Firedragon not showing the top Menu Bar options
Hello Garuda users,
As the title suggests I suddenly noticed that my firedragon is not showing the top dock options since the last update for some reason.
As you guys can see it's empty. No matter if I maximize it or minimize it. The other apps that previously showed the top dock options continue to do show as can been seen below.
I tried searching for my problem online but seems no one has had the same problem before. I saw a post somewhere asking me to
[Windows]
BorderlessMaximizedWindows=true
do this in my ~/.config/kwinrc which is already there (the value is set to true I mean).
I tried updating my system with garuda-update and reboot but that didn't work. I tried to remove firedragon and reinstall it by,
sudo pacman -Rns firedragon firedragon-extension-plasma-integration
followed by,
rm -r  ~/.firedragon
and
rm -r ~/.cache/firedragon
then cleaned the cache
sudo paccache -ruk0
then reinstalled firedragon
sudo pacman -S firedragon-extension-plasma-integration firedragon
But this didn't help. Launching firedragon from terminal outputs nothing.
╭─siddharth@siddharth in ~ took 425ms
󰂄60%
╰─λ firedragon
So I am at my wits end. Does anyone know what's happening and how to solve this?
inxi:
Summary
  Kernel: 6.3.8-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.1.1
    root=UUID=6a7bcee6-f3ae-4c03-b6b0-7cb27fb4c8d4 rw rootflags=subvol=@
    resume=UUID=1b9b6f2d-a19b-4eee-b2bf-6af31dfdf566 loglevel=3 ibt=off
  Desktop: KDE Plasma v: 5.27.5 tk: Qt v: 5.15.10 wm: kwin_x11 vt: 1
  Type: Convertible System: LENOVO product: 81X1 v: IdeaPad Flex 5 14IIL05
    serial: <superuser required> Chassis: type: 31 v: IdeaPad Flex 5 14IIL05
  Mobo: LENOVO model: LNVNB161216 v: SDK0Q55722 WIN
    serial: <superuser required> UEFI: LENOVO v: ECCN41WW date: 06/27/2022
  ID-1: BAT0 charge: 28.0 Wh (64.1%) condition: 43.7/52.6 Wh (82.9%)
    volts: 12.4 min: 11.5 model: Sunwoda L19D3PD6 type: Li-poly serial: <filter>
    status: charging cycles: 1654
  Info: model: Intel Core i7-1065G7 bits: 64 type: MT MCP arch: Ice Lake
    gen: core 10 level: v4 note: check built: 2019-21 process: Intel 10nm
    family: 6 model-id: 0x7E (126) stepping: 5 microcode: 0xBA
    L1: 320 KiB desc: d-4x48 KiB; i-4x32 KiB L2: 2 MiB desc: 4x512 KiB L3: 8 MiB
    desc: 1x8 MiB
  Speed (MHz): avg: 1363 high: 1500 min/max: 400/3900 scaling:
    driver: intel_pstate governor: performance cores: 1: 1500 2: 1500 3: 843
    4: 1500 5: 1265 6: 1500 7: 1301 8: 1500 bogomips: 23961
  Device-1: Intel Iris Plus Graphics G7 vendor: Lenovo driver: i915 v: kernel
    arch: Gen-11 process: Intel 10nm built: 2019-21 ports: active: eDP-1
    empty: DP-1, DP-2, DP-3, HDMI-A-1 bus-ID: 00:02.0 chip-ID: 8086:8a52
  Device-2: NVIDIA GP108M [GeForce MX330] vendor: Lenovo driver: nvidia
    v: 535.54.03 alternate: nouveau,nvidia_drm non-free: 530.xx+
    status: current (as of 2023-05) arch: Pascal code: GP10x
    process: TSMC 16nm built: 2016-21 pcie: gen: 1 speed: 2.5 GT/s lanes: 4
    link-max: gen: 3 speed: 8 GT/s bus-ID: 01:00.0 chip-ID: 10de:1d16
    class-ID: 0302
  Device-3: Bison Integrated Camera driver: uvcvideo type: USB rev: 2.0
    speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-2:2 chip-ID: 5986:212a
    class-ID: 0e02
  Monitor-1: eDP-1 model: ChiMei InnoLux 0x1406 built: 2019 res: 1920x1080
    hz: 60 dpi: 158 gamma: 1.2 size: 309x173mm (12.17x6.81") diag: 354mm (13.9")
    ratio: 16:9 modes: 1920x1080
  API: OpenGL v: 4.6 Mesa 23.1.2 renderer: Mesa Intel Iris Plus Graphics
    (ICL GT2) direct-render: Yes
  Device-1: Intel Ice Lake-LP Smart Sound Audio vendor: Lenovo
    driver: sof-audio-pci-intel-icl
    alternate: snd_hda_intel,snd_sof_pci_intel_icl bus-ID: 00:1f.3
    chip-ID: 8086:34c8 class-ID: 0401
  API: ALSA v: k6.3.8-zen1-1-zen status: kernel-api tools: N/A
  Device-1: Intel Ice Lake-LP PCH CNVi WiFi driver: iwlwifi v: kernel
    bus-ID: 00:14.3 chip-ID: 8086:34f0 class-ID: 0280
    speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-10:4 chip-ID: 8087:0026
    address: <filter>
  Local Storage: total: 476.94 GiB used: 134.58 GiB (28.2%)
    model: MZALQ512HALU-000L2 size: 476.94 GiB block-size: physical: 512 B
    fw-rev: 3L1QFXV7 temp: 32.9 C scheme: GPT
  ID-1: / raw-size: 459.82 GiB size: 459.82 GiB (100.00%)
    used: 134.58 GiB (29.3%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
  ID-3: /home raw-size: 459.82 GiB size: 459.82 GiB (100.00%)
  ID-4: /var/log raw-size: 459.82 GiB size: 459.82 GiB (100.00%)
  ID-5: /var/tmp raw-size: 459.82 GiB size: 459.82 GiB (100.00%)
  ID-1: swap-1 type: zram size: 15.29 GiB used: 0 KiB (0.0%) priority: 100
  ID-2: swap-2 type: partition size: 16.82 GiB used: 0 KiB (0.0%)
  System Temperatures: cpu: 58.0 C mobo: N/A
  Processes: 291 Uptime: 39m wakeups: 2738 Memory: available: 15.29 GiB
  used: 6.29 GiB (41.1%) Init: systemd v: 253 default: graphical
  tool: systemctl Compilers: gcc: 13.1.1 Packages: pm: pacman pkgs: 1386
  libs: 388 tools: paru Shell: fish v: 3.6.1 default: Bash v: 5.1.16
  running-in: konsole inxi: 3.3.27
  System install date:     2022-11-12
  Last full system update: 2023-06-18
:frowning:
I had the same, but if you need menu items to do something, just press the 'Alt' key, menu back, press it again, menu gone.
I see. I hope this isn't the end of this feature and some workaround is eventually found. :slightly_frowning_face:
