Foreign/AUR package info
I will start with inxi:
Kernel: 6.9.6-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 14.1.1
root=UUID=e69eb184-4f60-4c60-a81f-aa5e53e9580b rw rootflags=subvol=@
Desktop: KDE Plasma v: 6.1.1 tk: Qt v: N/A info: frameworks v: 6.3.0
Mobo: ASUSTeK model: ROG STRIX B650E-F GAMING WIFI v: Rev 1.xx
UEFI: American Megatrends v: 2616 date: 04/29/2024
Info: model: AMD Ryzen 7 7800X3D bits: 64 type: MT MCP arch: Zen 4 gen: 5
L3: 96 MiB desc: 1x96 MiB
Speed (MHz): avg: 2427 high: 4850 min/max: 545/5050 scaling:
driver: amd-pstate-epp governor: performance cores: 1: 545 2: 4849 3: 545
4: 4848 5: 4849 6: 4848 7: 545 8: 545 9: 545 10: 545 11: 4849 12: 4849
13: 545 14: 4850 15: 545 16: 545 bogomips: 134401
Device-1: AMD Navi 31 [Radeon RX 7900 XT/7900 XTX/7900M]
vendor: Sapphire NITRO+ driver: amdgpu v: kernel arch: RDNA-3 code: Navi-3x
process: TSMC n5 (5nm) built: 2022+ pcie: gen: 4 speed: 16 GT/s lanes: 16
ports: active: DP-1 empty: DP-2, HDMI-A-1, HDMI-A-2, Writeback-1
bus-ID: 03:00.0 chip-ID: 1002:744c class-ID: 0300
Device-2: AMD Raphael vendor: ASUSTeK driver: amdgpu v: kernel
gen: 4 speed: 16 GT/s lanes: 16 ports: active: none
empty: DP-3,HDMI-A-3,Writeback-2 bus-ID: 0e:00.0 chip-ID: 1002:164e
class-ID: 0300 temp: 44.0 C
gpu: amdgpu,amdgpu display-ID: 0
Monitor-1: DP-1 res: 2560x1440 size: N/A modes: N/A
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 24.1.2-arch1.1
navi31 LLVM 17.0.6 DRM 3.57 6.9.6-zen1-1-zen) device-ID: 1002:744c
memory: 23.44 GiB unified: no display-ID: :1.0
API: Vulkan v: 1.3.279 layers: 9 device: 0 type: discrete-gpu name: AMD
Radeon RX 7900 XTX (RADV NAVI31) driver: mesa radv v: 24.1.2-arch1.1
device-ID: 1002:744c surfaces: xcb,xlib,wayland device: 1
type: integrated-gpu name: AMD Radeon Graphics (RADV RAPHAEL_MENDOCINO)
driver: mesa radv v: 24.1.2-arch1.1 device-ID: 1002:164e
17.0.6 256 bits) driver: mesa llvmpipe v: 24.1.2-arch1.1 (LLVM 17.0.6)
Device-2: AMD Rembrandt Radeon High Definition Audio vendor: ASUSTeK
bus-ID: 0e:00.1 chip-ID: 1002:1640 class-ID: 0403
Device-3: ASUSTek USB Audio driver: hid-generic,snd-usb-audio,usbhid
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-6:2
API: ALSA v: k6.9.6-zen1-1-zen status: kernel-api with: aoss
gen: 2 speed: 5 GT/s lanes: 1 port: N/A bus-ID: 0a:00.0 chip-ID: 8086:15f3
Local Storage: total: 2.73 TiB used: 336.4 GiB (12.0%)
ID-1: /dev/nvme0n1 maj-min: 259:1 vendor: Samsung model: SSD 980 PRO 2TB
lanes: 4 tech: SSD serial: <filter> fw-rev: 5B2QGXA7 temp: 41.9 C
ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: Samsung model: SSD 980 PRO 1TB
lanes: 4 tech: SSD serial: <filter> fw-rev: 5B2QGXA7 temp: 40.9 C
ID-1: / raw-size: 1.82 TiB size: 1.82 TiB (100.00%) used: 155.36 GiB (8.3%)
fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:4
used: 584 KiB (0.2%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:3
used: 155.36 GiB (8.3%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:4
ID-1: swap-1 type: zram size: 62.02 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 51.9 C mobo: N/A
GPU: device: amdgpu temp: 44.0 C device: amdgpu temp: 45.0 C mem: 50.0 C
fan: 0 watts: 13.00
Memory: total: 64 GiB available: 62.02 GiB used: 4.4 GiB (7.1%)
Processes: 335 Power: uptime: 1h 0m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 24.8 GiB services: org_kde_powerdevil,upowerd
Packages: pm: pacman pkgs: 1557 libs: 474 tools: octopi,pacseek,paru
Compilers: clang: 17.0.6 gcc: 14.1.1 Shell: garuda-inxi default: fish
v: 3.7.1 running-in: konsole inxi: 3.3.35
System install date:     2024-01-25
Last full system update: 2024-06-28
Foreign/AUR package notification, I find things that seem to be remnants of the KDE Plasma 5.27 → 6.0 update (other than FreeFileSync installed by me). I remember these were not present before 6.0.
(2/6) Foreign/AUR package notification
freefilesync-bin 13.7-1
garuda-dr460nized-next 4.1.1-1
khotkeys 5.27.10-1
kwin-scripts-forceblur 0.6.1-1.3
plasma5-applets-eventcalendar 76-1.4
I just want want to know, if these are still needed/used. For educational purposes, of course.
That pacman hook is basically helping you in the second part of this maintenance task.
https://wiki.archlinux.org/title/System_maintenance#Check_for_orphans_and_dropped_packages
It is up to you to understand if you still need those packages. Usually not.
If they have been dropped from the Arch repo to the AUR, you can still use them. If they do not even appear in the AUR anymore, chances are they are no longer needed or don’t even work. The last chance is to retrieve them from their upstream site. But this would be really uncommon.
I thought not-needed or dropped packages would go to the Orphaned category. Those I understand can be removed (e.g. via the function in Garuda Assistant).
The issue is I do not know if these have currently any real function and if they can break things.
I will double check the link you have posted. Thanks.
