Firmware security
Hello:
I was browsing through my device information and I happened to notice that under Firmware Security - Info center, Runtimte Suffix -!, Linux Kernel shows tainted.
Does anyone have any information as to why it would show tainted?
No garuda-inxi?
Kernel: 6.1.10-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
root=UUID=67aa51fa-b43d-4853-9719-27ab7e11d7d5 rw [email protected]
quiet
cryptdevice=UUID=b8883085-70cf-4bd8-94b3-897da600175f:luks-b8883085-70cf-4bd8-94b3-897da600175f
root=/dev/mapper/luks-b8883085-70cf-4bd8-94b3-897da600175f quiet splash
resume=/dev/mapper/luks-baad57bc-815f-42a1-9b08-7b7975c4484c loglevel=3
Type: Laptop System: Micro-Star product: Please change product name
v: REV:1.0 serial: <superuser required> Chassis: type: 10
Mobo: Micro-Star model: MS-17G1 v: REV:1.0 serial: <superuser required>
UEFI: American Megatrends v: E17G1IMS.111 date: 05/18/2020
ID-1: BAT1 charge: 54.2 Wh (100.0%) condition: 54.2/80.3 Wh (67.5%)
volts: 16.1 min: 15.2 model: MSI BIF0_9 type: Li-ion serial: N/A
status: full
L3: 12 MiB desc: 1x12 MiB
Speed (MHz): avg: 2600 min/max: 800/4500 scaling: driver: intel_pstate
governor: performance cores: 1: 2600 2: 2600 3: 2600 4: 2600 5: 2600 6: 2600
7: 2600 8: 2600 9: 2600 10: 2600 11: 2600 12: 2600 bogomips: 62399
Device-1: Intel CoffeeLake-H GT2 [UHD Graphics 630] vendor: Micro-Star MSI
ports: active: eDP-1 empty: none bus-ID: 0000:00:02.0 chip-ID: 8086:3e9b
Device-2: NVIDIA TU106M [GeForce RTX 2070 Mobile] vendor: Micro-Star MSI
driver: nvidia v: 525.89.02 alternate: nouveau,nvidia_drm non-free: 525.xx+
status: current (as of 2023-02) arch: Turing code: TUxxx
process: TSMC 12nm FF built: 2018-22 bus-ID: 0000:01:00.0
chip-ID: 10de:1f10 class-ID: 0300
Device-3: Acer HD Webcam type: USB driver: uvcvideo bus-ID: 1-11:3
chip-ID: 5986:211c class-ID: 0e02
Display: x11 server: X.Org v: 21.1.7 with: Xwayland v: 22.1.7
Monitor-1: eDP-1 model: ChiMei InnoLux 0x175c built: 2018 res: 1920x1080
hz: 144 dpi: 128 gamma: 1.2 size: 381x214mm (15x8.43") diag: 437mm (17.2")
ratio: 16:9 modes: 1920x1080
API: OpenGL v: 4.6 Mesa 22.3.4 renderer: Mesa Intel UHD Graphics 630 (CFL
GT2) direct-render: Yes
bus-ID: 0000:00:1f.3 chip-ID: 8086:a348 class-ID: 0403
Device-2: NVIDIA TU106 High Definition Audio vendor: Micro-Star MSI
driver: snd_hda_intel v: kernel bus-ID: 0000:01:00.1 chip-ID: 10de:10f9
Sound API: ALSA v: k6.1.10-zen1-1-zen running: yes
bus-ID: 0000:00:14.3 chip-ID: 8086:a370 class-ID: 0280
Device-2: Qualcomm Atheros Killer E2500 Gigabit Ethernet
vendor: Micro-Star MSI driver: alx v: kernel port: 3000 bus-ID: 0000:03:00.0
chip-ID: 1969:e0b1 class-ID: 0200
driver: btusb v: 0.8 bus-ID: 1-14:4 chip-ID: 8087:0aaa class-ID: e001
driver: intel_nvme_remap v: N/A port: 5060 bus-ID: 0000:00:17.0
chip-ID: 8086:282a rev: N/A class-ID: 0104
Local Storage: total: 2.91 TiB used: 30.16 GiB (1.0%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Apacer model: APS-SE20G-2T
size: 1.86 TiB block-size: physical: 512 B logical: 512 B type: SSD
serial: <filter> rev: ECFM12.3 temp: 24.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:4 vendor: Western Digital
model: PC SN720 SDAPNTW-1T00 size: 953.87 GiB block-size: physical: 512 B
logical: 512 B type: SSD serial: <filter> rev: 10126000 temp: 31.9 C
ID-3: /dev/sda maj-min: 8:0 vendor: SanDisk model: X600 M.2 2280 SATA
128GB size: 119.24 GiB block-size: physical: 512 B logical: 512 B
speed: 6.0 Gb/s type: SSD serial: <filter> rev: 3012 scheme: GPT
ID-1: / raw-size: 84.7 GiB size: 84.7 GiB (100.00%) used: 30.16 GiB (35.6%)
mapped: luks-b8883085-70cf-4bd8-94b3-897da600175f
used: 756 KiB (0.2%) fs: vfat dev: /dev/sda1 maj-min: 8:1
ID-3: /home raw-size: 84.7 GiB size: 84.7 GiB (100.00%)
used: 30.16 GiB (35.6%) fs: btrfs dev: /dev/dm-0 maj-min: 254:0
ID-4: /var/log raw-size: 84.7 GiB size: 84.7 GiB (100.00%)
ID-5: /var/tmp raw-size: 84.7 GiB size: 84.7 GiB (100.00%)
ID-1: swap-1 type: zram size: 31.2 GiB used: 0 KiB (0.0%) priority: 100
ID-2: swap-2 type: partition size: 34.25 GiB used: 0 KiB (0.0%)
mapped: luks-baad57bc-815f-42a1-9b08-7b7975c4484c
System Temperatures: cpu: 50.0 C pch: 46.0 C mobo: N/A
Processes: 329 Uptime: 1m wakeups: 2 Memory: 31.2 GiB used: 2.67 GiB (8.6%)
Init: systemd v: 252 default: graphical tool: systemctl Compilers:
gcc: 12.2.1 Packages: pm: pacman pkgs: 2012 libs: 559 tools: octopi,paru
Shell: fish v: 3.6.0 default: Bash v: 5.1.16 running-in: konsole
inxi: 3.3.25
Garuda (2.6.14-1):
System install date:     2023-02-09
Last full system update: 2023-02-09
@garuda-team
Sorry about the garuda-inxi. I posted it.
I am going to reinstall Garuda. I feel that it may be due to a BIOS update. I originally bricked my BIOS, then re-flashed my BIOS chip, then restarted both Windows and Garuda.
The reason why I I tried to upgrade my BIOS is because I was trying to fix my WiFi NIC not visible issue that comes up after I put my laptop to sleep.
I will check back in to see if tainted kernel issue gets resolved after a fresh install.
After reinstalling Garuda Linux, I still see linux kernel tainted.
root=UUID=66167e93-fb50-4f9e-9453-79c6b74c8f5c rw [email protected]
quiet
cryptdevice=UUID=147de0aa-3a42-40f0-b555-5ff045190f5e:luks-147de0aa-3a42-40f0-b555-5ff045190f5e
root=/dev/mapper/luks-147de0aa-3a42-40f0-b555-5ff045190f5e quiet splash
resume=/dev/mapper/luks-06d0d64e-bfb6-485c-855c-cebcc2115ee8 loglevel=3
Desktop: KDE Plasma v: 5.26.1 tk: Qt v: 5.15.6 info: latte-dock
status: full
Speed (MHz): avg: 3847 high: 4103 min/max: 800/4500 scaling:
driver: intel_pstate governor: performance cores: 1: 4103 2: 4101 3: 4087
4: 4099 5: 2600 6: 2600 7: 4100 8: 4100 9: 4091 10: 4098 11: 4100
12: 4094 bogomips: 62399
vulnerable
PBRSB-eIBRS: Not affected
driver: nvidia v: 520.56.06 alternate: nouveau,nvidia_drm non-free: 515.xx+
process: TSMC 12nm built: 2018-22 bus-ID: 0000:01:00.0 chip-ID: 10de:1f10
OpenGL: renderer: Mesa Intel UHD Graphics 630 (CFL GT2) v: 4.6 Mesa
22.2.1 direct render: Yes
alternate: snd_soc_skl,snd_sof_pci_intel_cnl bus-ID: 0000:00:1f.3
bus-ID: 0000:03:00.0 chip-ID: 1969:e0b1 class-ID: 0200
Local Storage: total: 2.91 TiB used: 14.58 GiB (0.5%)
serial: <filter> rev: ECFM12.3 temp: 27.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:4 vendor: Western Digital model: PC SN720
SDAPNTW-1T00 size: 953.87 GiB block-size: physical: 512 B logical: 512 B
type: SSD serial: <filter> rev: 10126000 temp: 42.9 C scheme: GPT
ID-1: / raw-size: 84.63 GiB size: 84.63 GiB (100.00%) used: 14.58 GiB
(17.2%) fs: btrfs dev: /dev/dm-0 maj-min: 254:0
mapped: luks-147de0aa-3a42-40f0-b555-5ff045190f5e
ID-2: /boot/efi raw-size: 300 MiB size: 299.4 MiB (99.80%) used: 752 KiB
ID-3: /home raw-size: 84.63 GiB size: 84.63 GiB (100.00%) used: 14.58 GiB
ID-4: /var/log raw-size: 84.63 GiB size: 84.63 GiB (100.00%) used: 14.58
GiB (17.2%) fs: btrfs dev: /dev/dm-0 maj-min: 254:0
ID-5: /var/tmp raw-size: 84.63 GiB size: 84.63 GiB (100.00%) used: 14.58
ID-2: swap-2 type: partition size: 34.31 GiB used: 0 KiB (0.0%)
mapped: luks-06d0d64e-bfb6-485c-855c-cebcc2115ee8
System Temperatures: cpu: 93.0 C pch: 55.0 C mobo: N/A
Processes: 345 Uptime: 4m wakeups: 2 Memory: 31.2 GiB used: 3.37 GiB
(10.8%) Init: systemd v: 251 default: graphical tool: systemctl
Compilers: gcc: 12.2.0 Packages: pm: pacman pkgs: 1830 libs: 514
Garuda (2.6.8-1):
System install date:     2023-02-13
Last full system update: 2023-02-13
You see it where? Paste the full input and output of what you are seeing into the thread to provide some context.
The taint is from the nVidia driver. Nothing to worry about.
