Forgive me if this is the wrong place for this (and also my English).
I use garuda Cinnamon.
after running the command garuda-update -a
firedragon was upgraded from version 105.0.1-3.2, to version 105.0.3-1.
after rebooting, I noticed that Firedragon was gone from my menu and panel. I narrowed down the problem to the firedragon.desktop file, located at /usr/share/applications/
. the problem was in the Exec=
segment in:
[Desktop Entry]
,[Desktop Action new-window]
,[Desktop Action new-private-window]
Example:
Exec=GTK_USE_PORTAL="1" /usr/lib/firedragon/firedragon --new-window %u
I fixed it by removing %u
and GTK_USE_PORTAL="1"
from all 3 Exec= and what remained was
Example:
Exec=/usr/lib/firedragon/firedragon
I don’t know if this is a Cinnamon specific issue, or a just me issue.
just wanted to report
garuda-inxi output
Kernel: 5.19.13-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
root=UUID=3c39be8e-4af5-4faa-8f99-7e4a12fb08f4 rw rootflags=subvol=@
resume=UUID=e32b9010-dd95-4f79-b1b2-cddf2896cdc6 loglevel=3
Desktop: Cinnamon v: 5.4.12 tk: GTK v: 3.24.34 wm: Mutter vt: 7
dm: LightDM v: 1.32.0 Distro: Garuda Linux base: Arch Linux
Type: Desktop System: Gigabyte product: N/A v: N/A
Mobo: Gigabyte model: H77-DS3H v: x.x serial: <superuser required>
UEFI: American Megatrends v: F10 date: 11/14/2013
Info: model: Intel Core i7-3770 bits: 64 type: MT MCP arch: Ivy Bridge
L3: 8 MiB desc: 1x8 MiB
Speed (MHz): avg: 1598 high: 1600 min/max: 1600/3900 scaling:
driver: intel_cpufreq governor: schedutil cores: 1: 1596 2: 1596 3: 1600
4: 1596 5: 1596 6: 1600 7: 1600 8: 1600 bogomips: 54273
vulnerable
Device-1: NVIDIA GP107 [GeForce GTX 1050 Ti]
vendor: Gigabyte GV-N105TOC-4GD driver: nvidia v: 515.76
alternate: nouveau,nvidia_drm non-free: 515.xx+ status: current (as of
2022-10) arch: Pascal code: GP10x process: TSMC 16nm built: 2016-21 pcie:
gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 01:00.0 chip-ID: 10de:1c82
Display: x11 server: X.Org v: 21.1.4 driver: X: loaded: nvidia
unloaded: modesetting alternate: fbdev,nouveau,nv,vesa gpu: nvidia
Screen-1: 0 s-res: 1920x2160 s-dpi: 96 s-size: 508x572mm (20.00x22.52")
s-diag: 765mm (30.12")
Monitor-1: DP-0 pos: primary,top res: 1920x1080 hz: 60 dpi: 93
Monitor-2: HDMI-0 pos: bottom res: 1920x1080 hz: 60 dpi: 190
size: 256x144mm (10.08x5.67") diag: 294mm (11.56") modes: N/A
OpenGL: renderer: NVIDIA GeForce GTX 1050 Ti/PCIe/SSE2 v: 4.6.0 NVIDIA
515.76 direct render: Yes
Device-1: Intel 7 Series/C216 Family High Definition Audio vendor: Gigabyte
Device-2: NVIDIA GP107GL High Definition Audio vendor: Gigabyte
Sound API: ALSA v: k5.19.13-zen1-1-zen running: yes
Device-1: Qualcomm Atheros AR8161 Gigabit Ethernet vendor: Gigabyte
driver: alx v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: d000
bus-ID: 03:00.0 chip-ID: 1969:1091 class-ID: 0200
Local Storage: total: 2.04 TiB used: 171.32 GiB (8.2%)
ID-1: /dev/sda maj-min: 8:0 model: SSD 240GB size: 223.57 GiB block-size:
physical: 512 B logical: 512 B speed: 6.0 Gb/s type: SSD serial: <filter>
rev: 838 scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: Toshiba model: DT01ACA200
size: 1.82 TiB block-size: physical: 4096 B logical: 512 B speed: 3.0 Gb/s
type: HDD rpm: 7200 serial: <filter> rev: ABB0 scheme: MBR
ID-1: / raw-size: 190.57 GiB size: 190.57 GiB (100.00%) used: 18.88 GiB
(9.9%) fs: btrfs dev: /dev/sda3 maj-min: 8:3
ID-2: /boot/efi raw-size: 1024 MiB size: 1022 MiB (99.80%) used: 608 KiB
(0.1%) fs: vfat dev: /dev/sda2 maj-min: 8:2
ID-3: /home raw-size: 1.82 TiB size: 1.82 TiB (100.00%) used: 152.43 GiB
(8.2%) fs: btrfs dev: /dev/sdb1 maj-min: 8:17
ID-4: /var/log raw-size: 190.57 GiB size: 190.57 GiB (100.00%) used: 18.88
GiB (9.9%) fs: btrfs dev: /dev/sda3 maj-min: 8:3
ID-5: /var/tmp raw-size: 190.57 GiB size: 190.57 GiB (100.00%) used: 18.88
ID-1: swap-1 type: zram size: 15.59 GiB used: 1009.5 MiB (6.3%)
ID-2: swap-2 type: partition size: 32 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/sda1 maj-min: 8:1
System Temperatures: cpu: 44.0 C mobo: N/A gpu: nvidia temp: 47 C
Processes: 301 Uptime: 3h 22m wakeups: 3 Memory: 15.59 GiB used: 3.01 GiB
(19.3%) Init: systemd v: 251 default: graphical tool: systemctl
Compilers: gcc: 12.2.0 clang: 14.0.6 Packages: 1640 pm: pacman pkgs: 1635
libs: 362 tools: paru pm: flatpak pkgs: 5 Shell: fish v: 3.5.1
running-in: gnome-terminal inxi: 3.3.22
Garuda (2.6.8-1):
System install date: 2022-09-12
Last full system update: 2022-10-12 ↻
