Hello.
got question regarding strange section at prompt [x!+?⇡1]
and [?]
looks like fish didn't recognize something, the question is what it could be or how to fine out with what is a problem.
1:
buzz@irene in repo: pywk on Python-3-upgrade-pywk [x!+?⇡1] via C v11.2.0-gcc via v3.4.10 took 1ms
λ
2:
buzz@irene in repo: pydm on Python-3-upgrade-pydm [?] via C v11.2.0-gcc via v2.7.18 took 2ms
λ
3:
buzz@irene in repo: scu on devel [?] is v1.0.0 via v17.9.0 via v2.7.18 took 1m11s
λ
Info/details:
Kernel: 5.17.5-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 11.2.0
root=UUID=15bd7acf-661b-457d-8d48-494219975754 rw rootflags=subvol=@
quiet
cryptdevice=UUID=6e618d74-4f05-41f1-a708-452600471782:luks-6e618d74-4f05-41f1-a708-452600471782
root=/dev/mapper/luks-6e618d74-4f05-41f1-a708-452600471782 splash
resume=/dev/mapper/luks-768f9eec-67f8-4a93-9ed8-d6503c5366a8 loglevel=3
Type: Laptop System: HP product: HP ProBook 640 G2 v: N/A
Mobo: HP model: 80FD v: KBC Version 22.74 serial: <superuser required>
UEFI: HP v: N76 Ver. 01.53 date: 11/19/2021
ID-1: BAT0 charge: 33.5 Wh (95.7%) condition: 35.0/48.0 Wh (72.9%)
volts: 12.6 min: 11.4 model: Hewlett-Packard Primary type: Li-ion
serial: <filter> status: N/A cycles: 135
Device-1: hidpp_battery_5 model: Logitech MX Ergo Multi-Device Trackball
Info: model: Intel Core i5-6200U bits: 64 type: MT MCP arch: Skylake
family: 6 model-id: 0x4E (78) stepping: 3 microcode: 0xEC
L3: 3 MiB desc: 1x3 MiB
Speed (MHz): avg: 2129 high: 2390 min/max: 400/2800 scaling:
driver: intel_pstate governor: powersave cores: 1: 2024 2: 2123 3: 1981
4: 2390 bogomips: 19200
Type: l1tf
Device-1: Intel Skylake GT2 [HD Graphics 520] vendor: Hewlett-Packard
driver: i915 v: kernel ports: active: DP-3,DP-4,eDP-1
empty: DP-1, DP-2, DP-5, HDMI-A-1, HDMI-A-2 bus-ID: 00:02.0
chip-ID: 8086:1916 class-ID: 0300
Device-2: Z-Star Micro Venus USB2.0 Camera type: USB
driver: snd-usb-audio,uvcvideo bus-ID: 1-4.1:5 chip-ID: 0ac8:3420
Screen-1: 0 s-res: 6400x1440 s-dpi: 96 s-size: 1693x381mm (66.65x15.00")
s-diag: 1735mm (68.32")
Monitor-1: not-matched mapped: DP-1-1 pos: primary,top-center
res: 2560x1440 hz: 60 dpi: 109 size: 598x336mm (23.54x13.23")
diag: 686mm (27.01") modes: N/A
Monitor-2: not-matched mapped: DP-1-2 pos: bottom-r res: 1920x1080 hz: 60
dpi: 93 size: 527x296mm (20.75x11.65") diag: 604mm (23.8") modes: N/A
Monitor-3: eDP-1 pos: bottom-l model: ChiMei InnoLux 0x14c0 built: 2015
res: 1920x1080 hz: 60 dpi: 158 gamma: 1.2 size: 308x173mm (12.13x6.81")
diag: 353mm (13.9") ratio: 16:9 modes: 1920x1080
OpenGL: renderer: Mesa Intel HD Graphics 520 (SKL GT2) v: 4.6 Mesa 22.0.2
direct render: Yes
Device-3: GN Netcom Jabra EVOLVE LINK type: USB
driver: jabra,snd-usb-audio,usbhid bus-ID: 1-4.4:10 chip-ID: 0b0e:0306
Sound Server-1: ALSA v: k5.17.5-zen1-1-zen running: yes
Device-1: Intel Ethernet I219-V vendor: Hewlett-Packard driver: e1000e
v: kernel port: N/A bus-ID: 00:1f.6 chip-ID: 8086:1570 class-ID: 0200
IF: enp0s31f6 state: up speed: 100 Mbps duplex: full mac: <filter>
Device-2: Intel Wireless 8260 driver: iwlwifi v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 bus-ID: 02:00.0 chip-ID: 8086:24f3 class-ID: 0280
Device-3: Lenovo USB-C Hub type: USB driver: r8152 bus-ID: 2-5.1:6
chip-ID: 17ef:7214 class-ID: 0000 serial: <filter>
IF: enp0s20f0u5u1 state: down mac: <filter>
IF-ID-1: br-26cc310318fc state: up speed: 10000 Mbps duplex: unknown
mac: <filter>
IF-ID-2: br-9e6bd9d88473 state: down mac: <filter>
IF-ID-3: docker0 state: down mac: <filter>
IF-ID-4: veth2073bc9 state: up speed: 10000 Mbps duplex: full
mac: <filter>
IF-ID-5: veth221c9a4 state: up speed: 10000 Mbps duplex: full
mac: <filter>
IF-ID-6: veth8f9f390 state: up speed: 10000 Mbps duplex: full
mac: <filter>
IF-ID-7: vethb1c9ddf state: up speed: 10000 Mbps duplex: full
mac: <filter>
IF-ID-8: vethce4bcee state: up speed: 10000 Mbps duplex: full
mac: <filter>
bus-ID: 1-7:6 chip-ID: 8087:0a2b class-ID: e001
address: <filter>
Local Storage: total: 238.47 GiB used: 68.74 GiB (28.8%)
ID-1: /dev/sda maj-min: 8:0 vendor: SanDisk model: SD8SN8U-256G-1006
size: 238.47 GiB block-size: physical: 4096 B logical: 512 B
speed: 6.0 Gb/s type: SSD serial: <filter> rev: 0006 scheme: GPT
ID-1: / raw-size: 221.22 GiB size: 221.22 GiB (100.00%)
used: 68.74 GiB (31.1%) fs: btrfs dev: /dev/dm-0 maj-min: 254:0
mapped: luks-6e618d74-4f05-41f1-a708-452600471782
used: 720 KiB (0.2%) fs: vfat dev: /dev/sda1 maj-min: 8:1
ID-3: /home raw-size: 221.22 GiB size: 221.22 GiB (100.00%)
ID-4: /var/log raw-size: 221.22 GiB size: 221.22 GiB (100.00%)
ID-5: /var/tmp raw-size: 221.22 GiB size: 221.22 GiB (100.00%)
ID-1: swap-1 type: zram size: 15.04 GiB used: 3.65 GiB (24.3%)
ID-2: swap-2 type: partition size: 16.95 GiB used: 0 KiB (0.0%)
mapped: luks-768f9eec-67f8-4a93-9ed8-d6503c5366a8
System Temperatures: cpu: 42.0 C pch: 39.0 C mobo: 0.0 C
Processes: 322 Uptime: 1d 13h 39m wakeups: 64 Memory: 15.04 GiB
used: 11.27 GiB (74.9%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.2.0 clang: 13.0.1 Packages: pacman: 1415 lib: 338 Shell: fish
v: 3.4.1 default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.15
Garuda (2.6.2-1):
System install date: 2022-02-08
Last full system update: 2022-04-29
Failed units: mnt-flap_movies.mount
