Firedragon default landingpage wont load
Hello everyone,
on my fresh Garuda install Firedragon wont load the landingpage.
Unable to connect
Firefox can’t establish a connection to the server at localhost:8001.
    The site could be temporarily unavailable or too busy. Try again in a few moments.
    If you are unable to load any pages, check your computer’s network connection.
    If your computer or network is protected by a firewall or proxy, make sure that FireDragon is permitted to access the web.
Id really love to know whats on it. :stuck_out_tongue:
Firewall’s been disabled, so i wouldnt know why it cant get access.
Any ideas?
Best regards
I cant imagine it helps in this case, but since its “formally requested” heres the garuda-inxi output:
Kernel: 6.6.32-1-lts arch: x86_64 bits: 64 compiler: gcc v: 14.1.1
root=UUID=16465533-041d-4993-afd4-de608fe01247 rw rootflags=subvol=@
Desktop: KDE Plasma v: 6.0.5 tk: Qt v: N/A info: frameworks v: 6.2.0
wm: kwin_x11 with: cairo-dock vt: 2 dm: SDDM Distro: Garuda base: Arch Linux
Type: Desktop Mobo: BIOSTAR model: X570GT8 serial: <superuser required>
uuid: <superuser required> UEFI: American Megatrends LLC. v: 5.17
date: 05/23/2022
L3: 32 MiB desc: 2x16 MiB
Speed (MHz): avg: 3599 high: 3603 min/max: 2200/4208 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 3600 2: 3600
3: 3600 4: 3599 5: 3588 6: 3600 7: 3600 8: 3600 9: 3600 10: 3600 11: 3600
12: 3603 bogomips: 86425
vendor: Micro-Star MSI driver: amdgpu v: kernel arch: GCN-4
code: Arctic Islands process: GF 14nm built: 2016-20 pcie: gen: 3
speed: 8 GT/s lanes: 8 link-max: lanes: 16 ports: active: DP-2,HDMI-A-2
empty: DP-1,DVI-D-1,HDMI-A-1 bus-ID: 09:00.0 chip-ID: 1002:67df
class-ID: 0300 temp: 55.0 C
Screen-1: 0 s-res: 4640x1920 s-dpi: 96 s-size: 1227x508mm (48.31x20.00")
s-diag: 1328mm (52.28")
Monitor-1: DP-2 mapped: DisplayPort-1 pos: primary,bottom-r
model: Gigabyte G34WQC A serial: <filter> built: 2022 res: 3440x1440
dpi: 110 gamma: 1.2 size: 797x334mm (31.38x13.15") diag: 864mm (34")
modes: max: 3440x1440 min: 720x400
Monitor-2: HDMI-A-2 mapped: HDMI-A-1 pos: top-left
model: Samsung LF24T450G serial: <filter> built: 2022 res: 1200x1920 hz: 75
dpi: 94 gamma: 1.2 size: 324x519mm (12.76x20.43") diag: 616mm (24.2")
ratio: 16:10 modes: max: 1920x1200 min: 720x400
inactive: gbm,wayland
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 24.1.0-arch1.1
glx-v: 1.4 direct-render: yes renderer: AMD Radeon RX 580 Series (radeonsi
polaris10 LLVM 17.0.6 DRM 3.54 6.6.32-1-lts) device-ID: 1002:67df
memory: 7.81 GiB unified: no
API: Vulkan v: 1.3.279 layers: 10 device: 0 type: discrete-gpu name: AMD
Radeon RX 580 Series (RADV POLARIS10) driver: mesa radv v: 24.1.0-arch1.1
device-ID: 1002:67df surfaces: xcb,xlib device: 1 type: cpu name: llvmpipe
(LLVM 17.0.6 256 bits) driver: mesa llvmpipe v: 24.1.0-arch1.1 (LLVM
vendor: Micro-Star MSI driver: snd_hda_intel v: kernel pcie: gen: 3
speed: 8 GT/s lanes: 8 link-max: lanes: 16 bus-ID: 09:00.1
chip-ID: 1002:aaf0 class-ID: 0403
Device-2: AMD Starship/Matisse HD Audio vendor: Biostar Microtech Intl
Corp driver: snd_hda_intel v: kernel pcie: gen: 4 speed: 16 GT/s lanes: 16
bus-ID: 0b:00.4 chip-ID: 1022:1487 class-ID: 0403
Device-3: SteelSeries ApS Arctis 7+
lanes: 1 mode: 1.1 bus-ID: 3-1.4.2.3:10 chip-ID: 1038:220e class-ID: 0300
API: ALSA v: k6.6.32-1-lts status: kernel-api with: aoss
Device-1: Intel I211 Gigabit Network vendor: Biostar Microtech Intl Corp
driver: igb v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: f000
bus-ID: 04:00.0 chip-ID: 8086:1539 class-ID: 0200
Device-1: TP-Link UB500 Adapter driver: btusb v: 0.8 type: USB rev: 1.1
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-1.4.2.1:8 chip-ID: 2357:0604
Local Storage: total: 8.69 TiB used: 1.05 TiB (12.1%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Intel model: SSDPEKNU020TZ
lanes: 4 tech: SSD serial: <filter> fw-rev: 002C temp: 38.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:2 vendor: Samsung
fw-rev: 2B2QEXM7 temp: 42.9 C scheme: GPT
model: WD40EZAZ-00SF3B0 size: 3.64 TiB block-size: physical: 4096 B
fw-rev: 0A80 scheme: GPT
ID-4: /dev/sdb maj-min: 8:16 vendor: Toshiba model: HDWD130 size: 2.73 TiB
block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s tech: HDD
rpm: 7200 serial: <filter> fw-rev: ACF0 scheme: GPT
used: 31.75 GiB (6.8%) fs: btrfs dev: /dev/nvme1n1p2 maj-min: 259:4
used: 584 KiB (0.2%) fs: vfat dev: /dev/nvme1n1p1 maj-min: 259:3
ID-1: swap-1 type: zram size: 31.29 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 50.6 C mobo: N/A gpu: amdgpu temp: 55.0 C
Fan Speeds (rpm): N/A gpu: amdgpu fan: 1020
Memory: total: 32 GiB available: 31.29 GiB used: 8.97 GiB (28.7%)
Processes: 455 Power: uptime: 2h 13m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 12.5 GiB services: org_kde_powerdevil,
Packages: pm: pacman pkgs: 1900 libs: 544 tools: octopi,paru Compilers:
clang: 17.0.6 gcc: 14.1.1 Shell: garuda-inxi default: fish v: 3.7.1
running-in: yakuake inxi: 3.3.34
System install date:     2024-05-29
Last full system update: 2024-06-01
Sorry, what is the default landing page from Firedragon?
Is not a default FD or Garuda main page.
I didnt change the default settings, thats how it came out of the box.
The URL its trying to reach is:
http://localhost:8001/453e95109229ca576d13c191f2257a0f/#!/colors
Please, check settings, sorry, German :wink:
Start page
“New users cant upload images.” :frowning:
Looks exactly the same tho… Both settings are on default.
/edit: Weird, after switching the homepage to blank and back to default
it now loads the “actual” homepage.
I still wouldve loved to know wth that initial URL was. :stuck_out_tongue:
Oh well, i guess some things will forever remain a mystery… ~~
That initial URL was for Firefox to display pages related to preferences, if you recall, when it asks for a color theme…well that was that (I think?)
Why it got set as your home page, we don’t know.
