FireDragon is reverting to Sweet-Dark on every launch
After this latest update today, FireDragon is force-resetting the theme to Sweet-Dark on every launch. I want to stay with System theme!
I can confirm this behaviour. Quite weird as nothing changed regarding the theme. You can at least prevent that by removing the addon from /usr/lib/firedragon/distribution/policies.json :eyes:
This did not happen before? (I'm only using it with Sweet theme)
No, only after the current update.
( 2/16) Aktualisierung läuft firedragon [------------] 100%
Warnung: /usr/lib/firedragon/firedragon.cfg wurde als /usr/lib/firedragon/firedragon.cfg.pacnew installiert
==> Firejail profiles are already present in firejail-git.
==> To use profile-sync-daemon add firedragon to ~/.config/psd/psd.conf
==> If you prefer strict hardened settings execute 'cp /usr/lib/firedragon/firedragon.overrides.cfg ~/.firedragon/'
==> Enjoy the Firedragon 🔥🐉
Personal missing DRM :slight_smile:
// # DRM
defaultPref("media.eme.enabled", true);
defaultPref("media.gmp-widevinecdm.visible", true);
defaultPref("media.gmp-widevinecdm.enabled", true);
defaultPref("media.gmp-provider.enabled", true);
defaultPref("media.gmp-manager.url", "data:text/plain,"); // had to re-add to prevent connections
defaultPref("media.gmp-gmpopenh264.enabled", true);
New
defaultPref("layout.css.backdrop-filter.enabled", true);
Yeah, DRM has been removed to have default behaviour and no issues with streaming :slight_smile:
It is now working on my pc (i.e. I can switch to themes other than sweet)
Are you still facing issue?
This doesnt happen anymore on my end as well, just tested! :slight_smile:
