I have disabled all searches except local whoogle. I can use wgl: weather
and search works fine. however when searching from the address bar google is always used.
using firedragon 100.2
You have to go in SETTINGS and manually select WHOOGLE (LOCAL) from the drop down list of Search Engines.
Sometimes the things that are right in front of you are so obvious. I did select the default search engine as whoogle. You are awsome!
