Fingerprint scanner only working after suspend
I recently tried to set up my fingerprint scanner using fprintd. I followed the arch wiki documentation. For a second it didn’t get prompted anywhere, even after editing my pam.d. However, after any suspends now it has started showing up in the intended way. This is, however, in combination with the default Garuda lockscreen being shown, instead of breeze dark. What could be the problem here? Thanks!
lsusb:
Bus 003 Device 004: ID 27c6:639c Shenzhen Goodix Technology Co.,Ltd. Goodix USB2.0 MISC
:warning: Missing information requested in the template may result in not receiving assistance
Issue still unresolved? Then:
  • ONE issue per topic.
Without garuda-inxi this request will be moved to 412 Precondition Failed
Suggestion: You give us your garuda-inxi and we will try to help you. Deal?
Edit: @SGS was exactly 1 second faster…that was close :grin:
My bad, did not realize this could help. Attached below.
Kernel: 6.8.1-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=1cf914cd-0f9c-40c1-bb81-3eb62d43a5db rw rootflags=subvol=@
Desktop: KDE Plasma v: 6.0.2 tk: Qt v: N/A info: frameworks v: 6.0.0
Type: Laptop System: Dell product: Inspiron 14 5430 v: N/A
Mobo: Dell model: 065RWX v: A00 serial: <superuser required> part-nu: 0C14
uuid: <superuser required> UEFI: Dell v: 1.12.0 date: 02/05/2024
ID-1: BAT0 charge: 25.6 Wh (47.3%) condition: 54.1/54.0 Wh (100.2%)
volts: 15.9 min: 15.0 model: BYD DELL WV3K833 type: Unknown serial: <filter>
status: charging cycles: 119
Info: model: 13th Gen Intel Core i7-1360P bits: 64 type: MST AMCP
arch: Raptor Lake level: v3 note: check built: 2022+ process: Intel 7 (10nm)
family: 6 model-id: 0xBA (186) stepping: 2 microcode: 0x4121
Topology: cpus: 1x cores: 12 mt: 4 tpc: 2 st: 8 threads: 16 smt: enabled
cache: L1: 1.1 MiB desc: d-8x32 KiB, 4x48 KiB; i-4x32 KiB, 8x64 KiB
L2: 9 MiB desc: 4x1.2 MiB, 2x2 MiB L3: 18 MiB desc: 1x18 MiB
Speed (MHz): avg: 1087 high: 3547 min/max: 400/5000:3700 scaling:
driver: intel_pstate governor: powersave cores: 1: 2084 2: 400 3: 507 4: 400
5: 2830 6: 400 7: 400 8: 400 9: 3547 10: 400 11: 400 12: 972 13: 572
14: 3280 15: 400 16: 400 bogomips: 83558
Device-1: Intel Raptor Lake-P [Iris Xe Graphics] vendor: Dell driver: i915
v: kernel alternate: xe arch: Gen-13 process: Intel 7 (10nm) built: 2022+
ports: active: eDP-1 empty: DP-1,DP-2,HDMI-A-1 bus-ID: 0000:00:02.0
chip-ID: 8086:a7a0 class-ID: 0300
Device-2: Microdia Integrated_Webcam_FHD driver: uvcvideo type: USB
rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-6:4 chip-ID: 0c45:6a1b
class-ID: 0e02
Monitor-1: eDP-1 res: 1920x1200 size: N/A modes: N/A
drv: iris inactive: gbm
API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 24.0.3-arch1.2
glx-v: 1.4 direct-render: yes renderer: Mesa Intel Graphics (RPL-P)
device-ID: 8086:a7a0 memory: 14.95 GiB unified: yes display-ID: :1.0
API: Vulkan v: 1.3.279 layers: 13 device: 0 type: integrated-gpu
name: Intel Graphics (RPL-P) driver: mesa intel v: 24.0.3-arch1.2
device-ID: 8086:a7a0 surfaces: xcb,xlib,wayland device: 1 type: cpu
v: 24.0.3-arch1.2 (LLVM 17.0.6) device-ID: 10005:0000
Device-1: Intel Raptor Lake-P/U/H cAVS vendor: Dell
alternate: snd_hda_intel,snd_sof_pci_intel_tgl bus-ID: 0000:00:1f.3
chip-ID: 8086:51ca class-ID: 0401
API: ALSA v: k6.8.1-zen1-1-zen status: kernel-api with: aoss
Server-1: PipeWire v: 1.0.4 status: active with: 1: pipewire-pulse
Device-1: Intel Raptor Lake PCH CNVi WiFi driver: iwlwifi v: kernel
bus-ID: 0000:00:14.3 chip-ID: 8086:51f1 class-ID: 0280
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-10:5 chip-ID: 8087:0033
Hardware-1: Intel Volume Management Device NVMe RAID Controller Intel
driver: vmd v: 0.6 port: N/A bus-ID: 0000:00:0e.0 chip-ID: 8086:a77f rev:
class-ID: 0104
Local Storage: total: 953.87 GiB used: 281.54 GiB (29.5%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: SK Hynix
model: BC901 NVMe 1024GB size: 953.87 GiB block-size: physical: 512 B
fw-rev: 51005151 temp: 29.9 C scheme: GPT
used: 281.5 GiB (29.5%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
used: 44 MiB (14.7%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-1: swap-1 type: zram size: 15.31 GiB used: 96.5 MiB (0.6%)
System Temperatures: cpu: 45.0 C mobo: 42.0 C sodimm: SODIMM C
Fan Speeds (rpm): cpu: 0
Memory: total: 16 GiB note: est. available: 15.31 GiB used: 8.29 GiB (54.1%)
Processes: 440 Power: uptime: 1h 41m states: freeze,mem,disk
suspend: s2idle wakeups: 1 hibernate: platform avail: shutdown, reboot,
suspend, test_resume image: 6.11 GiB services: org_kde_powerdevil,
Packages: pm: pacman pkgs: 1959 libs: 577 tools: gnome-software, octopi,
pamac, paru Compilers: clang: 17.0.6 gcc: 13.2.1 Shell: garuda-inxi
default: fish v: 3.7.0 running-in: konsole inxi: 3.3.33
Garuda (2.6.23-1):
System install date:     2024-03-20
Last full system update: 2024-03-27
Post any PAM files you have modified into the thread so we can take a look.
As always with issues like this, be sure you have the newest bios version installed, and test at least 3 alternate kernels.
