i am new to garuda linux need support on installing forti client
There is an AUR package but it is out-of-date and orphaned.
Your best bet would probably be to try to update the PKGBUILD manually to the latest version.
I would do it for you but since it is proprietary software I have no way to test I can't help all that much.
how i can do it can you guide
so no option to install forti client
https://wiki.archlinux.org/title/creating_packages
You are on your own and your own risk too.
You modify this file, save it to a directory as PKGBUILD
. Then run makepkg -si
You can probably install it, but there is probably isn’t a simple way to do it since they don’t support Arch.
If you only need it for the VPN, there are alternatives.
