With a fresh installation of Garuda, Fish shell takes 3 seconds to load. That should be instantaneous.
There are discussions about this issue here., but IMO that shouldn't happen out-of-the-box with Garuda.
Do you post in the correct forum?
If, post your inxi -Faz, please and which terminal you use.
Hello.
inxi -Faz
System: Kernel: 5.15.5-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-zen root=UUID=58203bda-e2e2-4c32-a00
6-c91d933cad4e
rw [email protected] quiet splash rd.udev.log_priority=3 vt.global_cursor_defaul
t=0
Desktop: KDE Plasma 5.23.3 tk: Qt 5.15.2 info: latte-dock wm: kwin_x11 vt: 1 dm:
SDDM
Machine: Type: Laptop System: Acer product: Predator PH315-53 v: V1.01 serial:
Mobo: CML model: QX50_CMS v: V1.01 serial: UEFI: Insyde v: 1
.01
date: 04/27/2020
Battery: ID-1: BAT1 charge: 43.7 Wh (99.8%) condition: 43.8/58.8 Wh (74.6%) volts: 16.4 mi
n: 15.4
model: SMP AP18E7M type: Li-ion serial: status: Unknown
CPU: Info: 6-Core model: Intel Core i7-10750H bits: 64 type: MT MCP arch: Comet Lake f
amily: 6
model-id: A5 (165) stepping: 2 microcode: EA cache: L1: 384 KiB L2: 1.5 MiB L3: 1
2 MiB
flags: avx avx2 ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 6239
9
Speed: 4588 MHz min/max: 800/5000 MHz Core speeds (MHz): 1: 4588 2: 4694 3: 4650
4: 4673
5: 4662 6: 4442 7: 4680 8: 4690 9: 4571 10: 4703 11: 4599 12: 3808
Type: spectre_v1 mitigation: usercopy/swapgs barriers and __user pointer sanitiza
tion
Graphics: Device-1: Intel CometLake-H GT2 [UHD Graphics] vendor: Acer Incorporated ALI driv
er: i915
v: kernel bus-ID: 00:02.0 chip-ID: 8086:9bc4 class-ID: 0300
Device-2: NVIDIA TU106M [GeForce RTX 2060 Mobile] vendor: Acer Incorporated ALI d
river: nvidia
v: 495.44 alternate: nouveau,nvidia_drm bus-ID: 01:00.0 chip-ID: 10de:1f15 class-
Device-3: Quanta HD User Facing type: USB driver: uvcvideo bus-ID: 1-5:4 chip-ID:
0408:a061
class-ID: 0e02
Display: x11 server: [X.Org](http://X.Org) 1.21.1.1 compositor: kwin_x11 driver: loaded: modesett
ing,nvidia
Screen-1: 0 s-res: 1920x1080 s-dpi: 96 s-size: 508x285mm (20.0x11.2") s-diag: 582
mm (22.9")
Monitor-1: eDP-1 res: 1920x1080 hz: 144 dpi: 142 size: 344x194mm (13.5x7.6")
diag: 395mm (15.5")
OpenGL: renderer: Mesa Intel UHD Graphics (CML GT2) v: 4.6 Mesa 21.2.5 direct ren
der: Yes
Audio: Device-1: Intel Comet Lake PCH cAVS vendor: Acer Incorporated ALI driver: snd_hda
_intel
v: kernel alternate: snd_soc_skl,snd_sof_pci_intel_cnl bus-ID: 00:1f.3 chip-ID: 8
086:06c8
Device-2: NVIDIA TU106 High Definition Audio driver: snd_hda_intel v: kernel bus-
chip-ID: 10de:10f9 class-ID: 0403
Device-3: Texas Instruments PCM2900B Audio CODEC type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 1-3:3 chip-ID: 08bb:29b0 class-I
D: 0300
Sound Server-1: ALSA v: k5.15.5-zen1-1-zen running: yes
Network: Device-1: Intel Comet Lake PCH CNVi WiFi vendor: Rivet Networks driver: iwlwifi v
: kernel
IF: wlp0s20f3 state: up mac:
Device-2: Realtek vendor: Acer Incorporated ALI driver: r8169 v: kernel port: 300
0
bus-ID: 07:00.0 chip-ID: 10ec:2600 class-ID: 0200
IF: enp7s0 state: down mac:
IF-ID-1: anbox0 state: down mac:
Bluetooth: Device-1: Intel AX201 Bluetooth type: USB driver: btusb v: 0.8 bus-ID: 1-14:5
chip-ID: 8087:0026 class-ID: e001
Report: bt-adapter ID: hci0 rfk-id: 1 state: down bt-service: enabled,running rfk
-block:
hardware: no software: yes address:
Drives: Local Storage: total: 1.63 TiB used: 328.76 GiB (19.7%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Western Digital model: PC SN730 SDBQNTY
-512G-1014
size: 476.94 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s lane
s: 4 type: SSD
serial: rev: 11101100 temp: 24.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: HGST (Hitachi) model: HTS721010A9E630 size: 9
31.51 GiB
serial: rev: A3J0 scheme: GPT
ID-3: /dev/sdb maj-min: 8:16 vendor: Crucial model: CT275MX300SSD4 size: 256.17 G
iB block-size:
physical: 512 B logical: 512 B speed: 6.0 Gb/s type: SSD serial: rev: R0
60 scheme: GPT
Partition: ID-1: / raw-size: 112.61 GiB size: 112.61 GiB (100.00%) used: 24.49 GiB (21.7%) f
s: btrfs
ID-2: /boot/efi raw-size: 100 MiB size: 96 MiB (96.00%) used: 51.2 MiB (53.4%) fs
: vfat
ID-3: /home raw-size: 112.61 GiB size: 112.61 GiB (100.00%) used: 24.49 GiB (21.7
%) fs: btrfs
ID-4: /var/log raw-size: 112.61 GiB size: 112.61 GiB (100.00%) used: 24.49 GiB (2
1.7%)
ID-5: /var/tmp raw-size: 112.61 GiB size: 112.61 GiB (100.00%) used: 24.49 GiB (2
1.7%)
ID-1: swap-1 type: zram size: 15.46 GiB used: 4.8 MiB (0.0%) priority: 100 dev: /
dev/zram0
Sensors: System Temperatures: cpu: 61.0 C pch: 57.0 C mobo: N/A
Info: Processes: 343 Uptime: 37m wakeups: 1 Memory: 15.46 GiB used: 6.92 GiB (44.8%) In
it: systemd
v: 249 tool: systemctl Compilers: gcc: 11.1.0 clang: 13.0.0 Packages: pacman: 153
8 lib: 411
Shell: fish v: 3.3.1 default: Bash v: 5.1.12 running-in: konsole inxi: 3.3.09
