmp raw size: 456.81 GiB size: 456.81 GiB (100.00%) used: 27.73 GiB (6.1%)
ID-1: swap-1 type: zram size: 1.92 GiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram0
ID-2: swap-2 type: zram size: 1.92 GiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram1
ID-3: swap-3 type: zram size: 1.92 GiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram2
ID-4: swap-4 type: zram size: 1.92 GiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram3
ID-5: swap-5 type: partition size: 8.7 GiB used: 0 KiB (0.0%) priority: 1024
dev: /dev/sda4 maj-min: 8:4
Sensors: System Temperatures: cpu: 48.0 C mobo: N/A
Info: Processes: 224 Uptime: 51m wakeups: 0 Memory: 7.66 GiB used: 3.18 GiB (41.5%)
Init: systemd v: 247 Compilers: gcc: 10.2.0 Packages: pacman: 1632 lib: 492 Shell: fish
v: 3.1.2 running in: konsole inxi: 3.2.01
Desktop with two GPU, two monitor and HP, puhhh. That must have framedrops (joke)
Restore last snapshot
i dont have 2 monitors , and the same thing happened with garuda gnome...Which desktop environment would you suggest (gnome , wayland ,xfce...)
Ok, misreading?
But it is not the Desktop Environment, maybe kernel related, try another.
Another garuda distro or other linux distros
kernel .....
or man... or pop ... or ubuntu.
You can only find out through logs (journal and Xorg).
journalctl -b -p3 --no-hostname --no-pager
bash -c 'grep -E "(EE)|(WW)|failed|Time" /var/log/Xorg.0.log'
Same problem here. Rolled back to before the update for now, though.(thanks btrfs+timeshift! That was as fast as pressing Enter )
Here is my setup:
System: Kernel: 5.10.4-107-tkg-bmq x86_64 bits: 64 compiler: gcc v: 10.2.0
BOOT_IMAGE=/timeshift-btrfs/snapshots/2021-01-14_17-46-34/@/boot/vmlinuz-linux-tkg-bmq
root=UUID=a7d5bdd9-fe2b-40ea-a8c9-7155cbc7ddee rw quiet splash rd.udev.log_priority=3
rootflags=subvol=timeshift-btrfs/snapshots/2021-01-14_17-46-34/@
Machine: Type: Desktop System: Gigabyte product: N/A v: N/A serial: <filter>
Mobo: Gigabyte model: Z170-HD3-CF v: x.x serial: <filter> UEFI: American Megatrends v: F6
date: 02/23/2016
CPU: Info: Quad Core model: Intel Core i5-6600K bits: 64 type: MCP arch: Skylake-S family: 6
model-id: 5E (94) stepping: 3 microcode: E2 L2 cache: 6 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 28026
Speed: 3165 MHz min/max: 800/3500 MHz Core speeds (MHz): 1: 3165 2: 1805 3: 3501 4: 3500
Type: l1tf mitigation: PTE Inversion; VMX: conditional cache flushes, SMT disabled
mitigation: Full generic retpoline, IBPB: conditional, IBRS_FW, STIBP: disabled, RSB filling
Type: tsx_async_abort mitigation: Clear CPU buffers; SMT disabled
Graphics: Device-1: NVIDIA GP104 [GeForce GTX 1070] vendor: ASUSTeK driver: nvidia v: 455.45.01
alternate: nouveau,nvidia_drm bus ID: 01:00.0 chip ID: 10de:1b81
Display: x11 server: X.org 1.20.10 compositor: kwin_x11 driver: nvidia
resolution: <missing: xdpyinfo>
OpenGL: renderer: GeForce GTX 1070/PCIe/SSE2 v: 4.6.0 NVIDIA 455.45.01 direct render: Yes
Audio: Device-1: Intel 100 Series/C230 Series Family HD Audio vendor: Gigabyte driver: snd_hda_intel
v: kernel bus ID: 00:1f.3 chip ID: 8086:a170
Device-2: NVIDIA GP104 High Definition Audio vendor: ASUSTeK driver: snd_hda_intel v: kernel
bus ID: 01:00.1 chip ID: 10de:10f0
Device-3: C-Media CM106 Like Sound Device type: USB driver: hid-generic,snd-usb-audio,usbhid
bus ID: 1-6.4.1:10 chip ID: 0d8c:0102
Sound Server: ALSA v: k5.10.4-107-tkg-bmq
Network: Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: Gigabyte driver: r8169
v: kernel port: d000 bus ID: 06:00.0 chip ID: 10ec:8168
IF: enp6s0 state: up speed: 100 Mbps duplex: full mac: <filter>
IF-ID-1: tun0 state: unknown speed: 10 Mbps duplex: full mac: N/A
Drives: Local Storage: total: 4.1 TiB used: 1.73 TiB (42.1%)
ID-1: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 850 PRO 512GB size: 476.94 GiB block size:
physical: 512 B logical: 512 B speed: 6.0 Gb/s serial: <filter> rev: 4B6Q
ID-2: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST3000DM001-1ER166 size: 2.73 TiB block size:
physical: 4096 B logical: 512 B speed: 6.0 Gb/s serial: <filter> rev: CC46
ID-3: /dev/sdc maj-min: 8:32 type: USB vendor: Toshiba model: External USB 3.0 size: 931.51 GiB
block size: physical: 512 B logical: 512 B serial: <filter> rev: 0001
Partition: ID-1: / raw size: 393.08 GiB size: 393.08 GiB (100.00%) used: 179.8 GiB (45.7%) fs: btrfs
ID-2: /boot/efi raw size: 100 MiB size: 96 MiB (96.00%) used: 26.1 MiB (27.2%) fs: vfat
dev: /dev/sda5 maj-min: 8:5
ID-3: /home raw size: 393.08 GiB size: 393.08 GiB (100.00%) used: 179.8 GiB (45.7%) fs: btrfs
ID-4: /var/log raw size: 393.08 GiB size: 393.08 GiB (100.00%) used: 179.8 GiB (45.7%) fs: btrfs
ID-5: /var/tmp raw size: 393.08 GiB size: 393.08 GiB (100.00%) used: 179.8 GiB (45.7%) fs: btrfs
ID-1: swap-1 type: zram size: 3.9 GiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram0
ID-2: swap-2 type: zram size: 3.9 GiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram1
ID-3: swap-3 type: zram size: 3.9 GiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram2
ID-4: swap-4 type: zram size: 3.9 GiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram3
Sensors: System Temperatures: cpu: 43.0 C mobo: 29.8 C gpu: nvidia temp: 38 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 28%
Info: Processes: 238 Uptime: 4m wakeups: 0 Memory: 15.58 GiB used: 3.44 GiB (22.1%) Init: systemd
v: 247 Compilers: gcc: 10.2.0 clang: 11.0.0 Packages: pacman: 1425 lib: 410 Shell: fish v: 3.1.2
I also noticed some lags when open multiple tabs in the browser and some folders in dolphin from the last 2 days...
I tried to disable Baloo File Extractor and now everything going smooth like before...
balooctl disable
This method just confirms the reason of your system's lag.
Unless you know what baloo is and really want to disable it, the normal way to deal with it is to let baloo run for a day, so the initial index is built. Then it will not affect this badly the system performance.
I noticed the same behavior under Cinnamon.
Start time Firefox 9s, Thunderbird 10s, other apps significantly slower than normal.
I tried the arch kernel, it works but I was unable to install as default kernel. It ended up in a complete desaster (urgend advice: donΒ΄t use grub customizer under garuda!!).
Then I installed Garuda Cinnamon, the latest iso 2021, on a brand new machine, everything went fine, but after the first update (300-400MB) the system shows the same (mis)behavior, it goes slow again
root=UUID=dea7c420-f294-4700-8b3b-62eed45701b7 rw rootflags=subvol=@ quiet
Desktop: Cinnamon 4.8.5 tk: GTK 3.24.24 wm: muffin dm: LightDM 1.30.0
Type: Desktop Mobo: ASUSTeK model: PRIME H310T R2.0 v: Rev X.0x
serial: <filter> UEFI: American Megatrends v: 1401 date: 04/01/2020
Device-1: hidpp_battery_0 model: Logitech Wireless Mouse MX Master
status: Discharging
Info: 6-Core model: Intel Core i5-9400 bits: 64 type: MCP arch: Kaby Lake
note: check family: 6 model-id: 9E (158) stepping: A (10) microcode: DE
L2 cache: 9 MiB
bogomips: 34831
Speed: 800 MHz min/max: 800/2900 MHz Core speeds (MHz): 1: 800 2: 800
3: 800 4: 800 5: 800 6: 801
Device-1: Intel UHD Graphics 630 vendor: ASUSTeK driver: i915 v: kernel
bus ID: 00:02.0 chip ID: 8086:3e92
Display: x11 server: X.Org 1.20.10 driver: intel unloaded: modesetting
alternate: fbdev,vesa display ID: :0 screens: 1
Monitor-1: HDMI2 res: 1920x1080 hz: 60 dpi: 92
size: 530x300mm (20.9x11.8") diag: 609mm (24")
OpenGL: renderer: Mesa Intel UHD Graphics 630 (CFL GT2) v: 4.6 Mesa 20.3.2
direct render: Yes
driver: snd_hda_intel v: kernel bus ID: 00:1f.3 chip ID: 8086:a2f0
vendor: ASUSTeK driver: r8169 v: kernel port: e000 bus ID: 02:00.0
chip ID: 10ec:8168
Device-2: Intel Wireless-AC 9260 driver: iwlwifi v: kernel port: e000
bus ID: 03:00.0 chip ID: 8086:2526
Device-3: Intel Wireless-AC 9260 Bluetooth Adapter type: USB driver: btusb
bus ID: 1-10:5 chip ID: 8087:0025
Local Storage: total: 931.51 GiB used: 61.47 GiB (6.6%)
model: SSD 970 EVO Plus 1TB size: 931.51 GiB block size: physical: 512 B
logical: 512 B speed: 31.6 Gb/s lanes: 4 serial: <filter> rev: 2B2QEXM7
temp: 31.9 C
ID-1: / raw size: 488.28 GiB size: 488.28 GiB (100.00%)
used: 61.47 GiB (12.6%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-2: /boot/efi raw size: 300 MiB size: 299.4 MiB (99.80%)
used: 560 KiB (0.2%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw size: 488.28 GiB size: 488.28 GiB (100.00%)
ID-4: /var/log raw size: 488.28 GiB size: 488.28 GiB (100.00%)
ID-5: /var/tmp raw size: 488.28 GiB size: 488.28 GiB (100.00%)
ID-1: swap-1 type: zram size: 2.58 GiB used: 0 KiB (0.0%) priority: 32767
ID-2: swap-2 type: zram size: 2.58 GiB used: 0 KiB (0.0%) priority: 32767
dev: /dev/zram1
ID-3: swap-3 type: zram size: 2.58 GiB used: 0 KiB (0.0%) priority: 32767
dev: /dev/zram2
ID-4: swap-4 type: zram size: 2.58 GiB used: 0 KiB (0.0%) priority: 32767
dev: /dev/zram3
ID-5: swap-5 type: zram size: 2.58 GiB used: 0 KiB (0.0%) priority: 32767
dev: /dev/zram4
ID-6: swap-6 type: zram size: 2.58 GiB used: 0 KiB (0.0%) priority: 32767
dev: /dev/zram5
System Temperatures: cpu: 29.8 C mobo: 27.8 C
Processes: 283 Uptime: 2m wakeups: 2 Memory: 15.51 GiB
used: 3.13 GiB (20.2%) Init: systemd v: 247 Compilers: gcc: 10.2.0
clang: 11.0.1 Packages: pacman: 1344 lib: 334 Shell: Zsh v: 5.8
running in: gnome-terminal inxi: 3.2.01
