Ever since Foot went from 1.20 to 1.21, the terminal emulator windows opens, but renders nothing. I type ‘exit’ and it closes as expected, again no rendering of text from me or the machine. Attached is my garuda-inxi output. I tried to go to a minimal config for foot, but this didn’t work. Alacritty and Kitty work fine. I have adjusted my pacman config to ignore Foot for now for upgrades. All other steps up to wl_surface_commit show up in logs for Foot. Where should I post this bug for Foot? Thank you.
Kernel: 6.13.8-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc
v: 14.2.1 clocksource: tsc avail: hpet,acpi_pm
root=UUID=09a492ac-b858-4712-bd5e-55521edd101f rw
rootflags=subvol=@ quiet loglevel=3 ibt=off
Desktop: Hyprland v: 0.48.1 with: waybar tools:
avail: swayidle,swaylock vt: 1 dm: SDDM Distro: Garuda
Type: Laptop System: LENOVO product: 861469B v: ThinkPad T430u
serial: <superuser required> Chassis: type: 10
Mobo: LENOVO model: 861469B v: Win8 STD DPK TPG
serial: <superuser required> part-nu: LENOVO_MT_8614
uuid: <superuser required> UEFI: LENOVO v: H6ET65WW (2.06 )
date: 11/09/2012
ID-1: BAT1 charge: 17.0 Wh (44.0%) condition: 38.6/46.8 Wh (82.3%)
power: 23.3 W volts: 10.7 min: 11.1 model: SONY 45N1091
type: Li-poly serial: <filter> status: discharging
Info: model: Intel Core i7-3517U bits: 64 type: MT MCP
arch: Ivy Bridge gen: core 3 level: v2 built: 2012-15
process: Intel 22nm family: 6 model-id: 0x3A (58) stepping: 9
microcode: 0x21
Topology: cpus: 1x dies: 1 clusters: 2 cores: 2 threads: 4
tpc: 2 smt: enabled cache: L1: 128 KiB
desc: d-2x32 KiB; i-2x32 KiB L2: 512 KiB desc: 2x256 KiB
L3: 4 MiB desc: 1x4 MiB
Speed (MHz): avg: 1261 min/max: 800/3000 scaling:
driver: intel_cpufreq governor: schedutil cores: 1: 1261 2: 1261
3: 1261 4: 1261 bogomips: 19155
Flags: avx ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3
Device-1: Intel 3rd Gen Core processor Graphics vendor: Lenovo
driver: i915 v: kernel arch: Gen-7 process: Intel 22nm
built: 2012-13 ports: active: eDP-1 empty: DP-1, DP-2,
HDMI-A-1, HDMI-A-2 bus-ID: 00:02.0 chip-ID: 8086:0166
Device-2: NVIDIA GF117M [GeForce 610M/710M/810M/820M / GT
620M/625M/630M/720M] vendor: Lenovo driver: N/A
alternate: nouveau, nvidia_drm, nvidia non-free: series: 390.xx+
status: legacy (EOL~2022-11-22) last: release: 390.157
kernel: 6.0 xorg: 1.21 arch: Fermi code: GF1xx process: 40/28nm
built: 2010-2016 pcie: gen: 1 speed: 2.5 GT/s lanes: 8 link-max:
lanes: 16 bus-ID: 01:00.0 chip-ID: 10de:1140 class-ID: 0302
Device-3: Chicony Integrated Camera driver: uvcvideo type: USB
rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 2-4:2
chip-ID: 04f2:b327 class-ID: 0e02 serial: <filter>
Display: wayland server: X.org v: 1.21.1.16 with: Xwayland
v: 24.1.6 compositor: Hyprland v: 0.48.1 driver: X:
loaded: modesetting alternate: fbdev,intel,vesa dri: crocus
gpu: i915 display-ID: 1
Monitor-1: eDP-1 model: AU Optronics 0x253c built: 2012 res:
mode: 1366x768 hz: 60 scale: 100% (1) dpi: 112 gamma: 1.2
size: 309x173mm (12.17x6.81") diag: 354mm (13.9") ratio: 16:9
modes: 1366x768
API: Vulkan v: 1.4.309 layers: 7 device: 0 type: integrated-gpu
name: Intel HD Graphics 4000 (IVB GT2) driver: N/A
device-ID: 8086:0166 surfaces: xcb,xlib,wayland device: 1
type: cpu name: llvmpipe (LLVM 19.1.7 256 bits) driver: N/A
Info: Tools: api: vulkaninfo gpu: nvidia-settings,nvidia-smi
wl: kanshi, wdisplays, wlr-randr x11: xprop,xrandr
vendor: Lenovo driver: snd_hda_intel v: kernel bus-ID: 00:1b.0
API: ALSA v: k6.13.8-zen1-1-zen status: kernel-api tools: N/A
Server-1: sndiod v: N/A status: off
tools: aucat,midicat,sndioctl
Server-2: PipeWire v: 1.4.1 status: active with:
Device-1: Intel Centrino Wireless-N 2230 driver: iwlwifi v: kernel
pcie: gen: 1 speed: 2.5 GT/s lanes: 1 bus-ID: 03:00.0
chip-ID: 8086:0888 class-ID: 0280
Device-2: Realtek RTL8111/8168/8211/8411 PCI Express Gigabit
Ethernet vendor: Lenovo driver: r8169 v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 port: 3000 bus-ID: 09:00.0
Info: services: NetworkManager, systemd-timesyncd,
wpa_supplicant
Device-1: Intel Centrino Bluetooth Wireless Transceiver
driver: btusb v: 0.8 type: USB rev: 2.0 speed: 12 Mb/s lanes: 1
mode: 1.1 bus-ID: 3-1.5:3 chip-ID: 8087:07da class-ID: e001
Report: btmgmt ID: hci0 rfk-id: 2 state: up address: <filter>
bt-v: 4.0 lmp-v: 6 status: discoverable: no pairing: no
class-ID: 6c010c
Local Storage: total: 1.14 TiB used: 28.24 GiB (2.4%)
SMART Message: Required tool smartctl not installed. Check
--recommends
ID-1: /dev/sda maj-min: 8:0 vendor: HGST (Hitachi)
model: HTS541010A9E680 size: 931.51 GiB block-size:
physical: 4096 B logical: 512 B speed: 6.0 Gb/s tech: HDD
rpm: 5400 serial: <filter> fw-rev: B600 scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: Orico model: N/A
size: 238.47 GiB block-size: physical: 512 B logical: 512 B
speed: 3.0 Gb/s tech: SSD serial: <filter> fw-rev: 4A0
used: 28.24 GiB (11.9%) fs: btrfs dev: /dev/sdb2 maj-min: 8:18
used: 608 KiB (0.2%) fs: vfat dev: /dev/sdb1 maj-min: 8:17
zswap: no
ID-1: swap-1 type: zram size: 15.46 GiB used: 0 KiB (0.0%)
max-streams: 4 dev: /dev/zram0
System Temperatures: cpu: 59.0 C mobo: 40.0 C
Fan Speeds (rpm): cpu: 3348 fan-2: 3348
Memory: total: 16 GiB available: 15.46 GiB used: 2.94 GiB (19.0%)
Processes: 193 Power: uptime: 1h 57m states: freeze,mem,disk
suspend: deep avail: s2idle wakeups: 0 hibernate: platform
avail: shutdown, reboot, suspend, test_resume image: 6.12 GiB
services: upowerd Init: systemd v: 257 default: graphical
Packages: pm: pacman pkgs: 1930 libs: 466
tools: octopi,pacseek,paru Compilers: clang: 19.1.7 gcc: 14.2.1
Shell: garuda-inxi default: Bash v: 5.2.37 running-in: kitty
inxi: 3.3.37
System install date: 2025-01-27
Last full system update: 2025-04-02
