FireDragon resets application-specific audio level
Hello Community!
i just switched from Brave to FireDragon due to more and more concerns over the whole chromium base. I use "deej" which is a 3D printed mix-table where i can level the audio of specified applications.
Now when i play a video on firedragon and pause the video, the audio level will reset back to 100% on resume.
Is there a way to fix this?
Thanks!
  Kernel: 6.4.12-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
    root=UUID=c3ef0d61-a4ef-469b-96b1-b7a7583d021e rw rootflags=subvol=@
  Desktop: KDE Plasma v: 5.27.7 tk: Qt v: 5.15.10 info: polybar wm: kwin_x11
    vt: 2 dm: SDDM Distro: Garuda Linux base: Arch Linux
  Type: Desktop Mobo: ASUSTeK model: ROG STRIX X570-I GAMING v: Rev X.0x
    serial: <superuser required> BIOS: American Megatrends v: 4601
    date: 02/02/2023
  Device-1: apple_mfi_fastcharge model: N/A serial: N/A charge: N/A
    status: N/A
  Info: model: AMD Ryzen 7 5800X3D bits: 64 type: MT MCP arch: Zen 3+ gen: 4
    L3: 96 MiB desc: 1x96 MiB
  Speed (MHz): avg: 3629 high: 4347 min/max: 2200/4549 boost: enabled
    scaling: driver: acpi-cpufreq governor: performance cores: 1: 3723 2: 3550
    3: 3523 4: 3525 5: 3400 6: 3957 7: 3546 8: 4347 9: 3461 10: 3475 11: 3400
    12: 3537 13: 3494 14: 3400 15: 3400 16: 4335 bogomips: 108801
  Device-1: NVIDIA GA104 [GeForce RTX 3070] vendor: ASUSTeK driver: nvidia
    v: 535.104.05 alternate: nouveau,nvidia_drm non-free: 535.xx+
    status: current (as of 2023-08) arch: Ampere code: GAxxx
    process: TSMC n7 (7nm) built: 2020-22 pcie: gen: 3 speed: 8 GT/s lanes: 16
    link-max: gen: 4 speed: 16 GT/s bus-ID: 0a:00.0 chip-ID: 10de:2484
  Display: x11 server: X.Org v: 21.1.8 with: Xwayland v: 23.2.0 compositors:
    1: kwin_x11 2: Picom v: git-f70d0 driver: X: loaded: nvidia gpu: nvidia
  Screen-1: 0 s-res: 4520x1920 s-dpi: 163 s-size: 706x299mm (27.80x11.77")
    s-diag: 767mm (30.19")
  Monitor-1: DP-0 pos: top-left res: 1080x1920 hz: 60 dpi: 92
    size: 299x531mm (11.77x20.91") diag: 609mm (23.99") modes: N/A
  Monitor-2: DP-2 pos: primary,bottom-r res: 3440x1440 dpi: 109
    size: 800x330mm (31.5x12.99") diag: 865mm (34.07") modes: N/A
  Monitor-3: HDMI-0 size-res: N/A modes: N/A
  API: OpenGL v: 4.6.0 NVIDIA 535.104.05 renderer: NVIDIA GeForce RTX
    3070/PCIe/SSE2 direct-render: Yes
  Device-1: NVIDIA GA104 High Definition Audio vendor: ASUSTeK
    link-max: gen: 4 speed: 16 GT/s bus-ID: 0a:00.1 chip-ID: 10de:228b
  API: ALSA v: k6.4.12-zen1-1-zen status: kernel-api with: aoss
  Server-2: PipeWire v: 0.3.78 status: active with: 1: pipewire-pulse
    speed: 5 GT/s lanes: 1 bus-ID: 05:00.0 chip-ID: 8086:2723 class-ID: 0280
    pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: f000 bus-ID: 06:00.0
  IF-ID-1: enp7s0f3u1c4i2 state: down mac: <filter>
  Device-1: SINO WEALTH RK Bluetooth Keyboar driver: hid-generic,usbhid
    type: USB rev: 1.1 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 5-3.4:5
    chip-ID: 258a:0059 class-ID: 0300
  Device-2: ASUSTek Broadcom BCM20702A0 Bluetooth driver: btusb v: 0.8
    type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 5-4.1.1:7
    chip-ID: 0b05:17cb class-ID: fe01 serial: <filter>
  Report: ID: hci0 rfk-id: 1 state: down bt-service: enabled,running
    rfk-block: hardware: no software: yes address: <filter> bt-v: 4.0 lmp-v: 6
  Local Storage: total: 3.19 TiB used: 2.14 TiB (67.2%)
  ID-1: /dev/nvme0n1 maj-min: 259:2 vendor: Samsung model: SSD 970 EVO 250GB
    size: 232.89 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
    lanes: 4 tech: SSD serial: <filter> fw-rev: 1B2QEXE7 temp: 45.9 C
    scheme: MBR
  ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: SK Hynix
    model: HFM256GDHTNG-8310A size: 238.47 GiB block-size: physical: 512 B
    logical: 512 B speed: 15.8 Gb/s lanes: 2 tech: SSD serial: <filter>
    fw-rev: 80070C00 temp: 53.9 C scheme: MBR
  ID-3: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 870 EVO 2TB
  ID-4: /dev/sdb maj-min: 8:16 vendor: Crucial model: CT1000MX500SSD1
    tech: SSD serial: <filter> fw-rev: 033 scheme: GPT
  ID-1: / raw-size: 232.88 GiB size: 232.88 GiB (100.00%)
    used: 162.76 GiB (69.9%) fs: btrfs dev: /dev/nvme0n1p1 maj-min: 259:3
  ID-2: /home raw-size: 232.88 GiB size: 232.88 GiB (100.00%)
  ID-3: /var/log raw-size: 232.88 GiB size: 232.88 GiB (100.00%)
  ID-4: /var/tmp raw-size: 232.88 GiB size: 232.88 GiB (100.00%)
  ID-1: swap-1 type: zram size: 62.71 GiB used: 16.8 MiB (0.0%)
  System Temperatures: cpu: 56.0 C mobo: 51.0 C gpu: nvidia temp: 40 C
  Fan Speeds (rpm): fan-1: 951 fan-2: 1776 fan-5: 889 fan-7: 0 gpu: nvidia
    fan: 53%
  Processes: 466 Uptime: 9h 11m wakeups: 1 Memory: total: 64 GiB note: est.
  available: 62.71 GiB used: 9.94 GiB (15.9%) Init: systemd v: 254
  default: graphical tool: systemctl Compilers: gcc: 13.2.1 alt: 11/12
  clang: 15.0.7 Packages: 2430 pm: pacman pkgs: 2401 libs: 545
  tools: pamac,paru pm: flatpak pkgs: 29 Shell: fish v: 3.6.1
  running-in: alacritty inxi: 3.3.29
  System install date:     2023-08-26
  Last full system update: 2023-08-29
  Is partially upgraded:   Yes
  Failed units:            input-remapper.service systemd-networkd-wait-online.service
Can you install Firefox and see if the same behavior happens?
heyho, yup same behaviour...
Then this is Firefox related, not Firedragon. I would bet all Firefox-based browser have this.
I have no clue what could cause it, but looking through Firefox-Mozilla's forums maybe others have raised this already.
hm yeah after finding out firefox does the same, i found this
So it's firefox based... ugh this is such a bummer. Because it makes it simply unusable for me... i work a lot with adjusting volumes for specific applications
Good catch!
6 years old bug, that does not look too promising.
I do not have the issue though and I use pulseaudio on many machines.
i found out that i could set media.cubeb.backend to alsa which fixes the bug....but i don't know how i could control it via deej then...
i am using pipewire, is there something i could do there to make firedragon remember it's settings?
Yes, create a firedragon override cfg file in your .firedragon folder with the proper setting in it.
I can’t recall by heart the location of the source file, but give me a couple of hours and I’ll get back.
oh that would be awesome!
thanks!
Copy this file /usr/lib/firedragon/firedragon.overrides.cfg to ~./.firedragon/.
Edit it all you want but of course add that setting you modified for alsa.
By reading that file you should understand how to set stuff, sometimes you have to force a setting, sometimes Default it, I always had difficulties with this but in the end it was working.
Definition of setting types can be found on Google, it's standard Mozilla stuff.
Thanks!
I think here is a missunderstanding :smile: What i think you just gave me, was a method to set media.cubeb.backend to alsa via config file.
But i know how to do this in the about:config. As soon as i set it to alsa though, i can't control the volume of FireDragon via deej anymore. Because in the applications tab of the audio applet in the systemtray - FireDragon isn't it's own application anymore but rather an entry called PipeWire ALSA [firedragon] and isn't considered an application anymore. So i can't put this into the config file of deej.
What i hoped for was some config or override that blocks firedragon from changing the volume without user input. Or make it so it can only be changed via deej and nothing else.
Sorry for the missunderstanding here
Oh sorry about that.
That's something different, I wouldn't know, though. :frowning:
nah dw...thanks nonetheless!
i just hope mozilla fixes this some day^^
