is already .. thx for the suggestion!
will be checking in on this this weekend .. thx!
JUST DOCUMENTATION
No action being looked for.
updated discord
via its update button and then a bit later xorg crashed, unsure related but uptime was days the BOOM!:
Jul 20 10:47:18 Bit ananicy-cpp[547]: [2022-07-20 10:47:18.228] [info] Discord(3096127)
Jul 20 10:47:23 Bit kernel: nouveau 0000:09:00.0: fifo: fault 01 [WRITE] at 0000000000240000 engine 00 [GR] client 0f [GPC0/PROP_0] reason 02 [PTE] on channel 2 [007fb1a000 Xorg[641]]
Jul 20 10:47:23 Bit kernel: nouveau 0000:09:00.0: fifo: channel 2: killed
Jul 20 10:47:23 Bit kernel: nouveau 0000:09:00.0: fifo: runlist 0: scheduled for recovery
Jul 20 10:47:23 Bit kernel: nouveau 0000:09:00.0: fifo: engine 0: scheduled for recovery
Jul 20 10:47:23 Bit kernel: nouveau 0000:09:00.0: fifo: engine 6: scheduled for recovery
Jul 20 10:47:23 Bit kernel: nouveau 0000:09:00.0: Xorg[641]: channel 2 killed!
Jul 20 10:47:23 Bit audit[641]: ANOM_ABEND auid=4294967295 uid=0 gid=0 ses=4294967295 pid=641 comm="Xorg" exe="/usr/lib/Xorg" sig=6 res=1
Jul 20 10:47:23 Bit kernel: audit: type=1701 audit(1658339243.780:327): auid=4294967295 uid=0 gid=0 ses=4294967295 pid=641 comm="Xorg" exe="/usr/lib/Xorg" sig=6 res=1
Jul 20 10:47:23 Bit systemd[1]: Created slice Slice /system/systemd-coredump.
Jul 20 10:47:23 Bit audit: BPF prog-id=56 op=LOAD
Jul 20 10:47:23 Bit audit: BPF prog-id=57 op=LOAD
Jul 20 10:47:23 Bit audit: BPF prog-id=58 op=LOAD
Jul 20 10:47:23 Bit kernel: audit: type=1334 audit(1658339243.786:328): prog-id=56 op=LOAD
Jul 20 10:47:23 Bit kernel: audit: type=1334 audit(1658339243.786:329): prog-id=57 op=LOAD
Jul 20 10:47:23 Bit kernel: audit: type=1334 audit(1658339243.786:330): prog-id=58 op=LOAD
Jul 20 10:47:23 Bit systemd[1]: Started Process Core Dump (PID 3096144/UID 0).
Jul 20 10:47:23 Bit audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-coredump@0-3096144-0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jul 20 10:47:23 Bit kernel: audit: type=1130 audit(1658339243.787:331): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-coredump@0-3096144-0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jul 20 10:47:24 Bit systemd-coredump[3096145]: Process 641 (Xorg) of user 0 dumped core.
Looks like a graphics driver bug.
yeah, was going to look into how to use the default/non-nvidia driver.
my card is pathetic so i really dont have need for serious graphics power.
if you have a link to how to switch to a more basic driver that would be cool!
