Hello.
I recently did an upgrade to my system and now Fire Dragon has a really weird border between the edge of the web page and the border of the actual application.
I'm at 100% screen size and I don't have any web developer options enabled.
See screenshot below:
Has anyone seen this or dealt with this?
Kernel: 5.16.9-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.2.0
root=UUID=5ea32362-776b-4a64-a2e7-1e1492b1137b rw rootflags=subvol=@
resume=UUID=99213909-149f-4663-8cb0-b7431f100328 loglevel=3
Desktop: sway 1.7 vt: 1 dm: N/A Distro: Garuda Linux base: Arch Linux
Type: Laptop System: Dell product: XPS 13 9350 v: N/A
Mobo: Dell model: 0PWNCR v: A01 serial: <superuser required> UEFI: Dell
v: 1.11.1 date: 08/01/2019
ID-1: BAT0 charge: 30.4 Wh (100.0%) condition: 30.4/56.0 Wh (54.3%)
volts: 8.6 min: 7.6 model: LGC-LGC7.3 DELL 5K9CP5A type: Li-ion
serial: <filter> status: Full
Info: model: Intel Core i7-6500U bits: 64 type: MT MCP arch: Skylake
family: 6 model-id: 0x4E (78) stepping: 3 microcode: 0xEC
L3: 4 MiB desc: 1x4 MiB
Speed (MHz): avg: 3045 high: 3074 min/max: 400/3100 scaling:
driver: intel_pstate governor: performance cores: 1: 3074 2: 3032 3: 3028
4: 3046 bogomips: 20799
Type: l1tf
Device-1: Intel Skylake GT2 [HD Graphics 520] vendor: Dell driver: i915
v: kernel bus-ID: 00:02.0 chip-ID: 8086:1916 class-ID: 0300
Device-2: Microdia Integrated Webcam HD type: USB driver: uvcvideo
bus-ID: 1-5:4 chip-ID: 0c45:670c class-ID: 0e02
Display: wayland server: N/A compositor: sway v: 1.7 driver: loaded: i915
note: n/a (using device driver) display-ID: 1
resolution: <missing: xdpyinfo>
Device-1: Intel Sunrise Point-LP HD Audio vendor: Dell
Sound Server-1: ALSA v: k5.16.9-zen1-1-zen running: yes
Sound Server-4: PipeWire v: 0.3.45 running: yes
Device-1: Intel Wireless 7265 driver: iwlwifi v: kernel bus-ID: 3a:00.0
chip-ID: 8086:095a class-ID: 0280
IF: wlp58s0 state: up mac: <filter>
bus-ID: 1-3:3 chip-ID: 8087:0a2a class-ID: e001
v: 3.0 port: f060 bus-ID: 00:17.0 chip-ID: 8086:282a rev: N/A
class-ID: 0104
Local Storage: total: 465.76 GiB used: 23.12 GiB (5.0%)
ID-1: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 860 EVO M.2 500GB
type: SSD serial: <filter> rev: 2B6Q scheme: GPT
ID-1: / raw-size: 456.66 GiB size: 456.66 GiB (100.00%)
used: 23.12 GiB (5.1%) fs: btrfs dev: /dev/sda2 maj-min: 8:2
ID-3: /home raw-size: 456.66 GiB size: 456.66 GiB (100.00%)
ID-4: /var/log raw-size: 456.66 GiB size: 456.66 GiB (100.00%)
ID-5: /var/tmp raw-size: 456.66 GiB size: 456.66 GiB (100.00%)
ID-1: swap-1 type: partition size: 8.8 GiB used: 0 KiB (0.0%)
ID-2: swap-2 type: zram size: 7.63 GiB used: 1.8 MiB (0.0%) priority: 100
System Temperatures: cpu: 48.0 C pch: 43.5 C mobo: 35.0 C sodimm: SODIMM C
Fan Speeds (RPM): cpu: 0
Processes: 229 Uptime: 5m wakeups: 1 Memory: 7.63 GiB
used: 3.69 GiB (48.4%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.2.0 clang: 13.0.1 Packages: pacman: 1285 lib: 318 Shell: Zsh
v: 5.8.1 running-in: alacritty inxi: 3.3.12
Garuda (2.5.4-2):
System install date: 2021-12-08
Last full system update: 2022-02-15
I have searched across different forums and haven't found anything that talked about this.
I don't know what to try to resolve it so that's why I'm asking the community.
