Firedragon starting at system boot - not wanted behaviour
  Kernel: 6.8.9-zen1-2-zen arch: x86_64 bits: 64 compiler: gcc v: 14.1.1
    root=UUID=bd6ec518-0675-438b-8673-51b1fb05d518 rw rootflags=subvol=@
    quiet loglevel=3 amdgpu.ppfeaturemask=0xffffffff ibt=off
  Type: Desktop Mobo: Gigabyte model: B450 AORUS ELITE
    Megatrends LLC. v: F65a date: 02/09/2023
  Info: model: AMD Ryzen 7 5700G with Radeon Graphics bits: 64 type: MT MCP
    microcode: 0xA50000D
    L3: 16 MiB desc: 1x16 MiB
  Speed (MHz): avg: 562 high: 2994 min/max: 400/4673 scaling:
    4: 400 5: 400 6: 400 7: 400 8: 400 9: 400 10: 400 11: 400 12: 400 13: 2994
    14: 400 15: 400 16: 400 bogomips: 121365
    vendor: Sapphire driver: amdgpu v: kernel arch: RDNA-2 code: Navi-2x
    lanes: 16 ports: active: HDMI-A-1 empty: DP-1, DP-2, DP-3, Writeback-1
    bus-ID: 03:00.0 chip-ID: 1002:73df class-ID: 0300
  Display: x11 server: X.Org v: 21.1.13 with: Xwayland v: 23.2.6
    s-diag: 777mm (30.58")
  Monitor-1: HDMI-A-1 mapped: HDMI-A-0 model: Samsung LC27G5xT
    serial: <filter> built: 2021 res: 2560x1440 hz: 60 dpi: 109 gamma: 1.2
    max: 2560x1440 min: 720x400
    inactive: gbm,wayland
  API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 24.0.6-arch1.2
    navi22 LLVM 17.0.6 DRM 3.57 6.8.9-zen1-2-zen) device-ID: 1002:73df
    memory: 11.72 GiB unified: no
  API: Vulkan v: 1.3.279 layers: 14 device: 0 type: discrete-gpu name: AMD
    Radeon RX 6700 XT (RADV NAVI22) driver: mesa radv v: 24.0.6-arch1.2
    device-ID: 1002:73df surfaces: xcb,xlib device: 1 type: cpu name: llvmpipe
    (LLVM 17.0.6 256 bits) driver: mesa llvmpipe v: 24.0.6-arch1.2 (LLVM
    gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 03:00.1 chip-ID: 1002:ab28
  Device-2: AMD Renoir Radeon High Definition Audio driver: snd_hda_intel
    speed: 16 GT/s bus-ID: 0a:00.1 chip-ID: 1002:1637 class-ID: 0403
  Device-3: AMD Family 17h/19h HD Audio vendor: Gigabyte
    link-max: gen: 4 speed: 16 GT/s bus-ID: 0a:00.6 chip-ID: 1022:15e3
  API: ALSA v: k6.8.9-zen1-2-zen status: kernel-api with: aoss
    lanes: 1 port: e000 bus-ID: 06:00.0 chip-ID: 10ec:8168 class-ID: 0200
    v: 0.8 type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-9:4
  Report: btmgmt ID: hci0 rfk-id: 0 state: down bt-service: disabled
    rfk-block: hardware: no software: no address: N/A
  Local Storage: total: 1.56 TiB used: 182.24 GiB (11.4%)
    lanes: 4 tech: SSD serial: <filter> fw-rev: 5B2QGXA7 temp: 27.9 C
  ID-2: /dev/sda maj-min: 8:0 vendor: GOODRAM model: SSDPR-CL100-480-G2
    tech: SSD serial: <filter> fw-rev: V4.9 scheme: MBR
  ID-3: /dev/sdb maj-min: 8:16 vendor: PNY model: CS900 240GB SSD
    tech: SSD serial: <filter> fw-rev: 0615 scheme: GPT
  ID-1: / raw-size: 100 GiB size: 100 GiB (100.00%) used: 13.46 GiB (13.5%)
  ID-2: /boot/efi raw-size: 1 GiB size: 1023 MiB (99.80%)
    used: 584 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
  ID-3: /home raw-size: 830.51 GiB size: 830.51 GiB (100.00%)
    used: 168.77 GiB (20.3%) fs: btrfs dev: /dev/nvme0n1p3 maj-min: 259:3
  ID-4: /var/log raw-size: 100 GiB size: 100 GiB (100.00%)
    used: 13.46 GiB (13.5%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
  ID-5: /var/tmp raw-size: 100 GiB size: 100 GiB (100.00%)
  ID-1: swap-1 type: zram size: 31.21 GiB used: 0 KiB (0.0%) priority: 100
  System Temperatures: cpu: 27.8 C mobo: N/A gpu: amdgpu temp: 30.0 C
    mem: 28.0 C
  Fan Speeds (rpm): N/A gpu: amdgpu fan: 890
  Memory: total: 32 GiB available: 31.21 GiB used: 3.31 GiB (10.6%)
  Processes: 347 Power: uptime: 5m states: freeze,mem,disk suspend: deep
    suspend, test_resume image: 12.47 GiB services: org_kde_powerdevil,
  Packages: pm: pacman pkgs: 1789 libs: 535 tools: octopi,paru Compilers:
    clang: 17.0.6 gcc: 14.1.1 Shell: garuda-inxi default: fish v: 3.7.1
  System install date:     2024-05-06
  Last full system update: 2024-05-09
Hi i have an issue with firedragon, it startsup all time then i boot up my system, it’s same on x11 and wayland, i do not have autostart option enabled for firedragon
~/.cache cleaning not helping
Check session recovery (translated)
you mean in .config/session?
System settings, GUI
yes i have found it, that worked, thank you
