inxi
Kernel: 5.15.18-1-lts x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=6b9b1581-851d-48e8-aefd-50c43c9df285 rw [email protected]
resume=UUID=627ec95c-1cbb-46d5-b209-fc50f8eee503 loglevel=3
Type: Laptop System: ASUSTeK product: VivoBook_ASUSLaptop X513EAN_X513EA
Mobo: ASUSTeK model: X513EAN v: 1.0 serial: <superuser required>
UEFI: American Megatrends LLC. v: X513EAN.201 date: 05/31/2021
ID-1: BAT0 charge: 35.0 Wh (82.0%) condition: 42.7/42.1 Wh (101.5%)
volts: 11.8 min: 11.8 model: ASUSTeK ASUS Battery type: Li-ion serial: N/A
status: Charging
Info: model: 11th Gen Intel Core i7-1165G7 bits: 64 type: MT MCP
arch: Tiger Lake family: 6 model-id: 0x8C (140) stepping: 1 microcode: 0x88
L3: 12 MiB desc: 1x12 MiB
Speed (MHz): avg: 1864 high: 3992 min/max: 400/4700 scaling:
driver: intel_pstate governor: powersave cores: 1: 1166 2: 841 3: 1403
4: 3989 5: 3992 6: 898 7: 1242 8: 1381 bogomips: 44851
Device-1: Intel TigerLake-LP GT2 [Iris Xe Graphics] vendor: ASUSTeK
driver: i915 v: kernel bus-ID: 0000:00:02.0 chip-ID: 8086:9a49
Device-2: IMC Networks USB2.0 HD UVC WebCam type: USB driver: uvcvideo
bus-ID: 1-6:3 chip-ID: 13d3:56a8 class-ID: 0e02 serial: <filter>
loaded: intel unloaded: modesetting alternate: fbdev,vesa display-ID: :0
s-diag: 582mm (22.9")
Monitor-1: eDP1 res: 1920x1080 hz: 60 dpi: 143
size: 340x190mm (13.4x7.5") diag: 389mm (15.3")
Device-1: Intel Tiger Lake-LP Smart Sound Audio vendor: ASUSTeK
bus-ID: 0000:00:1f.3 chip-ID: 8086:a0c8 class-ID: 0403
Sound Server-1: ALSA v: k5.15.18-1-lts running: yes
Sound Server-3: JACK v: 1.9.20 running: no
Sound Server-5: PipeWire v: 0.3.44 running: yes
Device-1: MEDIATEK vendor: AzureWave driver: mt7921e v: kernel port: N/A
bus-ID: 0000:02:00.0 chip-ID: 14c3:7961 class-ID: 0280
Device-1: IMC Networks Wireless_Device type: USB driver: btusb v: 0.8
bus-ID: 1-10:4 chip-ID: 13d3:3563 class-ID: e001 serial: <filter>
v: 0.6 port: N/A bus-ID: 0000:00:0e.0 chip-ID: 8086:9a0b rev:
class-ID: 0104
Local Storage: total: 476.94 GiB used: 16.79 GiB (3.5%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Intel model: SSDPEKNW512G8
speed: 31.6 Gb/s lanes: 4 type: SSD serial: <filter> rev: 004C
temp: 30.9 C scheme: GPT
used: 16.79 GiB (3.6%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-1: swap-1 type: partition size: 8.8 GiB used: 0 KiB (0.0%)
ID-2: swap-2 type: zram size: 7.45 GiB used: 5.5 MiB (0.1%) priority: 100
System Temperatures: cpu: 50.0 C mobo: N/A
Fan Speeds (RPM): cpu: 3200
Processes: 262 Uptime: 27m wakeups: 1181 Memory: 7.45 GiB
used: 3.04 GiB (40.7%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.1.0 clang: 13.0.0 Packages: pacman: 1607 lib: 470 Shell: fish
v: 3.3.1 running-in: konsole inxi: 3.3.12
Garuda (2.5.3-1):
System install date: 2022-02-01
Last full system update: 2022-02-01
Is partially upgraded: Yes
Failed units: dev-binderfs.mount systemd-networkd-wait-online.service
Hello again. I'd like to use my fingerprint sensor on my laptop, but it doesn't show in lsusb
. Here's my output of the command:
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 001 Device 003: ID 13d3:56a8 IMC Networks USB2.0 HD UVC WebCam
Bus 001 Device 004: ID 13d3:3563 IMC Networks Wireless_Device
Bus 001 Device 002: ID 093a:2510 Pixart Imaging, Inc. Optical Mouse
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Is there a way to connect my sensor to linux?
