tl;dr
You can not set appearance on anything running on XScreens other than 0.0.
inxi -Faz Output:
Kernel: 5.10.79-1-lts x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=b0e4d9bb-6152-4407-bf73-0dbf7d629019 rw [email protected] quiet
Desktop: Xfce 4.16.0 tk: Gtk 3.24.29 info: xfce4-panel wm: xfwm 4.16.1
vt: 7 dm: LightDM 1.30.0 Distro: Garuda Linux base: Arch Linux
Type: Desktop Mobo: Micro-Star model: B450 TOMAHAWK (MS-7C02) v: 1.0
serial: <filter> UEFI: American Megatrends LLC. v: 1.H5 date: 04/22/2021
Info: 8-Core model: AMD Ryzen 7 2700X bits: 64 type: MT MCP arch: Zen+
family: 17 (23) model-id: 8 stepping: 2 microcode: 800820D cache:
L2: 4 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm
bogomips: 118401
Speed: 3441 MHz min/max: 2200/3700 MHz boost: enabled Core speeds (MHz):
1: 3441 2: 4221 3: 3956 4: 4130 5: 3207 6: 4218 7: 4264 8: 4250 9: 3660
10: 3542 11: 3430 12: 4226 13: 4072 14: 4154 15: 3557 16: 4070
Type: spectre_v2 mitigation: Full AMD retpoline, IBPB: conditional, STIBP:
disabled, RSB filling
Device-1: NVIDIA GP106 [GeForce GTX 1060 6GB] vendor: ZOTAC driver: nvidia
v: 495.44 alternate: nouveau,nvidia_drm bus-ID: 25:00.0 chip-ID: 10de:1c03
Device-2: NVIDIA TU116 [GeForce GTX 1660] vendor: ZOTAC driver: nvidia
v: 495.44 alternate: nouveau,nvidia_drm bus-ID: 26:00.0 chip-ID: 10de:2184
Display: x11 server: X.Org 1.21.1.1 compositor: xfwm4 v: 4.16.1 driver:
loaded: nvidia display-ID: :0.0 screens: 3 default screen: 0
Screen-1: 0 s-res: 5760x1080 s-dpi: 96 s-size: 1524x286mm (60.0x11.3")
s-diag: 1551mm (61")
Monitor-1: DP-0 res: 1920x1080 hz: 60 dpi: 93 size: 527x296mm (20.7x11.7")
diag: 604mm (23.8")
Monitor-2: DP-2 res: 1920x1080 hz: 60 dpi: 93 size: 527x296mm (20.7x11.7")
diag: 604mm (23.8")
Monitor-3: DP-4 res: 1920x1080 hz: 60 dpi: 93 size: 527x296mm (20.7x11.7")
diag: 604mm (23.8")
Screen-2: 1 s-res: 5760x1080 s-dpi: 95 s-size: 1540x292mm (60.6x11.5")
s-diag: 1567mm (61.7")
Screen-3: 2 s-res: 1280x1024 s-dpi: 85 s-size: 382x302mm (15.0x11.9")
s-diag: 487mm (19.2")
OpenGL: renderer: NVIDIA GeForce GTX 1660/PCIe/SSE2 v: 4.6.0 NVIDIA 495.44
direct render: Yes
Device-1: NVIDIA GP106 High Definition Audio vendor: ZOTAC
driver: snd_hda_intel v: kernel bus-ID: 25:00.1 chip-ID: 10de:10f1
Device-2: NVIDIA TU116 High Definition Audio vendor: ZOTAC
driver: snd_hda_intel v: kernel bus-ID: 26:00.1 chip-ID: 10de:1aeb
Device-3: Focusrite-Novation Scarlett 6i6 type: USB driver: snd-usb-audio
bus-ID: 1-8:3 chip-ID: 1235:8012 class-ID: fe01 serial: <filter>
Sound Server-1: ALSA v: k5.10.79-1-lts running: yes
vendor: Micro-Star MSI driver: r8169 v: kernel port: e000 bus-ID: 22:00.0
Supported mdraid levels: raid0
Device-1: md127 maj-min: 9:127 type: mdraid level: raid-0 status: active
Info: report: N/A blocks: 1953258496 chunk-size: 512k super-blocks: 1.2
Components: Online:
0: sda1 maj-min: 8:1 size: 931.51 GiB
1: sdb1 maj-min: 8:17 size: 931.51 GiB
Local Storage: total: 3.87 TiB used: 1.97 TiB (51.0%)
model: WDS250G1B0C-00S6U0 size: 232.89 GiB block-size: physical: 512 B
rev: 201000WD temp: 38.9 C scheme: GPT
model: WD1003FZEX-00K3CA0 size: 931.51 GiB block-size: physical: 4096 B
rev: 1A01 scheme: MBR
model: WD10EFRX-68PJCN0 size: 931.51 GiB block-size: physical: 4096 B
ID-5: /dev/sdd maj-min: 8:48 vendor: Western Digital
ID-1: / raw-size: 232.38 GiB size: 232.38 GiB (100.00%)
used: 9.66 GiB (4.2%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
used: 576 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 1.82 TiB size: 1.79 TiB (98.38%)
used: 601.66 GiB (32.8%) fs: ext4 dev: /dev/md127p1 maj-min: 259:3
ID-1: swap-1 type: zram size: 62.79 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 44.9 C mobo: N/A
GPU: device: nvidia screen: :0.0 temp: 38 C fan: 38% device: nvidia
screen: :0.1 temp: 38 C fan: 38% device: nvidia screen: :0.2 temp: 38 C
fan: 38%
Processes: 426 Uptime: 21m wakeups: 0 Memory: 62.8 GiB
used: 4.77 GiB (7.6%) Init: systemd v: 249 tool: systemctl Compilers:
gcc: 11.1.0 Packages: pacman: 1288 lib: 347 Shell: Bash v: 5.1.8
running-in: sakura inxi: 3.3.08
This isn't a Garuda specific issue but Garuda XFCE4 is the most functional I've come across since moving from Ubuntu 18.04. I am simply hoping someone can shed some light on what's going on and where the issue actually lies.
Themeing is broken on any xfce newer than 4.12. I've seen the code change where they stopped enumerating XScreens. I was hoping someone here might be able to help point me in the direction of actually fixing this and perhaps even submitting a patch, something I've never done before.
