Hello, I am having issues with Firedragon syncing. I am using firedragon on all my PCs, and it worked about a week ago, but this time when I signed in, it won't sync my bookmarks and history and passwords etc. Im not sure what else I can say to explain my issues so feel free to ask questions to help clarify.
Kernel: 6.3.1-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.1.1
root=UUID=21bce4bc-148c-4a50-bcbd-61a93efebf2a rw [email protected]
quiet resume=UUID=83813a89-85f7-417f-8c16-f1e6252e3854 loglevel=3 ibt=off
Desktop: KDE Plasma v: 5.27.4 tk: Qt v: 5.15.9 wm: kwin_wayland vt: 2
Type: Desktop Mobo: ASRock model: X570 Taichi serial: <superuser required>
UEFI: American Megatrends v: P4.60 date: 08/03/2021
Info: model: AMD Ryzen 9 3950X bits: 64 type: MT MCP arch: Zen 2 gen: 3
Topology: cpus: 1x cores: 16 tpc: 2 threads: 32 smt: enabled cache:
L1: 1024 KiB desc: d-16x32 KiB; i-16x32 KiB L2: 8 MiB desc: 16x512 KiB
L3: 64 MiB desc: 4x16 MiB
Speed (MHz): avg: 3552 high: 3768 min/max: 2200/4761 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 3500 2: 3722
3: 3606 4: 3500 5: 3500 6: 3500 7: 3500 8: 3500 9: 3628 10: 3600 11: 3500
12: 3599 13: 3500 14: 3500 15: 3500 16: 3500 17: 3667 18: 3500 19: 3500
20: 3768 21: 3500 22: 3598 23: 3600 24: 3598 25: 3500 26: 3500 27: 3604
28: 3500 29: 3500 30: 3500 31: 3500 32: 3698 bogomips: 223992
Device-1: AMD Navi 21 [Radeon RX 6800/6800 XT / 6900 XT] vendor: Sapphire
active: DP-2,DP-3,HDMI-A-1 empty: DP-1 bus-ID: 10:00.0 chip-ID: 1002:73bf
Display: wayland server: X.org v: 1.21.1.8 with: Xwayland v: 23.1.1
gpu: amdgpu display-ID: 0
Monitor-1: DP-2 model: Dell S2721Q serial: <filter> built: 2021
res: 3840x2160 dpi: 163 gamma: 1.2 size: 597x336mm (23.5x13.23")
diag: 685mm (27") ratio: 16:9 modes: max: 3840x2160 min: 720x400
Monitor-2: DP-3 model: Dell S2721Q serial: <filter> built: 2021
Monitor-3: HDMI-A-1 model: Dell MR2416 serial: <filter> built: 2018
res: 1920x1200 dpi: 94 gamma: 1.2 size: 518x324mm (20.39x12.76")
diag: 611mm (24.1") ratio: 16:10 modes: max: 1920x1200 min: 720x400
API: OpenGL v: 4.6 Mesa 23.0.3 renderer: AMD Radeon RX 6900 XT (navi21
LLVM 15.0.7 DRM 3.52 6.3.1-zen1-1-zen) direct-render: Yes
bus-ID: 5-1:2 chip-ID: 413c:a503 gen: 4 class-ID: 0300 speed: 16 GT/s
lanes: 16 bus-ID: 10:00.1 chip-ID: 1002:ab28 class-ID: 0403
Device-2: AMD Starship/Matisse HD Audio vendor: ASRock
bus-ID: 12:00.4 chip-ID: 1022:1487 class-ID: 0403
Device-3: Dell AC511 Sound Bar type: USB
API: ALSA v: k6.3.1-zen1-1-zen status: kernel-api tools: N/A
speed: 5 GT/s lanes: 1 bus-ID: 06:00.0 chip-ID: 8086:2723 class-ID: 0280
IF: wlp6s0 state: up mac: <filter>
Device-2: Intel I211 Gigabit Network vendor: ASRock driver: igb v: kernel
pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: f000 bus-ID: 08:00.0
Device-1: Intel AX200 Bluetooth type: USB driver: btusb v: 0.8 bus-ID: 3-2:2
chip-ID: 8087:0029 class-ID: e001
Report: rfkill ID: hci0 rfk-id: 0 state: up address: see --recommends
Local Storage: total: 8.67 TiB used: 207.26 GiB (2.3%)
ID-1: /dev/nvme0n1 maj-min: 259:4 vendor: KIOXIA
model: KXG60ZNV512G NVMe 512GB size: 476.94 GiB block-size: physical: 512 B
rev: 10604106 temp: 54.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: A-Data model: SX8200PNP
lanes: 4 type: SSD serial: <filter> rev: 42AZS6AC temp: 41.9 C scheme: GPT
model: WDS200T2B0A-00SM50 size: 1.82 TiB block-size: physical: 512 B
logical: 512 B speed: 6.0 Gb/s type: SSD serial: <filter> rev: 40WD
model: WD6003FZBX-00GXAB0 size: 5.46 TiB block-size: physical: 4096 B
rev: 1A01 scheme: GPT
ID-1: / raw-size: 919.17 GiB size: 919.17 GiB (100.00%)
used: 178 GiB (19.4%) fs: btrfs dev: /dev/nvme1n1p2 maj-min: 259:2
used: 576 KiB (0.2%) fs: vfat dev: /dev/nvme1n1p1 maj-min: 259:1
ID-3: /home raw-size: 919.17 GiB size: 919.17 GiB (100.00%)
ID-4: /var/log raw-size: 919.17 GiB size: 919.17 GiB (100.00%)
ID-5: /var/tmp raw-size: 919.17 GiB size: 919.17 GiB (100.00%)
ID-1: swap-1 type: zram size: 31.27 GiB used: 1024 KiB (0.0%)
priority: -2 dev: /dev/nvme1n1p3 maj-min: 259:3
System Temperatures: cpu: 50.2 C mobo: N/A gpu: amdgpu temp: 49.0 C
mem: 48.0 C
Processes: 537 Uptime: 5h 5m wakeups: 0 Memory: 31.27 GiB
used: 9.89 GiB (31.6%) Init: systemd v: 253 default: graphical
tool: systemctl Compilers: gcc: 13.1.1 clang: 15.0.7 Packages: pm: pacman
pkgs: 1317 libs: 374 tools: pamac Shell: Bash v: 5.1.16 running-in: konsole
inxi: 3.3.26
System install date: 2023-02-11
Last full system update: 2023-05-07
