Firedragon Timezone issue
I am currently using firedragon 115.0.2 (64-bit). The time and date on my laptop are set correctly.
I have a weird problem where some websites are using my current timezone CST (ie: messages.google.com), while others are using UTC (ie: webbrowsertools.com/timezone/). This has led me to miss an important meeting. Luckily just one so far.
I have disabled all plugins and the results have not changed. I have found a plugin to spoof my timezone. However this changes the ones that normally do work to the offset time. I cannot seem to find any settings in the about:config.
Not sure where else to look.
Kernel: 6.4.7-zen1-2-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=fee12699-5d85-4ddb-bae0-daf333cf53d5 rw rootflags=subvol=@
loglevel=3 quiet ibt=off
Type: Laptop System: Micro-Star product: GL65 9SE v: REV:1.0
Mobo: Micro-Star model: MS-16U5 v: REV:1.0 serial: <superuser required>
UEFI: American Megatrends v: E16U5IMS.102 date: 03/17/2020
ID-1: BAT1 charge: 34.8 Wh (93.0%) condition: 37.4/51.6 Wh (72.6%)
volts: 11.8 min: 10.9 model: MSI BIF0_9 type: Li-ion serial: N/A
status: not charging
model-id: 0x9E (158) stepping: 0xA (10) microcode: 0xF2
L3: 12 MiB desc: 1x12 MiB
Speed (MHz): avg: 2118 high: 2600 min/max: 800/4500 scaling:
driver: intel_pstate governor: powersave cores: 1: 800 2: 2600 3: 2600
4: 2600 5: 1164 6: 2600 7: 2600 8: 1152 9: 2600 10: 2600 11: 1509 12: 2600
bogomips: 62399
Device-1: Intel CoffeeLake-H GT2 [UHD Graphics 630] vendor: Micro-Star MSI
ports: active: eDP-1 empty: none bus-ID: 00:02.0 chip-ID: 8086:3e9b
Device-2: NVIDIA TU106M [GeForce RTX 2060 Mobile] vendor: Micro-Star MSI
driver: nvidia v: 535.86.05 alternate: nouveau,nvidia_drm non-free: 535.xx+
status: current (as of 2023-07) arch: Turing code: TUxxx
process: TSMC 12nm FF built: 2018-22 pcie: gen: 3 speed: 8 GT/s lanes: 16
ports: active: none empty: DP-1,HDMI-A-1 bus-ID: 01:00.0
chip-ID: 10de:1f11 class-ID: 0300
Device-3: Chicony HD Webcam driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-13:3 chip-ID: 04f2:b695
class-ID: 0e02
Monitor-1: eDP-1 model: AU Optronics 0xd0ed built: 2019 res: 1920x1080
hz: 120 dpi: 142 gamma: 1.2 size: 344x193mm (13.54x7.6") diag: 394mm (15.5")
ratio: 16:9 modes: 1920x1080
API: OpenGL v: 4.6 Mesa 23.1.4 renderer: Mesa Intel UHD Graphics 630 (CFL
GT2) direct-render: Yes
Device-2: NVIDIA TU106 High Definition Audio vendor: Micro-Star MSI
bus-ID: 01:00.1 chip-ID: 10de:10f9 class-ID: 0403
API: ALSA v: k6.4.7-zen1-2-zen status: kernel-api with: aoss
Server-1: PipeWire v: 0.3.76 status: active with: 1: pipewire-pulse
vendor: Micro-Star MSI driver: r8168 v: 8.051.02-NAPI modules: r8169 pcie:
gen: 1 speed: 2.5 GT/s lanes: 1 port: 3000 bus-ID: 03:00.0
v: 0.8 type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-14:4
Local Storage: total: 1.38 TiB used: 785.03 GiB (55.7%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Western Digital model: PC SN520
SDAPNUW-512G-1032 size: 476.94 GiB block-size: physical: 512 B
logical: 512 B speed: 15.8 Gb/s lanes: 2 tech: SSD serial: <filter>
fw-rev: 20140000 temp: 50.9 C scheme: GPT
model: WD10JPVX-60JC3T0 size: 931.51 GiB block-size: physical: 4096 B
fw-rev: 1A01 scheme: GPT
ID-1: / raw-size: 146.44 GiB size: 146.44 GiB (100.00%)
used: 116.52 GiB (79.6%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-2: /home raw-size: 146.44 GiB size: 146.44 GiB (100.00%)
ID-3: /var/log raw-size: 146.44 GiB size: 146.44 GiB (100.00%)
ID-4: /var/tmp raw-size: 146.44 GiB size: 146.44 GiB (100.00%)
ID-1: swap-1 type: zram size: 15.46 GiB used: 529.2 MiB (3.3%)
System Temperatures: cpu: 58.0 C pch: 57.0 C mobo: N/A
Processes: 414 Uptime: 1d 17h 11m wakeups: 37770 Memory: total: 16 GiB
available: 15.46 GiB used: 6.61 GiB (42.7%) Init: systemd v: 254
default: graphical tool: systemctl Compilers: gcc: 13.2.1 clang: 15.0.7
Packages: pm: pacman pkgs: 1811 libs: 509 tools: octopi,paru Shell: fish
v: 3.6.1 running-in: konsole inxi: 3.3.28
System install date:     2022-07-14
Last full system update: 2023-08-02
Failed units:            systemd-modules-load.service
It looks similar to this issue:
Thanks, this led me in the right direction.
there is a setting
privacy.resistFingerprinting.exemptedDomains where you can put in the websites that you want to override. I must have messed with this in the past as messages.google.com was there already.
I have added to ~/.firedragon/ firedragon.overrides.cfg
defaultPref("privacy.resistFingerprinting.exemptedDomains", "mail.google.com,messages.google.com,webbrowsertools.com");
I will have to pay attention in the future to which websites have to incorrect time and will then have to add them to this file.
