Now I'm going to need to re-read all of Anne McCaffrey's Pern series.
Thanks for the reading tip!
Just.....dribbling
I am downloading the update. The tension grows with every Kb / s
blob:moz-extension://3c743576-c609-493e-83e4-9a47b323f2d8/ba76afff-5c14-43e1-99d7-b49af5a8efa0
Danke, das wΓΌnsche ich Ihnen auch.
Sadly there is a bug which requires manual workaround, already fixed that in the source but building will take a while
Edit /usr/lib/firedragon/firedragon.cfg and delete all following lines starting with
// set default fonts
done.
Sorry, the link doesn't work.
Where is this link? Im missing context
I tried to copy the link from "new tab". Unfortunately it failed.
Im pretty sure its
without the "blob:"
Oh thanks!
moz-extension://3c743576-c609-493e-83e4-9a47b323f2d8/0a9e5523-cb1c-42bf-9133-265d498287a2
:blob:moz-extension://3c743576-c609-493e-83e4-9a47b323f2d8/0a9e5523-cb1c-42bf-9133-265d498287a2
Sorry, heute ist nicht mein Tag
I'm too stupid to copy a link right now. Please let us forget about that today. I ask for it
Mistakes are there to be made. But you should definitely avoid making the same mistake again. I'm a little ashamed.
If you don't speak of it again, I won't either.
You should probably send a PM to a moderator and ask to have this thread cleaned up...
If I had known that you had the last word, I would not have written anything.
Please regard my words as a joke relating to myself
Any chance of an arm rpi4 version?
Three wise frogs
