Firedragon appearance issue - grey borders around any website
When in maximized screen, on both my devices, the browser seems to be using only most of the screen. I will post some screenshots as example, as well as inxi -Fxxxza:
inxi -Fxxxza
System:    Kernel: 5.12.2-zen2-1-zen x86_64 bits: 64 compiler: gcc v: 10.2.0
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-zen root=UUID=1529dfeb-81df-4527-9c62-b769c459cbf8
rw [email protected] quiet splash rd.udev.log_priority=3 vt.global_cursor_default=0
Desktop: KDE Plasma 5.21.5 tk: Qt 5.15.2 info: latte-dock wm: kwin_x11 vt: 1 dm: SDDM
Machine:   Type: Laptop System: LENOVO product: 81YK v: IdeaPad 5 15IIL05 serial: <filter> Chassis:
type: 10 v: IdeaPad 5 15IIL05 serial: <filter>
Mobo: LENOVO model: LNVNB161216 v: SDK0J40709 WIN serial: <filter> UEFI: LENOVO v: DPCN51WW
date: 02/23/2021
Battery:   ID-1: BAT0 charge: 39.0 Wh (66.0%) condition: 59.1/57.0 Wh (103.7%) volts: 12.7 min: 11.5
model: SMP L19M3PF6 type: Li-poly serial: <filter> status: Charging cycles: 19
CPU:       Info: Quad Core model: Intel Core i7-1065G7 bits: 64 type: MT MCP arch: Ice Lake family: 6
model-id: 7E (126) stepping: 5 microcode: A0 cache: L2: 8 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 23961
Speed: 3766 MHz min/max: 400/3900 MHz Core speeds (MHz): 1: 3766 2: 3639 3: 3696 4: 792 5: 3714
6: 3664 7: 3685 8: 2530
Graphics:  Device-1: Intel Iris Plus Graphics G7 vendor: Lenovo driver: i915 v: kernel bus-ID: 00:02.0
chip-ID: 8086:8a52 class-ID: 0300
Device-2: IMC Networks Integrated Camera type: USB driver: uvcvideo bus-ID: 3-5:2
chip-ID: 13d3:56ff class-ID: 0e02
Display: x11 server: X.Org 1.20.11 compositor: kwin_x11 driver: loaded: intel
Monitor-1: eDP1 res: 1920x1080 hz: 60 dpi: 143 size: 340x190mm (13.4x7.5") diag: 389mm (15.3")
OpenGL: renderer: Mesa Intel Iris Plus Graphics (ICL GT2) v: 4.6 Mesa 21.1.0 direct render: Yes
Audio:     Device-1: Intel Smart Sound Audio vendor: Lenovo driver: sof-audio-pci-intel-icl
alternate: snd_hda_intel,snd_sof_pci_intel_icl bus-ID: 00:1f.3 chip-ID: 8086:34c8
class-ID: 0401
Sound Server-1: ALSA v: k5.12.2-zen2-1-zen running: yes
Sound Server-4: PipeWire v: 0.3.27 running: yes
Network:   Device-1: Intel Killer Wi-Fi 6 AX1650i 160MHz Wireless Network Adapter driver: iwlwifi
v: kernel port: 3000 bus-ID: 00:14.3 chip-ID: 8086:34f0 class-ID: 0280
Bluetooth: Device-1: Intel type: USB driver: btusb v: 0.8 bus-ID: 3-10:4 chip-ID: 8087:0026 class-ID: e001
Report: bt-adapter ID: hci0 rfk-id: 3 state: down bt-service: enabled,running rfk-block:
Drives:    Local Storage: total: 476.94 GiB used: 23.74 GiB (5.0%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Lenovo model: UMIS RPJTJ512MEE1OWX size: 476.94 GiB
block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s lanes: 4 rotation: SSD
serial: <filter> rev: 2.0C0628 scheme: GPT
Partition: ID-1: / raw-size: 178.46 GiB size: 178.46 GiB (100.00%) used: 23.7 GiB (13.3%) fs: btrfs
dev: /dev/nvme0n1p6 maj-min: 259:6
ID-2: /boot/efi raw-size: 260 MiB size: 256 MiB (98.46%) used: 46.4 MiB (18.1%) fs: vfat
ID-3: /home raw-size: 178.46 GiB size: 178.46 GiB (100.00%) used: 23.7 GiB (13.3%) fs: btrfs
ID-4: /var/log raw-size: 178.46 GiB size: 178.46 GiB (100.00%) used: 23.7 GiB (13.3%) fs: btrfs
ID-5: /var/tmp raw-size: 178.46 GiB size: 178.46 GiB (100.00%) used: 23.7 GiB (13.3%) fs: btrfs
Swap:      Kernel: swappiness: 10 (default 60) cache-pressure: 75 (default 100)
ID-1: swap-1 type: partition size: 16.85 GiB used: 0 KiB (0.0%) priority: -2
ID-2: swap-2 type: zram size: 1.91 GiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram0
ID-3: swap-3 type: zram size: 1.91 GiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram1
ID-4: swap-4 type: zram size: 1.91 GiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram2
ID-5: swap-5 type: zram size: 1.91 GiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram3
ID-6: swap-6 type: zram size: 1.91 GiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram4
ID-7: swap-7 type: zram size: 1.91 GiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram5
ID-8: swap-8 type: zram size: 1.91 GiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram6
ID-9: swap-9 type: zram size: 1.91 GiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram7
Sensors:   System Temperatures: cpu: 50.0 C mobo: N/A
Info:      Processes: 239 Uptime: 5m wakeups: 800 Memory: 15.32 GiB used: 2.63 GiB (17.2%) Init: systemd
v: 248 tool: systemctl Compilers: gcc: 10.2.0 clang: 11.1.0 Packages: pacman: 1306 lib: 325
Shell: fish v: 3.2.2 running-in: konsole inxi: 3.3.04
inxi -Fxxxza
  Kernel: 5.12.1-zen2-1-zen x86_64 bits: 64 compiler: gcc v: 10.2.0
  root=UUID=da4d6968-7db8-43fd-9261-d5aedfe746fc rw [email protected] quiet
  resume=UUID=cf2c3392-2047-4e74-8130-ad7460fb517d loglevel=3
  Desktop: MATE 1.24.3 info: mate-panel wm: marco 1.24.2 vt: 7
  dm: LightDM 1.30.0 Distro: Garuda Linux base: Arch Linux
  Type: Convertible System: LENOVO product: 81EM
  v: Lenovo ideapad FLEX 6-14IKB serial: <filter> Chassis: type: 31
  UEFI: LENOVO v: 7QCN43WW date: 11/28/2019
  ID-1: BAT0 charge: 4.9 Wh (49.0%) condition: 10.0/45.5 Wh (22.0%)
  volts: 7.8 min: 7.7 model: CPT-COS L17C4PB0 type: Li-poly serial: <filter>
  status: Discharging
  Info: Quad Core model: Intel Core i5-8250U bits: 64 type: MT MCP
  arch: Kaby Lake note: check family: 6 model-id: 8E (142) stepping: A (10)
  microcode: E0 cache: L2: 6 MiB
  bogomips: 28800
  Speed: 3400 MHz min/max: 400/3400 MHz Core speeds (MHz): 1: 3400 2: 3400
  3: 3400 4: 3400 5: 3400 6: 3400 7: 3401 8: 3400
  Type: l1tf
  Device-1: Intel UHD Graphics 620 vendor: Lenovo driver: i915 v: kernel
  bus-ID: 00:02.0 chip-ID: 8086:5917 class-ID: 0300
  Device-2: Chicony Integrated Camera type: USB driver: uvcvideo
  bus-ID: 1-8:4 chip-ID: 04f2:b61e class-ID: 0e02 serial: <filter>
  Display: x11 server: X.Org 1.20.11 compositor: marco v: 1.24.2 driver:
  loaded: intel unloaded: modesetting alternate: fbdev,vesa display-ID: :0.0
  Monitor-1: eDP1 res: 1920x1080 hz: 60 dpi: 157 size: 310x170mm (12.2x6.7")
  diag: 354mm (13.9")
  OpenGL: renderer: Mesa Intel UHD Graphics 620 (KBL GT2) v: 4.6 Mesa 21.1.0
  direct render: Yes
  Sound Server-1: ALSA v: k5.12.1-zen2-1-zen running: yes
  Device-1: Realtek RTL8822BE 802.11a/b/g/n/ac WiFi adapter
  vendor: Lenovo ThinkPad E595 driver: rtw_8822be v: N/A
  modules: rtw88_8822be port: 3000 bus-ID: 01:00.0 chip-ID: 10ec:b822
  Device-1: Realtek RTL8822BE Bluetooth 4.2 Adapter type: USB driver: btusb
  v: 0.8 bus-ID: 1-7:3 chip-ID: 0bda:b023 class-ID: e001 serial: <filter>
  Report: bt-adapter ID: hci0 rfk-id: 16 state: down
  address: <filter>
  Local Storage: total: 238.47 GiB used: 8.81 GiB (3.7%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: SK Hynix
  model: HFS256GD9TNG-62A0A size: 238.47 GiB block-size: physical: 512 B
  logical: 512 B speed: 31.6 Gb/s lanes: 4 rotation: SSD serial: <filter>
  rev: 80001E00 scheme: GPT
  ID-1: / raw-size: 229.42 GiB size: 229.42 GiB (100.00%)
  used: 8.81 GiB (3.8%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
  ID-2: /boot/efi raw-size: 256 MiB size: 252 MiB (98.46%)
  used: 546 KiB (0.2%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
  ID-3: /home raw-size: 229.42 GiB size: 229.42 GiB (100.00%)
  ID-4: /var/log raw-size: 229.42 GiB size: 229.42 GiB (100.00%)
  ID-5: /var/tmp raw-size: 229.42 GiB size: 229.42 GiB (100.00%)
  ID-1: swap-1 type: partition size: 8.8 GiB used: 0 KiB (0.0%) priority: -2
  ID-2: swap-2 type: zram size: 966.6 MiB used: 12 MiB (1.2%)
  ID-3: swap-3 type: zram size: 966.6 MiB used: 12.8 MiB (1.3%)
  ID-4: swap-4 type: zram size: 966.6 MiB used: 13 MiB (1.3%)
  ID-5: swap-5 type: zram size: 966.6 MiB used: 10.5 MiB (1.1%)
  ID-6: swap-6 type: zram size: 966.6 MiB used: 10.9 MiB (1.1%)
  ID-7: swap-7 type: zram size: 966.6 MiB used: 9.5 MiB (1.0%)
  ID-8: swap-8 type: zram size: 966.6 MiB used: 11.8 MiB (1.2%)
  ID-9: swap-9 type: zram size: 966.6 MiB used: 12.3 MiB (1.3%)
  System Temperatures: cpu: 44.0 C mobo: N/A
  Processes: 271 Uptime: 2d 2h 59m wakeups: 33 Memory: 7.55 GiB
  used: 2.33 GiB (30.8%) Init: systemd v: 248 tool: systemctl Compilers:
  gcc: 10.2.0 clang: 11.1.0 Packages: pacman: 1217 lib: 303 Shell: Zsh
  v: 5.8 running-in: mate-terminal inxi: 3.3.04
Same issue here :slight_smile:
inxi -Fxxxza
System:    Kernel: 5.12.2-153-tkg-bmq x86_64 bits: 64 compiler: gcc v: 10.2.0
parameters: intel_pstate=passive nowatchdog mitigations=off
BOOT_IMAGE=/@/boot/vmlinuz-linux512-tkg-bmq root=UUID=03dacf15-9056-4631-9c0f-13397609fd59 rw
systemd.unified_cgroup_hierarchy=1 resume=UUID=f98602e4-690c-4bcd-b2d0-5571e134d8b1 loglevel=3
mitigations=off
Machine:   Type: Desktop Mobo: ASUSTeK model: CROSSHAIR V FORMULA-Z v: Rev 1.xx serial: <filter>
UEFI: American Megatrends v: 1801 date: 11/25/2013
CPU:       Info: 8-Core model: AMD FX-8320 bits: 64 type: MCP arch: Bulldozer family: 15 (21) model-id: 2
stepping: 0 microcode: 6000852 cache: L2: 2 MiB
flags: avx lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm bogomips: 56186
Speed: 3512 MHz min/max: N/A Core speeds (MHz): 1: 3512 2: 3512 3: 3512 4: 3512 5: 3512 6: 3512
7: 3512 8: 3511
status: Vulnerable: __user pointer sanitization and usercopy barriers only; no swapgs barriers
Graphics:  Device-1: AMD Curacao XT / Trinidad XT [Radeon R7 370 / R9 270X/370X] vendor: ASUSTeK
driver: amdgpu v: kernel alternate: radeon bus-ID: 01:00.0 chip-ID: 1002:6810 class-ID: 0300
Display: x11 server: X.Org 1.20.11 compositor: kwin_x11 driver: loaded: amdgpu,ati
unloaded: modesetting,radeon alternate: fbdev,vesa display-ID: :0 screens: 1
Monitor-1: HDMI-A-0 res: 1920x1080 dpi: 94 size: 521x293mm (20.5x11.5") diag: 598mm (23.5")
OpenGL:
renderer: AMD Radeon HD 8800 Series (PITCAIRN DRM 3.40.0 5.12.2-153-tkg-bmq LLVM 11.1.0)
v: 4.6 Mesa 21.2.0-devel (git-a1c56b8091) direct render: Yes
Audio:     Device-1: AMD SBx00 Azalia vendor: ASUSTeK driver: snd_hda_intel v: kernel bus-ID: 00:14.2
chip-ID: 1002:4383 class-ID: 0403
Device-2: AMD Oland/Hainan/Cape Verde/Pitcairn HDMI Audio [Radeon HD 7000 Series]
vendor: ASUSTeK driver: snd_hda_intel v: kernel bus-ID: 01:00.1 chip-ID: 1002:aab0
Sound Server-1: ALSA v: k5.12.2-153-tkg-bmq running: yes
Network:   Device-1: Intel 82583V Gigabit Network vendor: ASUSTeK driver: e1000e v: kernel port: c000
bus-ID: 03:00.0 chip-ID: 8086:150c class-ID: 0200
Device-2: Ralink RT5572 Wireless Adapter type: USB driver: rt2800usb bus-ID: 1-3:2
chip-ID: 148f:5572 class-ID: 0000 serial: <filter>
IF: wlp0s18f2u3 state: up mac: <filter>
Drives:    Local Storage: total: 931.51 GiB used: 233.24 GiB (25.0%)
ID-1: /dev/sda maj-min: 8:0 vendor: Western Digital model: WD10EZRX-00L4HB0 size: 931.51 GiB
block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s rotation: 5400 rpm serial: <filter>
rev: 1A01 scheme: GPT
Partition: ID-1: / raw-size: 922.46 GiB size: 922.46 GiB (100.00%) used: 233.24 GiB (25.3%) fs: btrfs
dev: /dev/sda2 maj-min: 8:2
ID-2: /boot/efi raw-size: 256 MiB size: 252 MiB (98.46%) used: 546 KiB (0.2%) fs: vfat
dev: /dev/sda1 maj-min: 8:1
ID-3: /home raw-size: 922.46 GiB size: 922.46 GiB (100.00%) used: 233.24 GiB (25.3%) fs: btrfs
ID-4: /var/log raw-size: 922.46 GiB size: 922.46 GiB (100.00%) used: 233.24 GiB (25.3%)
ID-5: /var/tmp raw-size: 922.46 GiB size: 922.46 GiB (100.00%) used: 233.24 GiB (25.3%)
Swap:      Kernel: swappiness: 5 (default 60) cache-pressure: 75 (default 100)
ID-1: swap-1 type: zram size: 7.68 GiB used: 286.5 MiB (3.6%) priority: 100 dev: /dev/zram0
ID-2: swap-2 type: partition size: 8.8 GiB used: 0 KiB (0.0%) priority: -2 dev: /dev/sda3
maj-min: 8:3
Sensors:   System Temperatures: cpu: 41.1 C mobo: N/A gpu: amdgpu temp: 49.0 C
Info:      Processes: 246 Uptime: 3h 07m wakeups: 0 Memory: 7.68 GiB used: 3.36 GiB (43.8%) Init: systemd
v: 248 tool: systemctl Compilers: gcc: 10.2.0 clang: 11.1.0 Packages: pacman: 1909 lib: 561
Oh, of course the zoom is at 100%
This is an anti-fingerprinting measure - Tor Browser does the same.
The browser's viewport size can be used to fingerprint the instance, therefore it is restricted to common screen resolutions (or at least certain aspect ratios).
Thank you! Now I want this. :wink: but just to be clear, if I disable/uninstall canvas blocker will it be solved, or is it a firedragon.cfg feature?
The config values you want to be looking at are the following:
// # RFP
defaultPref("privacy.resistFingerprinting", true);
defaultPref("privacy.resistFingerprinting.block_mozAddonManager", true);
lockPref("browser.startup.blankWindow", false); // breaks RFP windows resizing
Try commenting out / setting to false & restarting the browser. If that solves the issue you can put this into the override file to make it stick (if thats what you want) :slight_smile:
