When trying to launch firedragon-hg i get this error:
XPCOMGlueLoad error for file /usr/lib/firedragon/libxul.so:
libvpx.so.6: cannot open shared object file: No such file or directory
Couldn't load XPCOM.
I need to use firedragon-hg as i need an unofficial extension which cant run on regular firedragon or firefox. Thanks in advance, Lutitious
This normally means it needs a rebuild, or you need to update your system.
Where did you install this package from?
I installed it from the chaoric aur.
The build is currently blocked by an upstream issue
Is there a timeline on a fix?
I might have fixed it, a build is currently running. We will see if it works in half an hour to an hour
Edit: It compiles successfully but fails at the end with a different error, guess it'll take some more work
