Kernel: 6.5.5-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=57b833d0-622a-4e4d-a5a2-c284671260f7 rw rootflags=subvol=@
Desktop: KDE Plasma v: 5.27.8 tk: Qt v: 5.15.10 wm: kwin_x11 vt: 2
Type: Laptop System: System76 product: Darter Pro v: darp8
Mobo: System76 model: Darter Pro v: darp8 serial: <superuser required>
UEFI: coreboot v: 2022-11-21_b337ac6 date: 11/14/2022
ID-1: BAT0 charge: 57.4 Wh (78.2%) condition: 73.4/73.9 Wh (99.2%)
volts: 8.0 min: 7.7 model: Notebook BAT type: Li-ion serial: <filter>
status: discharging cycles: 131
Device-1: hidpp_battery_0 model: Logitech Wireless Mouse M510
Info: model: 12th Gen Intel Core i5-1240P bits: 64 type: MST AMCP
arch: Alder Lake level: v3 note: check built: 2021+
microcode: 0x42C
Topology: cpus: 1x cores: 12 mt: 4 tpc: 2 st: 8 threads: 16 smt: enabled
cache: L1: 1.1 MiB desc: d-8x32 KiB, 4x48 KiB; i-4x32 KiB, 8x64 KiB
L2: 9 MiB desc: 4x1.2 MiB, 2x2 MiB L3: 12 MiB desc: 1x12 MiB
Speed (MHz): avg: 528 high: 857 min/max: 400/4400:3300 scaling:
driver: intel_pstate governor: powersave cores: 1: 400 2: 857 3: 400 4: 588
5: 694 6: 549 7: 652 8: 696 9: 400 10: 569 11: 400 12: 400 13: 400 14: 400
15: 400 16: 645 bogomips: 67584
Device-1: Intel Alder Lake-P GT2 [Iris Xe Graphics] vendor: CLEVO/KAPOK
driver: i915 v: kernel arch: Gen-12.2 process: Intel 10nm built: 2021-22+
ports: active: eDP-1 empty: DP-1, DP-2, DP-3, DP-4, HDMI-A-1
bus-ID: 00:02.0 chip-ID: 8086:46a6 class-ID: 0300
Device-2: Chicony USB2.0 Camera driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-7:3 chip-ID: 04f2:b6fb
class-ID: 0e02
Monitor-1: eDP-1 model: Najing CEC Panda 0x0057 built: 2020 res: 1920x1080
hz: 60 dpi: 142 gamma: 1.2 size: 344x194mm (13.54x7.64") diag: 395mm (15.5")
ratio: 16:9 modes: 1920x1080
inactive: gbm,wayland
API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 23.2.1-arch1.1
glx-v: 1.4 direct-render: yes renderer: Mesa Intel Graphics (ADL GT2)
device-ID: 8086:46a6 memory: 61.18 GiB unified: yes
API: Vulkan v: 1.3.264 layers: 3 device: 0 type: integrated-gpu name: Intel
Graphics (ADL GT2) driver: mesa intel v: 23.2.1-arch1.1
device-ID: 8086:46a6 surfaces: xcb,xlib device: 1 type: cpu name: llvmpipe
(LLVM 16.0.6 256 bits) driver: mesa llvmpipe v: 23.2.1-arch1.1 (LLVM
Device-1: Intel Alder Lake PCH-P High Definition Audio vendor: CLEVO/KAPOK
bus-ID: 00:1f.3 chip-ID: 8086:51c8 class-ID: 0403
API: ALSA v: k6.5.5-zen1-1-zen status: kernel-api tools: N/A
Server-2: PipeWire v: 0.3.80 status: active with: 1: pipewire-pulse
vendor: CLEVO/KAPOK driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 port: 4000 bus-ID: 2e:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp46s0 state: down mac: <filter>
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-10:4 chip-ID: 8087:0026
lmp-v: 11 status: discoverable: no pairing: no class-ID: 7c010c
Local Storage: total: 931.51 GiB used: 112.35 GiB (12.1%)
fw-rev: 4B2QEXM7 temp: 31.9 C scheme: GPT
used: 112.35 GiB (12.1%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-1: swap-1 type: zram size: 62.65 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 57.0 C mobo: N/A
Fan Speeds (rpm): cpu: 0
Processes: 352 Uptime: 7h 39m wakeups: 16133 Memory: total: 64 GiB
available: 62.65 GiB used: 8.25 GiB (13.2%) Init: systemd v: 254
Packages: pm: pacman pkgs: 1780 libs: 472
tools: gnome-software,octopi,pamac,paru Shell: fish v: 3.6.1 default: Bash
v: 5.1.16 running-in: konsole inxi: 3.3.30
Garuda (2.6.17-1):
System install date: 2023-04-25
Last full system update: 2023-10-18
Im having issues with Firedragon and need to use Firefox but am unable to install it for some reason.
I see it as an installed app in the start menu, but when trying to open it gives an error,
"firefox;118.0.1-1;x86_64;extra: could not find or read package"
Ive tried just closing that window and install it anyways, but still getting “Package download failed”
Ive searched forums for this issue and googled the issue but cant find anything about it and am at a loss now. Please help.
Thanks.
